Local Time 18:13 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMEdit problem
palcal
Posted: 01:27am 21 Oct 2024
I have a program I am trying to load into a Picomite. I have done this many times before and am familiar with all the settings.
In MMCC I connect to the Picomite OK, in MMedit I open the program I want to transfer and hit deploy, sometimes nothing happens and sometimes it says it has loaded and all OK but when I look in the Picomite there is nothing there.
I have switched everything off and started over and even used another computer to no avail. I can load the program to a different Picomite its just this one giving trouble. There are programs in 3 of the other flash slots, should I remove them. Maybe no room left, but they are only about 200 lines each. The device is obviously OK as programs in the flash slots run OK.
Edited 2024-10-21 11:56 by palcal
Posted: 02:03am 21 Oct 2024
Is the pico having problems using the same MMBasic version?
In MMCC make sure you see the command prompt >
enter NEW
How big is the program you re trying to load?
Can you load a short test program?
palcal
Posted: 02:39am 21 Oct 2024
The Pico giving trouble has programs in Flash slots 1,2 and 3. Each program is about 200 lines and runs OK. The program I am trying to load is about the same size it is simply another version of the other 3.
palcal
Posted: 03:11am 21 Oct 2024
OK all good. I modified my weather station to use the AHT10 instead of the HTU21D.
I added an underscore AHT10 to the file name to differentiate it from the previos file. Somehow it was being saved with an AHT10 file extension.
