Local Time 00:16 12 Aug 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMiteVGA DEMO
     Page 5 of 12
javavi
Posted: 05:11pm 19 Nov 2024
Black and White Infinite Art Cubism
MODE 1
 Q=Int(Rnd*5+3): If Q=7 Then Q=30
 A=Rad(360/Q): S=Sin(A): C=Cos(A)
 X=Rnd*MM.HRes: Y=Rnd*MM.VRes
 R=Rnd*(Sqr(Y+X)/20)*40+16
 For L=-R/5 To R/5
   N=(Abs(L)<R/8)*Int(Rnd*2)
   U=R+L: V=U
   X1=X+U: Y1=Y+V
   For I=1 To Q
     T=V*C-U*S: U=V*S+U*C: V=T
     X2=X+U: Y2=Y+V
     Line X1,Y1,X2,Y2,,N
     X1=X2: Y1=Y2
   Next
 Next
Loop While Inkey$=""
javavi
Posted: 05:32pm 26 Nov 2024
3D DISCO BALL
MODE 2
FRAMEBUFFER CREATE
FRAMEBUFFER WRITE F
 CLS
 t=Timer
 n=7
 r=n*16
 tr=t-n*50
 ra=tr/1234
 rb=tr/2345
 For a=0 To Pi Step .39268
   For b=0 To Pi*2 Step .8-.6*Sin(a)
     o=Sin(a)*Cos(b)
     k=Sin(a)*Sin(b)
     e=Cos(a)*Cos(ra)+k*Sin(ra)
     x=(o*Cos(rb)+e*Sin(rb))*r+160
     y=(e*Cos(rb)-o*Sin(rb))*r+120
     If Cos(a)*Sin(ra)-k*Cos(ra)<.05 Then
       C=Map(Int(Rnd*14)+1)
       Circle x,y,4,,,C,C
     Else
       Circle x,y,1,,,Map(15)
     EndIf
   Next b
 Next a
 FRAMEBUFFER COPY F,N,B
Edited 2024-11-27 04:25 by javavi
Martin H.
Posted: 04:24pm 28 Nov 2024
  Martin H. said  a litle animation inspired by the planet 9 demo
With small change it also runs on Game*Mite or any other Pico with LCD
FRAMEBUFFER create
FRAMEBUFFER write f
a=100:b=3:xc=160:yc=120
For n=0 To 9:For i=n To 180 Step 10
t=(i+90)*Pi/180:x=a*Cos(t):y=b*Sin(t):cl=(y<0):ball xc+x,n*20+yc+y-112,cl
Next : For i=170+n To n Step -10
t=(i-90)*Pi/180:x=a*Cos(t):y=b*Sin(t):cl=(y<0):ball xc+x,n*20+yc+y-112,cl
Next :Next
Blit 0,0,0,200,320,20:Blit 0,20,0,0,320,220:FRAMEBUFFER copy f,n:Pause 20
Sub ball bx,by,cl
For d=6 To 1Step -1
If cl Then :Color RGB(255,255-d*42,0):Else :Color RGB(0,255-d*42,255):EndIf
Circle bx+d/2,by+d/2,d,d
Next
End Sub
Edited 2024-11-29 02:29 by Martin H.
'no comment
stanleyella
Posted: 05:16pm 28 Nov 2024
cool. needs mode 2 on hdmi pico 2. very fast animation, like 3d a bit!
stanleyella
Posted: 06:16pm 28 Nov 2024
3d disco ball rotataing x axis and y axis same time?? maybe?
javavi
Posted: 07:38pm 28 Nov 2024
  stanleyella said  3d disco ball rotataing x axis and y axis same time?? maybe?
Yes, its axis rotates in three directions, but the ball itself does not spin.
Don't you have anything to see this on?
Martin H.
Posted: 08:44am 29 Nov 2024
  stanleyella said  cool. needs mode 2 on hdmi pico 2. very fast animation, like 3d a bit!
Yes, Mode 2 was included in the original listing. The pseudo 3D visualisation was inspired by the old Amiga demos.
The slight offset when drawing the spheres results in the rotation that occurs when simply scrolling up
'no comment
javavi
Posted: 09:01am 29 Nov 2024
Have a question for experts of retro computer graphics!?
The BBS micro computer had a video mode in which it was possible to form a picture in a palette of 16 colors, and by changing the palette display mode, only 4 colors were displayed. Quickly switching the color palette display mode gave the effect of a moving picture in a cycle. How can this be implemented on PicoMite ?
Posted: 09:16am 29 Nov 2024
  Quote  How can this be implemented on PicoMite ?
Using the map command and function. Ages ago Stanley posted an example of doing exactly this. Perhaps he can post a reference
Martin H.
Posted: 10:01am 29 Nov 2024
  javavi said  Have a question for experts of retro computer graphics!?
here is an example: Animation using MAP Command
Edited 2024-11-29 20:02 by Martin H.
'no comment
stanleyella
Posted: 03:17pm 29 Nov 2024
The Amstrad 464 had the same sort of palette switching as the bbc micro.
