Forum Index : Microcontroller and PC projects : PicoMite Version functionality matrix
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12252 |
CapabilityMatrix.zip Attached is an excel file showing for each version of the PicoMite firmware every command, function, option, and mm.info capability which is relevant (as at V6.00.00RC8). This will be used by Geoff and myself as the basis for getting to grips with writing the manual(s) for V6.00.00 but may be useful for users in the meantime. Edited 2024-10-13 04:59 by matherp |
what's it mean for joe user? |
TassyJim![]() Guru Joined: 07/08/2011 Location: AustraliaPosts: 6642 |
Thanks for that Peter. Now I just have to find the time to update MMEdit syntax files to match. Jim VK7JH MMedit |
| Malibu Senior Member Joined: 07/07/2018 Location: AustraliaPosts: 261 |
Thanks Peter, looks like a handy table... I just noticed there's an "mm.info(systick)" What's that indicating? (I hadn't seen it before, and nothing in the manual) John |
It's a 24-bit counter that counts at CPUSPEED. Really there for my testing but can be used for very short interval timing as long as you deal with the 24-bit roll-over |
| javavi Guru Joined: 01/10/2023 Location: UkrainePosts: 642 |
Your table does not indicate with a plus sign the change in the flags (2nd bit) of the Sort command |
