Forum Index : Microcontroller and PC projects : MMB for DOS pause problem
| DaveJacko Senior Member Joined: 25/07/2019 Location: United KingdomPosts: 103 |
If anyone has nothing important to do, can they confirm that.. in MMBasic for DOS pauseplus 1000 end sub pauseplus(ptim) for i=1 to ptim pause 1 'do some code next i end sub seems to delay for > 10 seconds. Pause 1000 is 1 second I hope It's me doing something stupid, workarounds welcome! Try swapping 2 and 3 over |
| twofingers Guru Joined: 02/06/2014 Location: GermanyPosts: 1752 |
AFAIK your observation is correct. I got 15600ms! This is really unexpected and weird. Regards Michael causality ≠ correlation ≠ coincidence |
MMBasic for DOS uses the DOS timer which goes in ~16mS steps so pause delays will be 16,32 etc mS Try this with different PAUSE times ' startedx = TIMER pauseplus 100 PRINT TIMER - startedx END SUB pauseplus(ptim) FOR i=1 TO ptim started = TIMER PAUSE 20 PRINT TIMER - started 'do some code NEXT i END SUB MMB4W uses a high definition timer so doesn't have the same problem. The strange 16mS came about because the default screen refresh in Microsoft land is 60Hz Jim Edited 2024-09-23 07:32 by TassyJim VK7JH MMedit |
Instead of "PAUSE", use an empty loop with a duration of 1 ms. sub pauseplus(ptim) for i=1 to ptim for j=1 to 3050 next j 'do some code next end sub Works for me. Edited 2024-09-23 08:17 by twofingers causality ≠ correlation ≠ coincidence |
| phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3289 |
Perhaps:- Pause 1000 / 16 'or T = Timer + 1000 : Do While Timer < T : Loop Not tested but I expect the resolution will still only be 16mS. Edited 2024-09-23 08:09 by phil99 |
How about this: timer=0 pauseplus 1000 ? timer end sub pauseplus(ptim) for i=1 to ptim do while timer<ptim:loop 'do some code next end sub Michael causality ≠ correlation ≠ coincidence |
you may get better mileage out of this: n=timer+1000 do while timer<n print "doing stuff... "; loop the above will fall through after spinning in a loop for 1000mS 'doing stuff'. place the loop inside another loop, and then you can also do the things you only want done once a second: n=timer+1000 do print "doing things at the start of the interval" do while timer<n print "doing stuff... "; loop print timer n=n+1000 loop depending upon how timer is implemented on the win32 console port of mmbasic, it may only be incremented (approximately) 18.2 times per second. this was (way back when) derived from a crystal oscillator running at 4x the NTSC colorburst frequency of 3.579545MHz: 3.579545MHz * 4 = 14.31818MHz 14.31818MHz / 3 / (2^18) = 18.2065074Hz (tick rate) with the processor clock for the original 8088 based IBM PC and IBM XT being: 14.31818MHz / 3 = 4.772727MHz since then various other periodic counters have been added to the PC's hardware, and to varying degrees used by windows, but as to which one is actually used in a specific case is not always certain! cheers, rob :-) Edited 2024-09-23 23:15 by robert.rozee |
Thanks all ! especially Rob for the background info and work-around. This will help me develop my RS232 graphics terminal for the LCD Backpack, featuring swipe left, right and tap. Dave ![]() Try swapping 2 and 3 over |
| PhenixRising Guru Joined: 07/11/2023 Location: United KingdomPosts: 1954 |
Bit of a long-shot but who knows. My DOS programs reprogram the clock interrupt (and compensate to preserve time-keeping). This example is 8 X normal speed but I've had it interrupting @ (not sure) 5 or 8KHz. This was created for QuickBasic/MS PDS 7.1 Title INT.ASM Interrupt Control Programs ;Revision History ;Rev 001 ;Rev 002 ; Call to PDPress added 1/11/94 ;Rev 003 ; Call to PumpTimer added 6/15/94 ;Rev 004 ; Call to DeadMan added 4/5/95 ;Rev 005 ; Call to IntTimer added 1/6/95 option segment:use16 .386 .dosseg .model medium,basic public flgoff public flgseg public inpoff public inpseg public optoff public optseg public outoff public outseg .data inpseg dw 0 ;inputs array inpoff dw 0 outseg dw 0 ;outputs array outoff dw 0 flgseg dw 0 ;flags array flgoff dw 0 optoff dw 0 ;options array optseg dw 0 .code extrn ButtonHandler:proc extrn DMCInt:proc extrn DeadMan:proc extrn inhand:proc extrn IntTimer:proc extrn MandStop:proc extrn PDPress:proc extrn ophand:proc extrn PumpTimer:proc extrn ScreenTimer:proc getw MACRO to,from ;get a parameter and save it mov bx,from mov ax,[bx] mov word ptr to,ax ENDM install proc inps:ptr word, ino:ptr word, \ ops:ptr word, opo:ptr word, \ fls:ptr word, flo:ptr word, \ opts:ptr word, opto:ptr word pusha ;save registers push ds push es mov ax,@data ;set data seg mov ds,ax ;save passed parameters for interrupt handler use getw inpseg,inps ;get inputs segment getw inpoff,ino ;get inputs offset getw outseg,ops ;get outputs segment getw outoff,opo ;get outputs offset getw flgseg,fls ;get flags segment getw flgoff,flo ;get flags offset getw optseg,opts ;get options segment getw optoff,opto ;get options segment mov ax,3508h ;get current interrupt vector int 21h mov word ptr cs:oldvec,bx ;save segment mov word ptr cs:oldvec+2,es ;save segment cli ;stop interrupt mov al,36h ;reprogram timer to 8 times out 43h,al ;normal speed mov al,0 jmp @F @@: jmp @F @@: out 40h,al ; mov al,20h MOV al,4 jmp @F @@: jmp @F @@: out 40h,al push cs ;change interrupt vector pop ds lea dx, newint mov ax,2508h int 21h sti ;restart interrupt pop es ;restore pop ds popa ret install endp uninst proc pusha push ds push es push si push di cli ;stop interrupts mov al,36h ;timer back to normal out 43h,al ;alert for coming values jmp @F @@: jmp @F @@: mov al,00h out 40h,al ;lsb jmp @F @@: jmp @F @@: out 40h,al ;msb lds dx,cs:oldvec ;restore old interrupt mov ax,2508h int 21h sti ;enable interrupts pop di pop si pop es ;restore registers pop ds popa ret uninst endp newint proc near pusha ;save registers push ds push es push si push di call IntTimer ;cpu independant interrupt timer call DeadMan ;deadman relay driver call inhand ;update inputs call ButtonHandler ;Pb interlock handler call MandStop ;stop mandrel on switch call PDPress ;Pressure die pressure handler call DMCInt ;DMC comms call ophand ;update outputs ; allow for speeded up clock dec cs:counter ;count down jns exit ;not time yet ; this section runs every eigth interrupt mov cs:counter,63 ;restart timer dec cs:SecTimer ;update seconds counter jns @F mov cs:sectimer,18 ;restart seconds timer call ScreenTimer ;do this once per second call PumpTimer @@: pop di pop si pop es ;restore registers pop ds popa jmp cs:oldvec ;to normal clock interrupt exit: mov al,20h ;issue an EOI out 20h,al pop di pop si pop es ;restore registers pop ds popa iret ;return from interrupt oldvec dd 0 counter dw 0 SecTimer dw 18 ;one second(approx) timer newint endp end Lots of surplus stuff there, obviously. Edited 2024-09-25 15:59 by PhenixRising |
