Local Time 17:14 19 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMEdit question
MarkF
Posted: 03:06am 26 Sep 2024
Hi. I am using MMEdit version 5.
https://www.c-com.com.au/MMedit.htm
I have set the Syntax > picomiteVGA
When I add code below, the PRINT command works in the DOS box, but not PIXEL. Does MMEdit support graphics commands?
PRINT "Test"
Pixel 10,10
i.e. Use "Run in DOS" cog button in MMEdit
Posted: 03:12am 26 Sep 2024
MMEdit is an editor, not a simulator/emulator.
The original MMBasic for DOS does not support graphic commands.
If you want to run your code on the PC, try MMBasic for Windows (MMB4W) and graphics commands will work.
MarkF
Posted: 04:04am 26 Sep 2024
Thanks Jim for clearing that up. Appreciated.
Link to MMB4W: https://github.com/UKTailwind/MMB4W
Edited 2024-09-26 14:07 by MarkF
