Forum Index : Microcontroller and PC projects : MMBasic SetTick vs INPUT
| Mark Regular Member Joined: 26/11/2022 Location: United StatesPosts: 99 |
It appears that during the MMBasic INPUT processing, SetTick interrupts are disabled (or at least they aren't working for me ).I wrote a program that on a SetTick interrupt updates a time display at the bottom right of the screen, but while in the INPUT routine, the time isn't being updated. Mark |
From the manual page 47 Interrupts VK7JH MMedit |
Thanks. I suspect that the INPUT command lasts until the user hits ENTER so it certainly will miss interrupts. I have my updated timer sort of working using INKEY$. The problem is getting an underscore cursor to display. Mark |
Cheat! Blank it during input. :) Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
| twofingers Guru Joined: 02/06/2014 Location: GermanyPosts: 1752 |
Why don't you write your own function for this? Similar to this. Kind regards Michael causality ≠ correlation ≠ coincidence |
