Local Time 19:04 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : formatting csv files
zeitfest
Posted: 10:07pm 12 Feb 2025
In general, do csv files have formatted field data ?
I think the whole point of csv's is convenience without formatting hassles.
I have been assuming that csv format just has data as ascii text fields with comma separators, with each field text length arbitrary. So to format each field individually would probably be unrequired complexity, may as well just use a string of text for each field, up to a default length for each datatype.
Is that the right track ?
tgerbic
Posted: 11:06pm 12 Feb 2025
It is just commas between fields. Simple. Just remember that the data must not have any commas in the text or it will be seen as another separator and offset all the rest of the data by the number of embedded commas.
Posted: 11:45pm 12 Feb 2025
I use tabs as the delimiter, means you can include commas in your text.
If you have a lot of formatted text, you can use double quotes, eg
"Apples","Pears","Oranges"
If there is a double quote in the text, you can escape it using another double quote. eg
"Fred said ""Hi"". ","Jane said ""How are you""."
I'm using commas as the delimiter here because a tab isn't visible.
Posted: 11:46pm 12 Feb 2025
INPUT # finds the comas and assigns the content of each field to a variable. Can be string variables.
eg
dim a(5)
> input a(0),a(1),a(2)
? 5,6,7
> math v_print a()
  5.0000,    6.0000,    7.0000,    0.0000,    0.0000,    0.0000
> dim s$(6), d$="sun,mon,tue,wed,thu,fri,sat"
> open "days.txt" for append as #3
> ? #3, d$
> close #3
> list "days.txt"
> open "days.txt" for input as #3
> input #3, s$(0),s$(1),s$(2),s$(3),s$(4),s$(5),s$(6)
> close #3
> for n=0 to 6:? s$(n), :next
sun     mon     tue     wed     thu     fri     sat
It's a pity this doesn't work
input a()
Edited 2025-02-13 12:32 by phil99
Posted: 07:17am 13 Feb 2025
Hi Phil,
Pitty you did not name your file "days.csv". That would have matched the topic
Edited 2025-02-13 17:17 by Volhout
Posted: 07:30am 16 Feb 2025
deleted
Edited 2025-02-16 17:34 by phil99
