Forum Index : Microcontroller and PC projects : Why pay for a scoppy?
Specially for Harm Coming in RC10 I've unlocked the ADC speed and it can now sample up to CPU speed/96 So in the example below on a RP2040 I'm running the CPU at 378MHz and sampling two channels each at 1.96775 MHz to give a total sample rate of over 3.9MHz https://youtu.be/7w7MKo9nofo ![]() CLS FRAMEBUFFER create FRAMEBUFFER write f Dim float a(1279),b(1279),aa(639),bb(639),c(639),d(639),e(639) ADC open 1968750,2,done For i=0 To 639:e(i)=i:Next Do ADC start a(),b() Do Loop Until f%=1 f%=0 p%=Math(crossing a(),1.5,-1) Memory copy float Peek(varaddr a(p%)),Peek(varaddr aa(0)),640 Memory copy float Peek(varaddr b(p%)),Peek(varaddr bb(0)),640 Math scale aa(),50,aa() Math scale bb(),50,bb() Math add aa(),50,aa() Math add bb(),250,bb() Line graph e(),c(),0 Line graph e(),d(),0 Line graph e(),aa(),RGB(green) Line graph e(),bb(),RGB(cyan) FRAMEBUFFER copy f,n Math scale aa(),1,c() Math scale bb(),1,d() Loop Sub done f%=1 End Sub |
Hi Peter, Looking at the saw-tooth waveform it looks like the ADC silicon problem amplifies when you sample faster. Thanks for providing the option. About Scoppy. You could build a system with an additional build in Pico-W (if you can spare the extra 100mA) that is always available. For diagnosis you would only bring your phone to the site, and connect to the pico-w and diagnose. Even if the system is on top of a mast. Sounds like a solution for some projects. Maybe it is not if you think about it deeper. IS this a solution looking for a problem..? Maybe.. Volhout PicomiteVGA PETSCII ROBOTS |
| PhenixRising Guru Joined: 07/11/2023 Location: United KingdomPosts: 1960 |
Outstanding |
| Pluto Guru Joined: 09/06/2017 Location: FinlandPosts: 411 |
Hi Peter, I tried the Scoppy app, and it works really decent. You cannot compare it to a genuine oscilloscope, but for diagnose it is perfect. The default is still 500kHz, but you can configure it different. The Pico-W has a build in (square wave) generator, and 8 channel logic analyzer as well. All in all a decent tool, waiting for some analog interfaces. I gladly payed the 3 euro's (one time fee) to get the full functionality. Volhout Edited 2024-10-26 05:47 by Volhout PicomiteVGA PETSCII ROBOTS |
@Volhout Thanks, Harm. I'm excited about this |