@Matherp sorted it for pico and called it map. On arduino, map is scale a value, on GCBasic they wanted to implement map but wanted another name for it, I suggested scale, which stuck.
javavi
Posted: 01:07pm 30 Nov 2024
Attracting Star Whirlpool
MODE 2
Dim integer cm(15)=(0,14,0,7,0,0,6,0,0,4,0,0,2,0,0,0)
Colour Map cm(),cm()
Q=.375
For E=1 To 40 Step .025
 R=E*E/4:T=R/99
 s1=Sin(T):c1=Cos(T)
 N=5+R/1:A=-Pi*2/N
 S=Sin(A):C=Cos(A)
 X=0:Y=R:I=Rnd
 For L=0 To N
   I=I+1 And 15: If I=0 Then I=1
   Color Map(I)
   Pixel 160+X*c1*Q-Y*s1,120+X*s1*Q+Y*c1
   x1=X*C-Y*S:Y=X*S+Y*C:X=x1
 Next
Next
 T=cm(1)
 For i=1 To 15-1:cm(i)=cm(i+1):Next
 cm(15)=T
 For i=1 To 15:Map(i)=cm(i):Next
 Map Set
 Pause 50
Gratitude:  matherp, Martin H., stanleyella
Edited 2024-12-01 01:40 by javavi
stanleyella
Posted: 07:08pm 30 Nov 2024
nice one javavi
make it go in reverse maybe?
Edited 2024-12-01 05:41 by stanleyella
javavi
Posted: 08:09pm 30 Nov 2024
  stanleyella said  nice one javavi
MODE 2
Dim integer cm(15)=(0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15)
Q=.375
R=E*E/4:T=R/99
s1=Sin(T):c1=Cos(T)
N=5+R/1:A=-Pi*2/N
S=Sin(A):C=Cos(A)
X=0:Y=R:I=Int(Rnd)
For L=0 To N
  Color Map(I)
Next
Next
T=cm(15)
For i=15 To 1+1 Step -1:cm(i)=cm(i-1):Next
cm(1)=T
Map Set
Pause 50
Edited 2024-12-01 06:11 by javavi
stanleyella
Posted: 09:08pm 30 Nov 2024
nice! is pico and mmbasic brill?
looks like star trek ds9 wormhole :)
Edited 2024-12-01 07:48 by stanleyella
javavi
Posted: 09:21pm 30 Nov 2024
  stanleyella said  nice! is pico and mmbasic brill?
WonderfulBeautifulAmazingLoveFantasticBrilliantAwesome
Edited 2024-12-02 03:50 by javavi
javavi
Posted: 06:08pm 01 Dec 2024
Toroidal Reactor   ITER
MODE 2
Map Reset
For U=0 To 159
 x1=U/128-1.25
For V=0 To 239
 y1=V/128-1
   X=0:Y=X:Z=-2.4
     k1=Sqr(X*X+Z*Z)-2
     d1=1-Sqr(k1*k1+Y*Y)
     X=X+x1*d1:Y=Y+y1*d1:Z=Z+d1
   Loop Until d1<.005
   v1=Atn(Z/X):u1=Atn(Y/k1)
   sColor(): Pixel U,V
   v1=3.13-v1
   sColor(): Pixel 319-U,V
 Next
Next
Sub sColor()
 p=Sin(Int((u1+v1)*40)*99)*98
 c=15 And ((u1-v1+p)*24*Abs(Sin(p)))
 Color Map(c)
End Sub
Dim integer cm(15)=(0,15,7,1,0,0,0,0,0,0,0,0,0,0,0,0)
 T=cm(1)
 cm(15)=T
 Map Set
 Pause 50
Edited 2024-12-02 04:09 by javavi
stanleyella
Posted: 06:41pm 01 Dec 2024
that's impressive! thanks. I had to learn trig years after school. never used it until started using pics
twofingers
Posted: 07:35pm 01 Dec 2024
Neat!   I immediately thought of "Wendelstein".
In my version, I save the image when it is created for the first time and load it when it is repeated. This is a bit faster - I'm so impatient!
I changed the rotating palette as follows:
Dim integer cm(15)=(15,14,13,12,11,10,9,8,7,6,5,4,3,2,1,0)
This makes the result more colorful.
Best regards
Michael
Edited 2024-12-02 06:05 by twofingers
javavi
Posted: 12:49pm 02 Dec 2024
  twofingers said  This makes the result more colorful.
MODE 2
Map Reset
For U=0 To 159
 x1=U/128-1.25
For V=0 To 239
 y1=V/128-1
   X=0:Y=X:Z=-2.4
     k=Sqr(X*X+Z*Z)-2
     d=1-Sqr(k*k+Y*Y)
     X=X+x1*d:Y=Y+y1*d:Z=Z+d
   Loop Until d<.005
   v1=Atn(Z/X):u1=Atn(Y/k)
   sColor(): Pixel U,V
   v1=3.13-v1
 Next
Next
Sub sColor()
 Color Map(c)
End Sub
'Dim integer cm(15)=(0,15,7,1,0,0,0,0,0,0,0,0,0,0,0,0)
 T=cm(0)
 For i=0 To 14:cm(i)=cm(i+1):Next
 cm(15)=T
 For i=0 To 15:Map(i)=cm(i):Next
 Map Set
 Pause 50
     Page 5 of 12
