Local Time 18:21 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: INPUT after INKEY$ problem
andreas
Posted: 07:37am 12 Dec 2024
I'm using the CMM2 Firmware Version 5.0702. I have a code to select an item from a menu:
Function menu(items$)
' ask user
   k$ = Inkey$
   Select Case k$
   Case String$(1,128) ' Up
   End Select
 Loop Until Asc(k$) = 13 ' Return
 ' restore screen & return value
 menu = sel ' return value = user selection
 font aktfont
 input dummy$  '(!)
End Function
This code uses the Inkey$ function to get a value k$ from keyboard. After processing my "menu-function" returns the selection to the main program.
The problem is that if an INPUT statement in the main program follows this menu-function the main program is not stopping to get the INPUT value. It is as if something else has put in the value into the INPUT variable.
My solution to this problem is that I add a dummy-INPUT-statement within the menu-Function as last statement. See (!) - the funny thing is, that this "input dummy$" will not stop and aks for a value but continue to the end of the function and return to the calling main program. The ASC(dummy$) is 0.
Now my question: Is it a bug or a feature?
-andreas
Posted: 08:49am 12 Dec 2024
to flush the input buffer
DO : LOOP UNTIL INKEY$ = ""
andreas
Posted: 10:56am 12 Dec 2024
  TassyJim said  to flush the input buffer
Thank you Jim!
The menu(Items$) function lives in an .inc file for a long time without any issues. Now I write a new program, use the good old menu.inc and discover that the INPUT is not working as expected.
I didn't relate inkey$ function and input command to a common buffer.
-andreas
