Local Time 04:35 13 Aug 2026 Privacy Policy
     Page 2 of 52
Posted: 05:00pm 13 Mar 2025
V6.00.02RC1 is available on
Fixes the issues picked up on RC0
Posted: 07:18pm 13 Mar 2025
Hi Peter,
2040 VGA RC1: So far most programs work, except for the logic analyzer.
It complains about not enough heap memory.
Memory indicates there is 128k available when not program running. That is good.
The logic analyzer:
- it uses FRAMEBUFFER, I checked that is 38k, nothing changed.
- it uses a large (16k) ring buffer (that wastes RAM because it needs an aligned start point).
- then several buffer (packed-unpacked), and string arrays (short length).
I tried re-arranging the DIM of buffers / arrays to hit the sweet spot, where it would all fit in RAM. But not found it yet. It looks like the memory start point is very unfortunate for mapping the variables in RAM. It all happens in "init_memory".
I will play a bit more.
There is something strange. After creating the ring buffer and unpacked buffer, there is 52kbyte heap left, then I want to create the framebuffer, and it errors "not enough heap". Should still have 14k left.
LA_24_2_60002rc1.zip
EDIT additional debugging (note: samples%=4096)
Sub init_memory
 'define data buffers
 'The logic analyzer captures samples% samples into the packed%() array'
 'The DMA buffer has 64bit width, packed with 32bit FIFO (2 per cell) = length%
 'The size of the ring buffer is specified in bytes, so size is 8 * length%
 'the samples will be unpacked into unpacked%() at 32 bits per cell (=2*lenth%)
CLS
Print MM.Info(heap)
 'MODE 1
 FRAMEBUFFER create          'define framebuffer after MODE
Print MM.Info(heap)
 length% = samples% / 2             'packed buffer = 64bit, data buffer 32bit
 Dim packed%                        'name of array to become circular buffer
 PIO MAKE RING BUFFER packed%,8*length%
Print MM.Info(heap)
 Dim unpacked%(samples%-1)          'array to put the 32 bit samples (base 0)
Print MM.Info(heap)
 Dim pnt%(100),deco$(100) length 10 'buffers for I2C decoding
End Sub
results in following printout
101888 --- clean heap
63488 --- framebuffer added 38k
47104 --- ring buffer added 16k
[558] Dim unpacked%(samples-1)
Error : Not Enough Heap memory
The unpacked%() buffer would require 32k of the 47k free. Why not enough heap..?
Edited 2025-03-14 05:42 by Volhout
Posted: 07:41pm 13 Mar 2025
  Quote  There is something strange. After creating the ring buffer and unpacked buffer, there is 52kbyte heap left, then I want to create the framebuffer, and it errors "not enough heap". Should still have 14k left.
The framebuffer need to be contiguous and it looks like the ring buffer has chopped up the available space
ville56
Posted: 07:43pm 13 Mar 2025
Peter,
ad FT6336: did some probing with the scope ... the IRQ pin is not going low, so there will be no interrupt generated. I don't know if this is because of some problems with the register init from the MMBasic firmware side or some fake or crap chips. I'll try to further translate the chinese register description of the FT6336 and will look through some c++ driver-files that i found on Github. But so far i've not been very successful. At least i can read and write the touch-controller registers already.
btw, RC1 did not solve the issue for me.
Gerald
73 de OE1HGA, Gerald
Posted: 07:44pm 13 Mar 2025
Peter,
See additional info in previous post..
bfwolf
Posted: 09:01pm 13 Mar 2025
@Peter:
Please don't misunderstand me: I don't want to "push" you, but I think it would be really worth considering using "SetByte()" and "GetByte()" respectively instead of "BYTE" for the command and function.
I took a look at the manual. There are already equivalents for long strings: "LONGSTRING SETBYTE" and "LGETBYTE()." So, from that perspective, maybe it would make more sense and be more logical?
Besides, that would leave "BYTE" free for a data type you might want in the future.
I hope you've already noticed how much I appreciate your and Geoff's work.
bfwolf
Posted: 10:44pm 13 Mar 2025
  Quote  ad FT6336: did some probing with the scope ... the IRQ pin is not going low, so there will be no interrupt generated. I don't know if this is because of some problems with the register init from the MMBasic firmware side or some fake or crap chips. I'll try to further translate the chinese register description of the FT6336 and will look through some c++ driver-files that i found on Github. But so far i've not been very successful. At least i can read and write the touch-controller registers already.
Try download RC1 again. I've made some tiny changes and it definitely works for me. The display must be fully wired on reboot because there is an I2C instruction that is sent on reboot that enables the IRQ output from the touch controller. If it doesn't see this it won't work. I have rewired the relevant display and it definitely can work with the latest RC1
Edited 2025-03-14 08:45 by matherp
disco4now
Posted: 01:58am 14 Mar 2025
Hi Peter,
Just studying what you have done, I should understand it in about 6 months!
