Local Time 07:35 13 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMiteVGA DEMO
     Page 13 of 13
javavi
Posted: 09:16am 22 Aug 2026
Option ANGLE DEGREES
RX=MM.HRES: RY=MM.VRES: CX=RX/2: CY=RY/2
Umin=-180: Umax=180: Ustep=14
Vmin= -90: Vmax= 90: Vstep=14
SCALE=220: C=1
Colour RGB(Cyan)
CLS
 If C>0 Then C=0 Else C=1
 For S=0 To 12 Step 2
   For V= Vmin To Vmax Step Vstep
   For U= Umin To Umax Step Ustep
     U=U+S
       x=Cos(U)*Cos(V)
       y=Sin(U)*Cos(V)
       z=Sin(V)
     U=U-S
     Plot_XY
     If Inkey$ <> "" Then End
   Next U: Next V
 Next S
Sub Plot_XY
 x=SCALE*x: y=SCALE*y: z=SCALE*z
 y=y/3
 If y<0 Then
   Circle CX+x-y,CY+z-y,1,,,C
 Else
   Pixel CX+x-y,CY+z-y,C
 EndIf
End Sub
javavi
Posted: 06:09pm 23 Aug 2026
Tesseract The Space Stone / The Cosmic Cube
MODE 3
CX=MM.HRES\2
CY=MM.VRES\2
Dim P(5),Q(5)
For L=0 To 5
 S=Pi/3*L
 P(L)=500*Sin(S)
 Q(L)=500*Cos(S)
Next
X=0:Y=500
For L=0 To 320000
 R=Int(Rnd*6)
 X=(X+P(R))/2
 Y=(Y+Q(R))/2
 PX=CX+X\2
 PY=CY+Y\2
 G=Pixel(PX,PY)
 Color Map(1)
 If G>0 Then Color Map(7)
 Pixel PX,PY
Next
javavi
Posted: 05:39pm 01 Sep 2026
Strudel aus den Kreisen
Excuse my German, but if you watch it for a long time, it should start spinning
MODE 2
Map Reset
For Y=0 To 240-1
 Color Map(1+(Y Mod 8))
 Line 0,Y,320,Y
Next
Color 0
Pause 1000
C=36
For O=0 To 7
 For A=0 To 7
   B=(A*8+O)*Pi/32
   L=120*Sin(B)+160
   M=((68*Cos(B))\8*8)+125
   For Y=M-C+O To M+C Step 8
     R=Sqr(Abs(C*C-(Y-M)^2))
     Line L-R,Y,L+R,Y
   Next
 Next
Next
Pause 1000
Dim CM%(15)
CM%(1)=RGB(Cyan)
 For i%=0 To 7:CM%(i%)=CM%(i%+1):Next
 CM%(8)=CM%(0)
 For i%=1 To 8:Map(i%)=CM%(i%):Next
 Map Set
 Pause 60
Loop While Inkey$=""
javavi
Posted: 09:49am 06 Sep 2026
Circular Strudel
MODE 3
Dim C%(15)=(0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15)
Colour Map C%(), C%()
xc=MM.HRES\2
yc=MM.VRES\2
 r=r+Pi/180
 w=w+Pi/72
 For i=1 To 11
   x=xc+200*Cos(w+i*Pi/6)*Sin(r)
   y=yc+200*Sin(w+i*Pi/6)*Sin(r)
   Circle x,y,40,,,C%(6),C%(0)
   ww=ww+Pi/80
   If i=1 Then
     For j=1 To 11
       xx=x+100*Cos(ww+j*Pi/6)*Sin(r)
       yy=y+100*Sin(ww+j*Pi/6)*Sin(r)
       Circle xx,yy,20,,,C%(8),C%(0)
       w3=w3+Pi/80
       If j=1 Then
         For k=1 To 11
           x3=xx+50*Cos(w3+k*Pi/6)*Sin(r)
           y3=yy+50*Sin(w3+k*Pi/6)*Sin(r)
           Circle x3,y3,10,,,C%(1),C%(0)
         Next k
       EndIf
     Next j
   EndIf
 Next i
javavi
Posted: 02:46pm 14 Sep 2026
Hyperboloid
MODE 3
XC=MM.HRES\2: YC=MM.VRES\2
D=3: CX=0: CY=-1: CZ=1
For CY=-1 To 1 Step 2
 For I=0 To 2*Pi Step Pi/26
   XM=CX+Sin(I): YM=CY: ZM=CZ+Cos(I)
   XD=CX+Sin(I+Pi/2): YD=-CY: ZD=CZ+Cos(I+Pi/2)
   If (ZM+ZD)/2>CZ Then Color RGB(Cyan) Else Color RGB(Yellow)
   SXM=XM*D/(ZM+D): SYM=YM*D/(ZM+D)
   SXD=XD*D/(ZD+D): SYD=YD*D/(ZD+D)
