Local Time 04:07 13 Aug 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Picomite issues with MCP3002, dual channel ADC SPI
apalert
Posted: 03:06am 31 Jan 2025
Have connection but data returned is rubbish. Any tips or clues gladly appreciated.
My code below is modified from Appendix D in Picomite User Manual
OPTION BASE 1                   ' array will start with the index 1
DIM data%(2)                    'array for receiving channel 1 data
dim data2%(2)                   'array for receiving channel 2 data
SETPIN GP8, GP15, GP14, SPI2    ' assign the I/O pins, RX, TX, CLK
PIN(27) = 1 : SETPIN 27, DOUT   'pin 27 ADC chip enable active low
SPI2 OPEN 5000000, 1, 8         ' speed is 5MHz, 8 bits data
PIN(27) = 0                     ' assert the enable line (active low)
SPI2 WRITE 2, 104, 0             ' initialise ADC channel 0
SPI2 READ 2, data%()            ' get two bytes from ADC
SPI2 WRITE 2, 120, 0              ' initialise ADC, channel 1
SPI2 READ 2, data2%()            ' get two bytes from the slave
PIN(27) = 1                      ' deselect the slave
SPI2 CLOSE                       ' and close the channel
'output to console
? bin$(data%(1)), bin$(data%(2)), bin$(data2%(1)), bin$(data2%(2))
jwettroth
Posted: 05:17am 31 Jan 2025
The part supports SPI at 3.2 at 5v and 1.2 at 3.3.  Change you speed to something reasonable- 1 Mhz?
John Wettroth
apalert
Posted: 05:58am 31 Jan 2025
  jwettroth said  The part supports SPI at 3.2 at 5v and 1.2 at 3.3.  Change you speed to something reasonable- 1 Mhz?
Good point, tried a range of speeds all the way down to 100kHz. No joy.
Posted: 06:03am 31 Jan 2025
First things I would try
- change SPI to mode 0 ( the most common mode)
- wait between SPI write and SPI read, to give the adc time to perform its conversion
Posted: 06:13am 31 Jan 2025
Another short Pause between Enable and Write may also be needed if the chip sleeps when idle.
Posted: 06:48am 31 Jan 2025
I think you need to send the channel setup data and receive the results in one command.
Use 16 bits not 8
SPI2 OPEN 1000000, 0, 16
Ch0data = SPI2(Ch0config)
Ch1data = SPI2(Ch1config)
I don't have a chip to test with.
Edited 2025-01-31 16:48 by TassyJim
Posted: 08:17am 31 Jan 2025
So summary:
- do not use a clock higher that 1MHz (the chip does 2 MHz max at 3.3V)
- use 16 bit transfers (or 2x8 bit transfers as below)
- you need to mask the read ADC value, since the MSB's are determined by pullup or pulldown.
- you need to use SPI mode 0 (called "0.0" in the datasheet). in essence this chip understands SPI mode 0 and 3, but not 1 and 2.
- you need to receive data while sending. use the function
value = SPI2( data )
 Do not use commands SPI WRITE and SPI READ, since these do not operate at the same time.
as TassyJim said: SPI2 OPEN 1000000,0,16
Edited 2025-01-31 18:24 by Volhout
apalert
Posted: 06:45am 01 Feb 2025
Many thanks for all suggestions, new version of code below. Hours have been spent tweaking. New ADC chip tried, wiring triple checked. Unfortunately output is still garbage :(
Below the code is a table of data returned. I put the code in a For x= 1 to 40 loop and ran it multiple times with 1/2VDD, VDD and VSS test voltage inputs. There is a curious pattern to the garbage!
SETPIN 27, DOUT                 ' pin 27 ADC chip enable active low
PIN(27) = 1                     ' ADC chip disabled
SETPIN 11, 20, 19, SPI2         ' assign SPI I/O pins, RX, TX, CLK
pause 20
SPI2 OPEN 100000, 0, 10         ' speed 1MHz, SPI mode 0, 10 bits data
PIN(27) = 0                     ' ADC chip enabled
data1 = spi2(104)               ' get data from ADC
pin(27)=1                       ' ADC chip disabled
SPI2 CLOSE                      ' close the channel
2025-02-01.png.pdf
Edited 2025-02-01 17:11 by apalert
karlelch
Posted: 11:35am 01 Feb 2025
Hi
not sure if it helps. I wrote a library for the MCP3208 (SPI, 12 bit, 8 channel), using the respective Arduino C(++) code as an example.
