Local Time 15:44 07 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : At last - a proper use for a control system.
PeteCotton
Posted: 09:11pm 07 Jan 2025
Cool model harrier doing VTOL. On his other videos he shows that he's using a P&ID to stabilise it.
https://www.youtube.com/watch?v=t66QM0X26h8
Edited 2025-01-08 07:11 by PeteCotton
PhenixRising
Posted: 10:13pm 07 Jan 2025
Incredible.... I'll be watching this, over and over
PhenixRising
Posted: 07:59am 08 Jan 2025
Can't find it now but there was a video about drone development and I was quite surprised that they did fine with a 250Hz PID loop-rate. Naturally, as processors got faster, they went beyond 1KHz but sometimes, faster is not always better. PID needs error to function at all and if one is not careful, this could lead to instability.
I am running 1KHz on the PicoMite, only because it is the most common for CNC control but it's overkill in many cases.
Posted: 08:08am 08 Jan 2025
They are using a drone flight controller to stabilize the plane. The complexity is that this plane seems to have a single (or dual) ducted fan, and in stead of controlling individual motors, they control servo controlled air flow.
The essence for this was already implemented in arduino (read: arduplane). The tuning is the difficult part (as is building the plane light enough for this application, since ducted fans generate high speed air flow, but not a lot of thrust).
The real difficult part will be the transition from VTOL to normal flight. The air flow directors rotate, and in the control algorithm Z becomes X direction for thrust, but the sensors do not rotate. So there is a control algorithm needed that can rotate output functions. That is typically not implemented in the flight controller plaforms.
Edited 2025-01-08 18:11 by Volhout
Posted: 08:54am 08 Jan 2025
That's a lovely model!
Believe me, you can't beat the racket from a Harrier! Rather noticeable when you are working in buildings at Warton aerodrome. :) While I was there they wouldn't let them use VTOL because it melts the tarmac in that area.
PhenixRising
Posted: 09:15am 08 Jan 2025
  Mixtel90 said  That's a lovely model!
Back in the 90's I was at a meeting with McDonnell Douglas and there just happened to be some airshow or something going on and my host took me to watch. The American AV-8B Harrier came hovering over the Mississippi, under the bridge, stopped and turned to left, bowed to the crowd and did the same to the crowd on the right. Then it pointed upwards and shot away.
Some random guy shouted "America baby!" I shouted back "British development, actually"
Posted: 10:14am 08 Jan 2025
At Warton and Samlesbury they have English Electric Lightnings (just the shells, I think) on display stands. Apparently they were very popular with the pilots and were, effectively, just a pilot sitting on a pair of turbo-jet engines. Many pilots got told off for just pointing the nose up and letting it rip. The rate of climb was phenomenal. :)
PhenixRising
Posted: 10:19am 08 Jan 2025
  Mixtel90 said  At Warton and Samlesbury they have English Electric Lightnings (just the shells, I think) on display stands. Apparently they were very popular with the pilots and were, effectively, just a pilot sitting on a pair of turbo-jet engines. Many pilots got told off for just pointing the nose up and letting it rip. The rate of climb was phenomenal. :)
I'd take a slap on the wrist, any day, well, every day just to do that. Always loved the Lightnings
PeteCotton
Posted: 04:07pm 08 Jan 2025
  Volhout said  They are using a drone flight controller to stabilize the plane. The complexity is that this plane seems to have a single (or dual) ducted fan, and in stead of controlling individual motors, they control servo controlled air flow.
I noticed that as well. On the real Harrier they vent air from the engine out to the wing tips and tail so that they can balance/turn the plane without needing airflow over the wings. If you look closely at the model - it looks like he has small propellers/fans in the wingtips to achieve this balance (with the four vector thrusters providing lift).
  Volhout said  The real difficult part will be the transition from VTOL to normal flight.
