Forum Index : Microcontroller and PC projects : PicoMite V6.00.02 betas
| mozzie Guru Joined: 15/06/2020 Location: AustraliaPosts: 409 |
Thanks Peter, Using 05.08.00 and the Onewire routines for testing so all is good Regards, Lyle. |
OPTION SDCARD GP13, GP10, GP11, GP12 reset usb vga and same sdcard pins but forgot order and sdcard is soldered so dunno what pin is what but works b: files |
> option list PicoMiteVGA MMBasic USB RP2350A Edition V6.00.02b8 OPTION SERIAL CONSOLE COM2,GP8,GP9 OPTION FLASH SIZE 4194304 OPTION COLOURCODE ON OPTION KEYBOARD UK, 0, 0, 600, 150 OPTION CPUSPEED (KHz) 378000 OPTION SDCARD GP13, GP10, GP11, GP12 OPTION AUDIO GP0,GP1', ON PWM CHANNEL 0 > b: > files B:/ 23:15 07-09-2015 5920096 03 - Heroes.mp3 21:36 03-10-2024 65256506 03 - Heroes.wav 19:05 28-07-2020 8802830 adele,tupac,eminem.mp3 21:37 03-10-2024 67081508 adele,tupac,eminem.wav 17:38 28-07-2020 8444268 Biggie,Adele,Tupac.mp3 21:38 03-10-2024 65642084 Biggie,Adele,Tupac.wav 22:16 28-07-2020 5338459 biggie.johnny cash.mp3 21:35 03-10-2024 39577644 biggie.johnny cash.wav 01:11 01-01-2000 0 bootcount 16:48 30-08-2024 44556 sfx-bg.mod 20:35 20-03-2020 49501189 THENOT~1.MP3 21:40 03-10-2024 363818330 THENOT~1.WAV 00:51 31-08-2015 5358571 Track 1 (7).mp3 21:40 03-10-2024 39382504 Track 1 (7).wav 18:49 28-07-2020 7598885 tupac,eminem.mp3 21:41 03-10-2024 54718580 tupac,eminem.wav 0 directories, 16 files > motto is keep a text copy of your option files ![]() Edited 2025-02-09 07:25 by stanleyella |
| JanVolk Guru Joined: 28/01/2023 Location: NetherlandsPosts: 401 |
Test PicoMite MMBasic RP2040 Edition V6.00.02b9 with I2S Excellent sound with PCM5102A I2S DAC and Multi-point Bluetooth Transmitter and headphones. Only playing .mp3 files does not work. Test up GP28 and GP5. [4] Play mp3 "B:/mp3/jazz-intro-251968.mp3" Error : Only available with VS1053 audio Greetings, Jan > option list PicoMite MMBasic RP2040 Edition V6.00.02b9 OPTION SYSTEM SPI GP10,GP11,GP24 OPTION FLASH SIZE 4194304 OPTION COLOURCODE ON OPTION HEARTBEAT OFF OPTION PICO OFF OPTION CPUSPEED 252000 'KHz OPTION DISPLAY 43, 89 OPTION LCDPANEL ST7789_135, RLANDSCAPE,GP8,GP12,GP9,GP25 OPTION SDCARD GP23, GP18, GP19, GP20 OPTION AUDIO I2S GP2,GP28', ON PWM CHANNEL 1 OPTION PLATFORM RP2040-GEEK > list pins GP0 1 OFF GP1 2 OFF GP2 4 Boot Reserved : I2S BCLK GP3 5 Boot Reserved : I2S LRCK GP4 6 OFF GP5 7 OFF GP6 9 OFF GP7 10 OFF GP8 11 Boot Reserved : LCD DC GP9 12 Boot Reserved : LCD CS GP10 14 Boot Reserved : SPI SYSTEM CLK GP11 15 Boot Reserved : SPI SYSTEM MOSI GP12 16 Boot Reserved : LCD Reset GP13 17 OFF GP14 19 OFF GP15 20 OFF GP16 21 OFF GP17 22 OFF GP18 24 Boot Reserved : SD CLK GP19 25 Boot Reserved : SD MOSI GP20 26 Boot Reserved : SD MISO GP21 27 OFF GP22 29 OFF GP23 41 Boot Reserved : SD CS GP24 42 Boot Reserved : SPI SYSTEM MISO GP25 43 Boot Reserved : LCD BACKLIGHT GP26 31 OFF GP27 32 OFF GP28 34 Boot Reserved : I2S DATA GP29 44 OFF > memory Program: 1K ( 1%) Program (7 lines) 127K (99%) Free Saved Variables: 16K (100%) Free RAM: 0K ( 0%) 0 Variables 0K ( 0%) General 156K (100%) Free > run [4] Play mp3 "B:/mp3/jazz-intro-251968.mp3" Error : Only available with VS1053 audio > list Play volume 40,40 'Play tone 200, 200 'Play wav "B:/wav/tet16cut.wav" Play mp3 "B:/mp3/jazz-intro-251968.mp3" 'Play sound 1, B, S, 1000, 5 Pause 60000 End > |
| dddns Guru Joined: 20/09/2024 Location: GermanyPosts: 893 |
Hello, I got some issues with the latest beta on a RP2040USB: when executing "backlight 50,default" it works for the moment but after a restart the only output is: "Error : Syntax" and then locks up. I can then only help myself by clearing the flash and start all over. My RTC DS3231 works for the moment and after a restart it is resetted to default. The battery is fine and it happens as well after a "cpu restart" without power cycling. I got a keyboard attached. In this version it says "unknown device detected....." followed by a column of hex addresses. This is not nice but might be due to the beta.. |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11733 |
Correct: RP2040 doesn't have enough memory or CPU to decode MP3 |
Peter, Thank you for the quick response. I already had a suspicion and was correct. Greetings, Jan |
