Forum Index : Microcontroller and PC projects : pimeroni board
| hhtg1968 Senior Member Joined: 25/05/2023 Location: GermanyPosts: 204 |
yesterday i found a so called pimeroni board with vga, sd, ps/2 and audio. is it possible to use it with mmbasic? Pimeroni VGA Board |
| Martin H. Guru Joined: 04/06/2022 Location: GermanyPosts: 1459 |
Picomite VGA does not support its 15-bit analog video, so no, i don't think so 'no comment |
Nope. Not MMBasic compatible. Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
yes, the vga solution is not the same. thank you for the answer. |
