Forum Index : Microcontroller and PC projects : Math M_Mult Bug
| Elijah 2 Newbie Joined: 08/03/2025 Location: United StatesPosts: 10 |
Hi all, I'm a new member but have been using MMBasic for a bit. I've found a bug (I think) with the Math M_Mult command. It seems to be using the Bound() of the wrong dimension when computing a product matrix with M_Mult; thus this bug doesn't manifest when multiplying square matrices. Here is code the demos the bug: Dim Float A(1, 6), TransA(6, 1), ProdA(6, 6) Math Set 1, A() A(1, 0) = 0 : A(1, 1) = 2 : A(1, 2) = 3 : A(1, 3) = 4 A(1, 4) = 5 : A(1, 5) = 7 : A(1, 6) = 8 Math M_Transpose A(), TransA() Math M_Mult A(), TransA(), ProdA() Math M_Print A() : Print Math M_Print TransA() : Print Math M_Print ProdA() Actual Output: 1.0000, 0.0000 1.0000, 2.0000 1.0000, 3.0000 1.0000, 4.0000 1.0000, 5.0000 1.0000, 7.0000 1.0000, 8.0000 1.0000, 1.0000, 1.0000, 1.0000, 1.0000, 1.0000, 1.0000 0.0000, 2.0000, 3.0000, 4.0000, 5.0000, 7.0000, 8.0000 1.0000, 1.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000 1.0000, 5.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000 1.0000, 7.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000 1.0000, 9.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000 1.0000, 11.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000 1.0000, 15.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000 1.0000, 17.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000 Expected Output for ProdA(): 1 1 1 1 1 1 1 1 5 7 9 11 15 17 1 7 10 13 16 22 25 1 9 13 17 21 29 33 1 11 16 21 26 36 41 1 15 22 29 36 50 57 1 17 25 33 41 57 65 You can see that the first two columns of output for ProdA() are correct. If I were to make A() have three columns, the first three would be correct. It's a little confusing because in code you dim A(cols, rows) but in math it's rows x cols. Maybe that's why the bug exists to begin with If some of the other forum members can confirm this is a bug, I'd appreciate it. Peter, sorry for emailing you directly about this. I honestly didn't think there was anyway I'd get a working membership on this forum, but it let me register (after a lot of leg work ).Thanks all! |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6162 |
I used matrix multiplication extensive in the thermal camera. On 5.09.00. Later tonight I can check on current release. Volhout PicomiteVGA PETSCII ROBOTS |
Thanks! I'm using v5.08. I should have mentioned that. |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11968 |
You don't say what firmware and what version you are using. I get the correct answer with V6.00.02b16 |
MM.Info(Version) is 5.08 and the firmware filename is WebMiteV5.08.00.uf2. I'm waiting to upgrade for 6.00.02 [release/stable?] for the LInStr regex fix. If this has already been addressed, please disregard. |
Hi Elijah, The thermal camera still work correct with the latest 6.00.02b16_2 on RP2040 in a VGA platform. I remember when implementing it that I needed to read the description in the user manual carefully, since there was something in the way rows and columns where used. Maybe that is what you are referring to. These are snippets of the code, array sizes, and how they are used with math M_mult 'scaling buffers and math matrices dim f_t(191),f_v(191) 'scratchpad temp/voltage size%=5 'pixel size dim Toa(15,11) 'this is Vir() in 2D form for math dim c(15,44) 'array for intermediate results math dim d(11,44),b_e(30,15),b_o(30,15) 'conversion arrays for scaling dim x_s%(1394),y_s%(1394) 'arrays for screen coordinates fill_matrix 'fill conversion matrices dim scrn_2D(30,44) '2D buffer for math dim scrn_1De(1394),scrn_1Do(1394) 'even/odd 1D arrays for 61x45 screen 'lots of code here in between..... 'show 192 temperatures on screen in a grid of 61x45 interleaved sub scale_4d local y31,px,cs0,cs1,x,y as integer 'copy linear array into 16x12 array, and perform math to scale up (=21ms) MEMORY COPY INTEGER PEEK( VARADDR Vir()),PEEK( VARADDR Toa()),192 math m_mult d(),Toa(),c() 'c() is in correct vertical resolution 'with low delta-T limit the color scaling for visual appearance max_colors = min(int(Tmax-Tmin)+2,num_colors-1) max_colors = 15 math window c(),0,max_colors,c() 'x color 'math window c(),0,max_colors+0.4,c() 'x colors + 0.4c for better distribution 'calculate even pixels math m_mult c(),b_e(),scrn_2D() 'flatten into 1D array MEMORY COPY float PEEK( VARADDR scrn_2D()),PEEK( VARADDR scrn_1De()),1395 'convert to RGB colour map scrn_1De(),scrn_1De(),col%() 'calculate odd pixels math m_mult c(),b_o(),scrn_2D() 'flatten into 1D array MEMORY COPY INTEGER PEEK( VARADDR scrn_2D()),PEEK( VARADDR scrn_1Do()),1395 'convert to RGB colour map scrn_1Do(),scrn_1Do(),col%() 'plot all the boxes on screen, since VGA does not use a framebuffer 'the plotting is done as fast and compact as possible. That is why there 'are dual 1D screen buffers. '31 even boxes, original x() coordinates box x_s%(),y_s%(),size%,size%,1,scrn_1De(),scrn_1De() math add x_s%(),size%,x_s%() 'prepare for odd boxes '30 odd boxes box x_s%(),y_s%(),size%,size%,1,scrn_1Do(),scrn_1Do() math add x_s%(),-size%,x_s%() 'restore for next even boxes end sub In this upscaling routine the even pixels and odd pixels are calculated independently, simply because there was not enough RAM memory to hold the whole array of 64bit variables. The b_e() and b_o() arrays contain the multiplication factors for upscaling. Volhout Edited 2025-03-09 04:35 by Volhout PicomiteVGA PETSCII ROBOTS |
I've upgraded my pico 1 W to the latest stable firmware WebMiteRP2040V6.00.01.uf2 and rerun the code posted above. Success! Output with WebMiteRP2040V6.00.01.uf2: 1.0000, 0.0000 1.0000, 2.0000 1.0000, 3.0000 1.0000, 4.0000 1.0000, 5.0000 1.0000, 7.0000 1.0000, 8.0000 1.0000, 1.0000, 1.0000, 1.0000, 1.0000, 1.0000, 1.0000 0.0000, 2.0000, 3.0000, 4.0000, 5.0000, 7.0000, 8.0000 1.0000, 1.0000, 1.0000, 1.0000, 1.0000, 1.0000, 1.0000 1.0000, 5.0000, 7.0000, 9.0000, 11.0000, 15.0000, 17.0000 1.0000, 7.0000, 10.0000, 13.0000, 16.0000, 22.0000, 25.0000 1.0000, 9.0000, 13.0000, 17.0000, 21.0000, 29.0000, 33.0000 1.0000, 11.0000, 16.0000, 21.0000, 26.0000, 36.0000, 41.0000 1.0000, 15.0000, 22.0000, 29.0000, 36.0000, 50.0000, 57.0000 1.0000, 17.0000, 25.0000, 33.0000, 41.0000, 57.0000, 65.0000 I didn't see this as an issue that was addressed so presumed it still was. All is well! Volhout, your use of Math Window to fit the color pallet is very elegant! |