I think I found another bug, (PicoMite VGA with PS/2 mouse and PS/2 keyboard) RP2350A V6.00.02b8 OPTION MOUSE GP27,GP28 I REALLY like and use the PS/2 mouse feature in the editor, but if any program executes in MODE 3 and I EDIT again, the mouse function is dead. If I change to MODE 1 or MODE 2 it works again. Not related to a specific program, but it is a bit annoying to manually type "mode 1 or mode 2" after my executed program runs in mode 3... So just minor bug (if so).... P.S.: Only thing I am missing in the editor is scrolling one step down / up via mouse scrollwheel But maybe there is a reason why this isn't implemented. Greetings Daniel Edited 2025-02-09 09:13 by Amnesie |
No - this is a limitation. The mouse only works in the editor in mode 1. This is because it uses the tile mechanism do do the highlighting. If you are in mode 2 the editor automatically switches to mode 1 during the edit hence that also works. Please provide more info - full list of options |
Is there a technical reason why regardless of current mode, the Editor can’t always switch to Mode 1? Then rather than a limitation, the user will always have the mouse functionality. |
Yep! This is what I was asking / want to know. |
| electricat Senior Member Joined: 30/11/2020 Location: LithuaniaPosts: 299 |
Lastest beta I used with my HDMI/USBR/P2350 was 02b4 Now tried 02b9 and get this https://youtube.com/shorts/HG7AB6jSCKU?feature=share flash clear/upload/cable change, connect keyboard directly (not using hub) does not change this behaviour. Returning to 02b4 and all works again. My MMBasic 'sand box' |
@Peter Used ‘LIST PINS’ for the first time just now - very useful indeed Just asking: would it be trivial to add a ‘PRESS ANY KEY …’ prompt as currently it scrolls up so you can’t then see the start of the list (I.e. in the same way that you currently prompt when using LIST for a ‘long’ program when it reaches the bottom of the screen. ALSO seen again a small cosmetic-bug with a font size change (font gets bigger at the command prompt) after LIBRARY SAVE (b8 HDMI) |
V6.00.02b10 now available https://geoffg.net/Downloads/picomite/PicoMite_Beta.zip Removes diagnostic print in USB connect Fixes bug in LINE PLOT Changes initialisation of HDMI pins For VGA version the I2S PIO now shares with the VGA PIO (PIO0) so PIO 1 is available for use in MMBasic |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6023 |
Peter, Thanks, I love PIO Volhout PicomiteVGA PETSCII ROBOTS |
@Peter, In B10, what mA did you set the HDMI pins? |
It happens with a fresh install of PicoMiteRP2040USBV6.00.02b10 and then setting the option "option lcdpanel ssd1963_7,l,,gp16,noreset". A "backlight 50" will work but setting it as default causes "Error : Syntax" at the next reboot or "cpu restart". Many thanks for fixing the issue with the RTC which works as expected with this version. The diagnostic dump has gone but it still says "Unknown Device Connected on channel 3 (pid=&H2, vid=&H1C4F)" which it does not with the stable. |
This is deliberate. It is an information message to indicate that there is no specific handling for that device in the firmware Thanks. needed the info about SSD1963 to allow me to find it. Will be fixed in next beta. In the meantime don't use the default option with a SSD1963. Should work with other types of display. Does it work or not? |
Happy to report back that all three modes work on all screens here. The RPi monitor at 640 needs to be set with OPTION RESOLUTION 640,252000 (i.e 60Hz as opposed to 75Hz). Did notice that with a 2m HDMI lead then I could introduce 'jitter' by touching the HDMI pins on the DVI sock which is soldered directly to the Pico (not that I would be doing this - just checking to see if it was possible to see jitter). This jitter showed as columns of blue pixels on the left-hand side of screen. By moving my finger, I could extended the pixel-columns further towards the right. However, by using a 30cm HDMI lead, there is zero jitter So yes - it does work. Big THANKS to you & Lyle for getting to the bottom of this niggle........ |
@peter HDMI/USB/RP2350 --> 02b10 Default options, except SD card added OPTION RESOLUTION 1024 Run this Pause 500 CLS For a=0 To 30 Print "aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa" Next a Do Loop Until KeyDown(0) <>0 Picture is not stable (its something like scanline starts to appear periodicaly) on entering do - loop. Take a look https://youtube.com/shorts/gKkV0EPsqH0?feature=share Do Loop Until KeyDown(0) <>0 Tried OPTION RESOLUTION 1024 with both 60 and 75 Khz req seting - same prob My MMBasic 'sand box' |
