Local Time 16:00 19 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Cellphone video is 90' out...
Posted: 07:40am 05 Jul 2024
When I download videos from my phone, although they play OK on the phone, they are 90's out of alignment when played on the PC with something like VLC.
I need some kind of software, that can take these files, rotate the video(left) by 90', and then save a new copy of the video.
Can anyone suggest anything?
Posted: 07:55am 05 Jul 2024
Linux or Doze?
Posted: 08:15am 05 Jul 2024
Are you taking the videos in portrait mode? That should be banned. The best you can get is a vertical strip in the middle of the screen with huge black side borders.
Edited 2024-07-05 18:16 by Mixtel90
Posted: 08:29am 05 Jul 2024
Hi Grogster, All,
You can change the rotation in VLC itself.  See this link
VLC Rotate
CaptainBoing
Posted: 09:20am 05 Jul 2024
https://ezgif.com/rotate
Posted: 11:30am 05 Jul 2024
A couple of ideas:
1. mplayer can rotate when showing videos
2. ffmpeg can convert an input video into a rotated output one
e.g. using -vf transpose =...
Quazee137
Posted: 11:33am 05 Jul 2024
If you like a GUI try winFF it use FFmpeg.
 Quazee137
Martin H.
Posted: 12:05pm 05 Jul 2024
or just use Handbrake (my favourite tool for compressing MP4/MKV videos) for Linux and Windoze
Can HandBrake Rotate Video? Here’s Guidance You Can Try
Edited 2024-07-05 22:15 by Martin H.
'no comment
Turbo46
Posted: 10:51pm 05 Jul 2024
Maybe your phone is locked into portrait mode so it will not change when you rotate the phone.
Bill
Posted: 12:38am 06 Jul 2024
  Mixtel90 said  Are you taking the videos in portrait mode? That should be banned. The best you can get is a vertical strip in the middle of the screen with huge black side borders.
No, I am taking them in landscape mode(phone on it's side), but when you try to play them, they come out as portrait orientation, 90-degrees rotated to the right - so just as you say: vertical strip in the middle of the screen.
ON THE PHONE, they play fine if you turn the phone on it's side, it's just when you try to play the downloaded video file on something else.
Posted: 12:41am 06 Jul 2024
  bigmik said  Hi Grogster, All,
VLC Rotate
EXCELLENT information, thank you.
That fixed it.
Turbo46
Posted: 05:45am 06 Jul 2024
  Turbo46 said  Maybe your phone is locked into portrait mode so it will not change when you rotate the phone.
Bill
