Local Time 15:58 19 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Problems with PEEK and POKE in MMBasic
v.lenzer
Posted: 02:42pm 09 Jun 2024
I want to create a data logger with an RP2040-Zero. I'm working with MMBasic, V.5.08. I wanted to use POKE BYTE .. and PEEK ... for this. But I haven't had any success with that yet. POKE BYTE 1000,111 (write the value 111 to address 1000) seems to work. At least I don't get an error message with it. But with PEEK(BYTE 1000) I don't get the value 111 back. I've already searched the forum, but unfortunately I haven't found any entries. Does anyone have experience with PEEK and POKE in MMBasic? Can the RAM of the RP2040-Zero be used for this at all?
Best wishes! Joachim
Posted: 02:59pm 09 Jun 2024
Hi @v.lenzer,
Not immediately sure about why that doesn't work (Edit: perhaps address 1000 - which is very low - is acting as ROM but not reporting an error when you try to write to it ?), however ...
Are you POKEing and PEEKing into arbitrary addresses? ... I would recommend against that.
Allocate an INTEGER array, and use POKE VAR and PEEK(VAR ...) (or PEEK(VARADDR var) so you know that you own the memory in question and it isn't the address of a piece of supposedly opaque MMBasic internals.
Edited 2024-06-10 01:12 by thwill
Posted: 03:23pm 09 Jun 2024
  Quote  2.6.1. ROM
A 16kB read-only memory (ROM) is at address 0x00000000. The ROM contents are fixed at the time the silicon is
manufactured. It contains:
• Initial startup routine
• Flash boot sequence
• Flash programming routines
• USB mass storage device with UF2 support
• Utility libraries such as fast floating point
As Tom says......
v.lenzer
Posted: 04:02pm 09 Jun 2024
thank you very much for your advices. I should have known that address 0 points to the ROM. I'm sorry. If I poke higher addresses than 16KB, the connection is broken. I'm probably poke to RAM locations that contain important values ​​or the program.
With DIM INTEGER adr(nbr) I can unfortunately only store a maximum of 256 bytes. That's why I came up with the idea of ​​writing to RAM. I wanted to write several thousand pulses (data logger).
I have to come up with a construct with variables. We'll see. In any case, I now know how to handle PEEK and POKE.
Edited 2024-06-10 02:07 by v.lenzer
Don't POKE just anywhere. It either won't work (if you're lucky), introduce obscure and unpredictable errors (if you're unlucky) or just crash the lot.
There is no "safe" normal RAM area that can be used with POKE.
You can poke into the video display area or into the variables area (into known variables only). See VAR POKE. I often POKE into strings, it's a neat way to store individual bytes.
For a data logger you are probably better saving to a file using OPEN APPEND to tag the new stuff onto the end. The file can be on drive A (but space is limited) or on a SD card.
Posted: 04:11pm 09 Jun 2024
  v.lenzer said  With DIM AS INTEGER adr(nbr) I can unfortunately only store a maximum of 256 bytes.
Why do you conclude that ?
Untested but something along these lines definitely allows you to store/manipulate 16K:
Dim buf%(16 * 1024 / 8) ' 16K buffer
Dim offset%
For offset% = 0 To (16 * 1024) - 1
 Poke Var buf%, offset, &hAB ' Store 0xAB in each byte.
Next
v.lenzer
Posted: 04:35pm 09 Jun 2024
Unfortunately, the short program didn't work. The error message appears: "[4] Poke Var buf%, offset%, &hAB ' Store 0xAB in each byte.
Error : Array dimensions"
Perhaps it's because I'm using an RP2040-Zero. I now have to study the OPEN APPEND command. Perhaps I can handle it.
At this point I have to apologize. I'm a newbie. I've already programmed many controllers in machine language, but I'm only just starting out with MMBasic. I'm trying to learn and practice through small projects in practice. That's why I often ask stupid questions.
Posted: 04:40pm 09 Jun 2024
Replace buf% with buf%() in the offending line.
Posted: 04:42pm 09 Jun 2024
Try this line. For me, it runs.
Poke Var buf%(), offset%, &hAB ' Store 0xAB in each byte.
(Note also "%" on offset.)
Edited 2024-06-10 02:43 by lizby
v.lenzer
Posted: 04:54pm 09 Jun 2024
Hurray! It worked and I was able to read the values ​​again with PEEK (VAR ...)! Thank you very much!!!
twofingers
Posted: 05:23pm 09 Jun 2024
  v.lenzer said  ... That's why I came up with the idea of ​​writing to RAM. I wanted to write several thousand pulses (data logger).[...]
I don't know if it's a good idea to use Peek and Poke for this. I would consider whether a string array with one byte strings (length 1) might not be a cleaner solution.
Example for an array of 16kB:
DIM STRING myByte$(16*1024) LENGTH 1
Best regards
Michael
Edit: One disadvantage is that each usable byte costs you two bytes in memory.
Edited 2024-06-10 04:08 by twofingers
Martin H.
Posted: 06:38pm 09 Jun 2024
a more economical way for an array of 16kB:
DIM STRING myByte$(128) LENGTH 128
you only waste additional 128 bytes for 16k Memory
Edited 2024-06-10 04:39 by Martin H.
'no comment
twofingers
Posted: 08:03am 10 Jun 2024
It might also be worth looking at the LONGSTRING command.
Martin H.
Posted: 12:38pm 10 Jun 2024
  twofingers said  It might also be worth looking at the LONGSTRING command.
possible.
As long as you do not use BASIC string functions on the array, you can even use the entire memory that has been reserved for this purpose.
'no comment
Martin H.
Posted: 01:38pm 10 Jun 2024
btw .. nice User Name @v.lenzer
a pun for slackers
'no comment
v.lenzer
Posted: 02:59pm 10 Jun 2024
Better than B.Trüger!