' lib_mcp3208.bas v0.1.2
' MCP3208 8-channel ADC driver
' 2024-02-04 - v0.1.1 - No constants to save global variable slots
' 2024-11-25 - v0.1.2 - Test routine added
' Example:
'   Const PIN_SPI2_RX      = MM.Info(PinNo GP12)
'   Const PIN_SPI2_TX      = MM.Info(PinNo GP11)
'   Const PIN_SPI2_CLK     = MM.Info(PinNo GP10)
'   Const PIN_MCP3208_CS   = MM.Info(PinNo GP13)
'   MCP3208.init PIN_SPI2_RX, PIN_SPI2_TX, PIN_SPI2_CLK, PIN_MCP3208_CS
'   Dim v(3)
'   MCP3208.readADCChans 4, v()
'   Math V_print v()
'   MCP3208.close
Option Base 0
Option Explicit
Option Escape
Option Default Float
Dim integer MCP3208.cs = MM.Info(PinNo GP13)
Sub MCP3208.init rx%, tx%, clk%, cs%
 ' Setup user SPI2
 Print "Initializing MCP3208 via SPI2 ..."
 SetPin rx%, tx%, clk%, SPI2
 SetPin MCP3208.cs, DOUT
 Pin(MCP3208.cs) = 0
 Pause 50
 Pin(MCP3208.cs) = 1
 SPI2 Open 1000000, 0, 8 ' 1MHz, mode 0, 8 bits
 Print "| Ready."
End Sub
Function MCP3208.readADC(ch%)
 ' Read channel `ch%`
 Local integer val, addr = &H60 Or ((ch% And &H07) << 2)
 Pin(MCP3208.cs) = 0
 SPI2 Write 1, addr
 val = SPI2(0) << 4
 val = val Or (SPI2(0) >> 4)
 Pin(MCP3208.cs) = 1
 MCP3208.readADC = val
End Function
Sub MCP3208.readADCChans n%, dta%()
 ' Read channels 0 to `n%`-1 into `dta%()`
 Local integer i, addr
 For i=0 To n%-1
   addr = &H60 Or ((i And &H07) << 2)
   Pin(MCP3208.cs) = 0
   SPI2 Write 1, addr
   dta%(i) = SPI2(0) << 4
   dta%(i) = dta%(i) Or (SPI2(0) >> 4)
   Pin(MCP3208.cs) = 1
 Next
End Sub
Sub MCP3208.close
 ' Close SPI2 devices
 SPI2 Close
 SetPin MCP3208.cs, OFF
End Sub
Sub MCP3208.test
 Local integer rx, tx, clk, cs, i, j
 Local integer v(7)
 rx  = MM.Info(PinNo GP12)
 tx  = MM.Info(PinNo GP11)
 clk = MM.Info(PinNo GP10)
 Print "Test is using SPI1 with:"
 Print "  VSYS -> VDD, VREF"
 Print "  GND  -> AGND, DGND"
 Print "  GP10 -> CLK"
 Print "  GP11 -> DIN"
 Print "  GP12 -> DOUT"
 Print "  GP13 -> CS/SHDN"
 Print
 MCP3208.init rx, tx, clk, cs
 For i=0 To 50
   For j=0 To 7
     v(j) = MCP3208.readADC(j)
   Next
   MCP3208.readADCChans 7, v()
   Math V_print v()
   Pause 500
 Next
 MCP3208.close
End Sub
It is mean to be loaded as a library, but it comes with a simple test.
Here, I am varying the voltage on channel 0 (left most value) from 0V to 5V and back to 0V using a potentiometer.
> mcp3208.test
 VSYS -> VDD, VREF
 GND  -> AGND, DGND
 GP10 -> CLK
 GP11 -> DIN
 GP12 -> DOUT
 GP13 -> CS/SHDN
| Ready.