   Line XC+XC*SXM,YC+YC*SYM,XC+XC*SXD,YC+YC*SYD
 Next
Next
javavi
Posted: 06:10pm 14 Sep 2026
Eldritch
MODE 2
FRAMEBUFFER CREATE
FRAMEBUFFER WRITE F
Dim PLGNX%(6)
Dim PLGNY%(6)
CX=MM.HRES\2:CY=MM.VRES\2
C%=RGB(Red)
 CLS
 For z=1 To 63
   For t=0 To 6
     x=CX+(Sin(t*1.05+Sin(Timer/300+z/10))*(z*4))
     y=CY+(Cos(t*1.05+Sin(Timer/300+z/10))*(z*4))
     PLGNX%(t)=x:PLGNY%(t)=y
   Next
   Polygon 6,PLGNX%(),PLGNY%(),C%
 Next
 FRAMEBUFFER COPY F,N,B
JulesO
Posted: 11:49am 15 Sep 2026
Thanks Javavi, it's always fun to test and play with your work. Great code to learn from.
javavi
Posted: 02:33pm 04 Oct 2026
Comet
MODE 2 '1 2 3
cx=MM.HRES\2
cy=MM.VRES\2
cr=7
rd=cy-cr
C=RGB(Cyan)
 For i=1 To 1000
   Pixel Rnd*MM.HRES,Rnd*MM.VRES,0
 Next
 t=Timer/5000
 x=cx+rd*Cos(3*t)
 y=cy+rd*Sin(4*t)
 Circle x,y,cr,,,C,C
mozzie
Posted: 03:05pm 07 Oct 2026
G'day Javavi,
Some of these short programs are a great learning device, I always look forward to trying out the latest one to see how they work and what can be changed.
That last one had me guessing how it new where to erase the tail, until the realization that its entropy at work. Brilliant in its simplicity
Hope to see many more.
Regards, Lyle.
PilotPirx
Posted: 07:05am 08 Oct 2026
Hi mozzie,
yes, it's a clever little program.
It's interesting that random deletion produces such an effect.
If you disable the delete function, it draws a Lissajous figure with a frequency ratio of 3:4.
DaveJacko
Posted: 09:08pm 08 Oct 2026
Fascinating work, guys!.. amazing how a little bit of mathematics can produce such images, (and remind us of the concept of entropy, and how strange.. maths controls the universe)
I am minded of the work of Alan Turing into the maths of Leopard spots and all sorts of other patterns in biology. Might be a bit more computationally expensive, but, we've got a compiler now!.. anyone inspired? I never got much beyond "Conway's game of life" myself.
BTW the WikiP article on Conway's game of life is excellent
Edited 2026-10-09 07:13 by DaveJacko
Try swapping 2 and 3 over
BarryH
Posted: 04:12am 09 Oct 2026
Yes, the Wikipedia article is fascinating and just like the Mandelbrot equations & fractals, show that initially inane constructs and discoveries can indeed have great scientific value.
BarryH
javavi
Posted: 03:30pm 11 Oct 2026
Turbulent flows
MODE 2
For YM=0 To MM.VRES-1
 For XM=0 To MM.HRES-1
   X=XM:Y=YM
   U=X:V=Y
   For L=0 To 3
     U=U+Sin(V*.01*L)*30
     V=V+Sin(U*.01*L)*30
   Next
   O=Sin(Int(V/2)*123.45)*12
   O=O-Int(O)
   Color Map(15 And(Int(U)+O*16))
   Pixel X,Y
 Next
Next
Dim integer CM(15)=(0,9,15,9,0,0,0,0,0,0,0,0,0,0,0,0)
Colour Map CM(),CM()
 Tmp=CM(0)
 For i=0 To 14: CM(i)=CM(i+1): Next
 CM(15)=Tmp
 For i=0 To 15: Map(i)=CM(i): Next
 Map Set
 Pause 50
     Page 13 of 13
