Forum Index : Microcontroller and PC projects : MicroMite vs PicoMite
fmafma
Posted: 01:45pm 04 Jul 2024
Hi!
I'm wondering if it could be possible to build a MMBackPack using a RPi Pico? In this case, would MMBackPack documentation apply to the RPi Pico-based BackPack?
What are the differences between MicroMite and PicoMite? Do firmwares evolve at the same rate?
Thanks,
Frédéric
Posted: 02:12pm 04 Jul 2024
The two devices are completely different apart from the fact that they both run MMBasic. :)  The versions are a bit different though as the Micromite has a lot more limitations. You would need the standard PicoMite documentation for MMBasic.
I did a backpack design for a PicoMite some time ago. I think you'll find it if you follow the link in my sig.
I've been working on a slight update to it if you are interested. I can't remember offhand whether I've published anything about it yet.
Posted: 04:48pm 04 Jul 2024
  fmafma said   possible to build a MMBackPack using a RPi Pico
What would you want this backpack to do? A number of people have posted PCBs for the PicoMite.
fmafma
Posted: 07:45pm 04 Jul 2024
The idea is to have a small RP2040-based platform to prototype, with a screen and maybe a few buttons, a battery (+charger), and a speaker, which could run Micropython or MMBasic, and be able to run MMBasic examples written for the MMBackPack...
I guess only inits should match the board (pins to LCD)?
Frédéric
fmafma
Posted: 07:46pm 04 Jul 2024
  Mixtel90 said  I did a backpack design for a PicoMite some time ago. I think you'll find it if you follow the link in my sig.
I found your design, thanks!
Frédéric
Posted: 09:24pm 04 Jul 2024
What you described sounds a bit like Toms GameMite design. Screen, a few buttons, speaker (but mono), battery & charger. It's designed for MMBasic, but I suppose you could put Micropython if you mess about enough. It also has a little GPIO port to give a few IO.
I haven't done a design with screen and battery so far, mostly because it means buying batteries. :)
I've found my version 1.2 of the backpack board. As I said, it adds a few features and tidies up some problems on the original. I didn't do a manual and BOM for it though, although I have a circuit diagram.
Posted: 09:59pm 04 Jul 2024
I was also going to say it sounds like you might want to consider a Game*Mite. @bigmik and I tried to make the GPIO accessible and  I know that @Volhout has been making use of his beyond it's original gaming purpose.
Edited 2024-07-05 09:09 by thwill