4, 0, 0, 0, 0, 0, 0, 0
4, 0, 0, 7, 22, 31, 69, 0
3, 60, 61, 71, 89, 107, 178, 0
90, 149, 141, 191, 242, 322, 506, 0
970, 542, 481, 532, 588, 676, 823, 0
1452, 804, 794, 832, 847, 874, 885, 0
2186, 935, 888, 858, 832, 839, 854, 0
4063, 960, 881, 807, 810, 790, 765, 0
4095, 887, 839, 764, 730, 703, 667, 0
2050, 790, 763, 693, 662, 624, 552, 0
1432, 611, 540, 431, 370, 275, 131, 0
972, 253, 202, 91, 48, 0, 0, 0
371, 25, 14, 0, 0, 0, 0, 0
4, 0, 0, 8, 22, 21, 73, 0
3, 66, 59, 69, 94, 118, 190, 0
Thomas
Edited 2025-02-01 21:36 by karlelch
karlelch
Posted: 11:41am 01 Feb 2025
P.S.: I think in `SPI2 OPEN 100000, 0, 10` the 10 bits is the problem. The bit width refers to whether you read/write bytes (I read/write bytes) or 16 bit words to communicate with the SPI device - it is not related to the bit depth of your ADC.
Posted: 02:15am 02 Feb 2025
Including the start bit, you need 4 bits to set the configuration, one null bit and 10 data bits
By adding a low bit before the start bit, you have 16 bits nicely aligned
You can choose to use 8 bit spi or 16 bit spi. Either will work,
OPTION EXPLICIT
OPTION DEFAULT INTEGER
DIM data0, data1
PAUSE 20
'using 16 bit spi
SPI2 OPEN 100000, 0, 16         ' speed 1MHz, SPI mode 0, 16 bits data
DO
data0 = SPI2(&b0110100000000000)' get data from ADC channel 0
data1 = SPI2(&b0111100000000000)' get data from ADC channel 1
PIN(27)=1                       ' ADC chip disabled
PRINT data0,data1
PAUSE 5000
LOOP UNTIL INKEY$<>""
'using 8 bit spi
SPI2 OPEN 100000, 0, 8         ' speed 1MHz, SPI mode 0, 8 bits data
DO
data0 = SPI2(&b01101000)<<8 + SPI2(0)' get data from ADC channel 0
data0 = data0 AND &h3FF
data1 = SPI2(&b01111000)<<8 + SPI2(0)' get data from ADC channel 1
data1 = data1 AND &h3FF
PRINT data0,data1
PAUSE 5000
You may need to toggle the CS pin between the two readings.
I don't have the MCP3002 so untested.
apalert
Posted: 07:29am 02 Feb 2025
  karlelch said  P.S.: I think in `SPI2 OPEN 100000, 0, 10` the 10 bits is the problem. The bit width refers to whether you read/write bytes (I read/write bytes) or 16 bit words to communicate with the SPI device - it is not related to the bit depth of your ADC.
Thanks Thomas. Didn't have any luck with 16 bit but TassyJim has made progress as you will see in next post. Interesting reading your Arduino C++ approach. I installed the IDE, time to make a start with it!
apalert
Posted: 09:27am 02 Feb 2025
Now tested :)
First time I have seen a result using 16 bit SPI. Playing with pauses all through the code varied correct data from 9/20 readings to 15/20. When I say correct, they are a tad off, expected 512 actually ranges from 508 to 515.
8 bit initially gave about 2/20 matching expected result. Playing with pauses lifted that to 18/20. And the good results were perfect 512! Second channel not working with the 8 bit though.
The way there is a run of good results then bad has me baffled. It's not related to run time.
Yes, I did have to cycle CS pin between reading the channels.
Many thanks
Pluto
Posted: 10:37am 02 Feb 2025
I made a test program for MCP3004 some years ago. If I remember correctly it was ok. But I dont know if the operation is similar for your MCP3002. Please have a look and see if this makes any sense for solving your problem.
'FN1:
option autorun on
 cls
 TEXT 160,40,"MCP3004","CM",1,5,RGB(white)
 TEXT 160,120,"10bit ADC","CM",7,2,RGB(yellow)
 TEXT 160,200,"FN 2021","CM",1,5,RGB(magenta)
 pause 1000
 cls
 Dim integer TX,RX(2),HighByte, LowByte, i
 dim integer DOC 'Digital Output Code
 DIM float Vref=3.296, Vin, Avg, Vavg
 const CS=5 'Chip Select
 const DebugPrint=0
 setpin CS, dout
 pin(CS)=1
 pin(CS)=0
 pin(CS)=1
 'If the device was powered up with the CS pin low, it must be
 'brought high and back low to initiate communication.
