Local Time 04:57 06 Jul 2025 Privacy Policy
Forum Index : Microcontroller and PC projects : Front panel designer
toml_12953
Posted: 10:36am 27 Oct 2024
  Mixtel90 said  Of particular interest if you are in Germany, Canada or the USofA. It might get expensive if you get them to make a panel.
I use the software to design a panel, then I print it and use that as a guide for drilling holes in my own sheet aluminum (aluminium?) After I drill, I paint the panel and apply dry letter transfers. It looks very professional. The software makes it easy to align and correctly space rows of holes.
Front Panel.pdf
Edited 2024-10-27 20:40 by toml_12953
Posted: 11:22am 27 Oct 2024
Ah, I use SL6 for PCB panels or nanoCAD 5.0 (the free version) for other mechanical stuff. That's because it's similar to an early AutoCAD version that I used for many years.
Posted: 08:12am 16 Dec 2024
All,
Used this software to design a new front panel and rear panel for a 40 year old power supply. Works very nice. I laser printed the test printout, and made it more robust using a plastic foil. Glued on the power supply. Nice...(*)
(8) I even thought for a moment to simply order them online from Schaffner, at a price of 40 eur per (for 3mm thick milled anodized alu, with countersunk screw holes), that was the most professional solution. I still may, but for now I am fine.
Edited 2024-12-16 18:21 by Volhout
© JAQ Software 2025