Yes - I haven't seen that happen yet. I suspect it's going to be very tricky. Not least because you're going to need to have sufficient airflow over the wings to create lift before you lose the upwards thrust. Maybe he has to go to a much higher altitude to transition so that he has a few seconds leeway in which the model can drop a bit.
PeteCotton
Posted: 04:14pm 08 Jan 2025
I probably should mention that one of my brothers collects planes, and he has a lovely lightning and harrier. They look amazing.
Edited 2025-01-09 02:14 by PeteCotton
PhenixRising
Posted: 04:17pm 08 Jan 2025
Harm and Pete:
What about his F35? It's doing VTOL and full flight(?)
PeteCotton
Posted: 04:48pm 08 Jan 2025
  PhenixRising said  Harm and Pete:
The F35 has two separate power plants. A lift one (mounted vertically behind the pilot) and a thrust one at the rear of the plane. Both can be running at the same time during the transition (from vertical to horizontal flight).
The harrier has four thrust vectors which must turn at the same time from downwards pointing to rear pointing. He could get the same effect (as the F35) by controlling the front pair and rear pair separately - but that would be cheating. I suspect there's a 45 degree angle or something that would give him the required thrust - but that might pitch the nose down (depending on how it's balanced). It's a tricky one for sure.
Edited 2025-01-09 04:38 by PeteCotton
Posted: 08:39am 12 Jan 2025
For anyone who doesn't know about the English Electric Lightning have a look at this
I stopped flying as a hobby a few years ago. Before that I built and flew a Vans RV9A aircraft
Shown here at the LAA rally (like a smaller Oshkosh).
The reason to raise this is that In the UK newly built aircraft have to be flight tested by a qualified test pilot. My test pilot for G-OPVM was a retired Lightning pilot
Posted: 09:25am 12 Jan 2025
Thanks Peter. There's some interesting stuff about the Lightning in there. I didn't know that they even stored fuel in the flaps!
G-OPVM looks really nice. :)  Flying has become a very expensive hobby now, I'm told. One of my friends sold his aircraft some time ago, but kept going with a hang glider for a short while after! Now downgraded to a kayak. lol
PeteCotton
Posted: 08:05pm 12 Jan 2025
One of my favourite stories about the Lightning.
https://en.wikipedia.org/wiki/Holden%27s_Lightning_flight
They are surprisingly large. But one of my absolute favourite aircraft. Up until recently you could book a flight on one in South Africa, but I think they eventually got grounded after a fatal crash. We looked into the legalities of flying one in Canada, but it was an absolute no-go. Apparently there's no redundancies on board for a lot of systems and the hydraulics are famous for double failures (I also suspect the fact that having a civvy plane that can do Mach 2+ makes them a bit uncomfortable) - so, sadly, I don't think any country will ever authorise them to fly ever again.
If you're wondering how you get flights in a single seater fighter, the South Africans were using the T5 which was the two seater trainer version.
https://www.youtube.com/watch?v=5hLvufAknW8
Edited 2025-01-13 06:48 by PeteCotton
Posted: 08:59pm 12 Jan 2025
Thanks Pete :)
Posted: 08:10am 13 Jan 2025
Hah,
I once built and flew an RV9 model airplane. But the real thing is quite a different story. Envy you Peter...
PeteCotton
Posted: 04:20am 14 Jan 2025
  Volhout said  Hah,
Well, if you ever find yourself in Western Canada, drop me a line and we'll go pay a visit to the Harrier. I'll even buy the drinks
He has it parked on the patio of his pub. We have some cool ideas as to what we can do with some simple PLCs and noise/smoke/lights for the summer time.
PhenixRising
Posted: 06:53am 14 Jan 2025
PLCs ??? Heck no. Mites are FAR superior
PeteCotton
Posted: 03:15pm 14 Jan 2025
  PhenixRising said  PLCs ??? Heck no. Mites are FAR superior
While I do agree, ... we have a surplus of out of date PLCs lying around that we will never use on a "real" project. Mites would be wasted on this - going to keep them for fun projects!