 '            bit|7|  6     |     5     |4 |2 |1 |0|
 'TX=&b01000000' |0|StartBIT|Single/Diff|D2|D1|D0|0|      D2 is 0 for MCP3004
 TX=&b01000000'             differential CH0-CH1
 'TX=&b01000010'            diff         CH1-CH0
 'TX=&b01000100'            diff         CH2-CH3
 'TX=&b01000110'            diff         CH3-CH2
 'TX=&b01100000'            single          CH0
 'TX=&b01100010'            single          CH1
 'TX=&b01100100'            single          CH2
 'TX=&b01100110'            single          CH3
 'The first clock received with CS low and DIN high will constitute a start bit.
 'The SGL/DIFF bit follows the start bit and will determine if the conversion will be done
 'using single-ended or differential input mode. The next three bits (D0, D1 and D2) are
 'used to select the input channel configuration.
 'If necessary, it is possible to bring CS low and clock in leading zeros on the DIN line
 'before the start bit. This is often done when dealing with microcontroller-based
 'SPI ports that must send 8 bits at a time. NOTE THE FIRST "0" IN TX!
 'BY INSERTING ONE "0" BEFORE THE START BIT, THE OUTPUT MSB WILL START DIRECTLY WITH B9
 'OF THE OUTPUT CODE. (No Null Bit before the Output Code.)
 'The device will begin to sample the analog input on the fourth rising edge of the clock
 'after the start bit has been received. The sample period will end on the falling edge
 'of the fifth clock following the start bit.
 'Once the D0 bit is input, one more clock is required to complete the sample and hold
 'period (DIN is a “don’t care” for this clock). On the falling edge of the next
 'clock, the device will output a low null bit. The next 10 clocks will output the result
 'of the conversion with MSB first.
 do
   Avg=0
   for i=1 to 100
   MCP3004read
   Avg=Vin+Avg
   Next i
   Vavg=Avg/100
   TEXT 160,40,"V="+str$(Vavg,1,4)+"V","CM",7,2,RGB(white)
 loop
 end'
 sub MCP3004read
 spi open 1000000,3,8 '8 bit mode
   'Data is always output from the device on the falling edge of the clock.
   'Mode 0,0 or 1,1 are possible.
   PIN(CS)=0
   SPI WRITE 1,TX
   SPI READ 2,RX()
   if DebugPrint=1 then Print "RX0:";RX(0);" 0b";bin$(RX(0),8)
   if DebugPrint=1 then Print "RX1:";RX(1);" 0b";bin$(RX(1),8)
   'Print "RX2:";RX(2);" 0b";bin$(RX(2),8)
   'Print "RX3:";RX(3);" 0b";bin$(RX(3),8)
   HighByte=RX(0) and &b11111111 'B9:B2 of the output data
   HighByte= HighByte<<2
   LowByte= RX(1) AND &b11000000 'B1:B0 of the output data
   LowByte=LowByte>>6
   if DebugPrint=1 then print "HighByte";HighByte
   if DebugPrint=1 then print "LowByte:";LowByte
   DOC=HighByte+LowByte
   if DebugPrint=1 then Print "Code:"; DOC
   Vin=Vref*DOC/1024
   if DebugPrint=1 then Print "Vin=";Vin
   PIN(CS)=1 'The CS/SHDN pin must be pulled high between conversions.
   spi close
 end sub
Pluto
Posted: 08:11pm 02 Feb 2025
I forgot to mask off the higher bits in the 16bit code
etc
doing that will get rid of the obviously wrong readings.
In the 8 bit version I should have masked of bits for each SPI read before adding them together.
For some reason the second call to SPI2() is returning zero
This is why the v/2 readings are too constant at 512 and also why the 0.4V reading is 0 instead of ~128
@Pluto
the MCP3004 is very similar but has a couple more configuration bits so needs 17 cycles or 3 bytes.
Edited 2025-02-03 13:18 by TassyJim
apalert
Posted: 09:31am 03 Feb 2025
  TassyJim said  I forgot to mask off the higher bits in the 16bit code
etc
Jim, did as you suggested and you have nailed it! Results are amazing.
Initially results were +/- 3. However I stabilised VDD on the VDC at 3 volts with an LM4040 and forced Pico into PWM mode while reading, now we get +/- 1 as per spec sheet.
Was able to remove all pauses and bring clock back up to 1000000. Time to take 20 readings around 7.5m/s when not printing result of each loop.
Hard to say which is better, 8 bit SPI or 16. Accuracy seems the same. 16 bit is a tiny bit faster.
Thanks so much for your input.
PhenixRising
Posted: 11:40am 03 Feb 2025
Nice...and an interesting thread