I noticed in
void fun_tilde(void){
that  case MMFONTHEIGHT: does not have a break. I think it would drop through to the default value.  Two breaks in case MMVER so it probably escaped to there.
Gerry
F4 H7FotSF4xGT
ville56
Posted: 06:56am 14 Mar 2025
Peter,
ad FT6336: it now generates interrupts and also the touch sensitve gui controls now work.
BUT it is now impossible to perform a GUI CALIBRATE. It terminates after one or two calibration points .... it was not easy with previous versions but it worked sometimes. Now it is just impossible.
failure after 1st cal. point (2nd point is drawn, but error raised)
> gui calibrate
Error : Touch not calibrated
failure after 2nd cal. point
> gui calibrate
Error : Touch hardware failure -1,-1,-1,-1
But many thanks for your unbelievable work, i always wonder how fast you write your code and change big parts of the firmware.
Gerald
Posted: 07:49am 14 Mar 2025
@Peter,
The original logic analyzer defined the RING BUFFER first, probably at your advise at that time, to avoid wasting RAM due to the alignment requirement. 3 posts back I posted a version where I started swapping RING BUFFER and FRAMEBUFFER order to try to make it work.
I assume heap was 16k block aligned in memory originally.
In V6.00.02b16_2 for 2040 VGA it still was. The B16_2 is the test update on the 2040 VGA version where you gained some RAM by skipping 126MHz VGA as I recall.
In v6.00.02b17 the logic analyzer stopped workin. I do not have b18, but in RC0 and RC1 the logic analyzer refuses to work.
Is there any way to get heap back at the original position ? (as in b16_2).
Thank you,
attached: the original logic analyzer, as working on PicoMiteVGA RP2040 v6.00.02b16_2
LA_24_2.zip
Posted: 09:43am 14 Mar 2025
  Quote  case MMFONTHEIGHT: does not have a break. I think it would drop through to the default value.  Two breaks in case MMVER so it probably escaped to there.
Thanks - typical cut-and-paste mistake
  Quote  BUT it is now impossible to perform a GUI CALIBRATE. It terminates after one or two calibration points .... it was not easy with previous versions but it worked sometimes. Now it is just impossible.
Wish I'd never started with this bl..dy device - will look further
ville56
Posted: 09:49am 14 Mar 2025
Peter,
ad FT6336: did some testing with Logic and Protocol Analyzer ... seems as after the first calibration point there is no I2C traffic anymore. So the data for the 2nd calibration point are never read in physically.
The data from the first calibration point are always the same (more or less) and are IMHO sensible no matter if they are considered valid or not.
I've also tried with I2C setting SLOW, but no change.
Gerald
Posted: 09:57am 14 Mar 2025
  Quote  ad FT6336: did some testing with Logic and Protocol Analyzer ... seems as after the first calibration point there is no I2C traffic anymore. So the data for the 2nd calibration point are never read in physically.
I know what the issue is - just trying to find a way round it without a complete re-write
Posted: 12:58pm 14 Mar 2025
V6.00.02RC2 is available on
Fixes bug in FT6336 touch
Fixes bug in MM.FONTHEIGHT
Re-arranges memory for RP2040 VGA
JanVolk
Posted: 01:31pm 14 Mar 2025
This is with the latest version
> option list
PicoMite MMBasic RP2040 Edition V6.00.02RC2
OPTION SYSTEM I2C GP4,GP5
OPTION COLOURCODE ON
OPTION CPUSPEED  48000 'KHz
OPTION DISPLAY 44, 89
> list functions
Error: Invalid address - resetting
Greetings,
Jan.
Posted: 02:36pm 14 Mar 2025
I've fixed LIST FUNCTIONS and updated the download - no version change
Posted: 02:53pm 14 Mar 2025
Peter,
You did it again.. !! It's alive.
Thank you. I will do a lot of testing during the weekend, but first glance RC2 looks perfect.
Thank you.
Edited 2025-03-15 00:53 by Volhout
ville56
Posted: 02:57pm 14 Mar 2025
Peter,
FT6336 calibration now works. But the program hangs arbitrarily after a number of touch presses. The Hardware still asserts the /IRQ signal, the loop in the program is still running but the touch interrupt is not processed and there is no activity on the I2C bus anymore.
Sorry to bother you again ...
Gerald
Posted: 03:01pm 14 Mar 2025
Doesn't stop for me. You need to find what you are doing that triggers the issue before I can do anything
GUI interrupt myint
Sub myint
Print Touch(x),Touch(y),Touch(x2),Touch(y2)
End Sub
Edited 2025-03-15 01:02 by matherp
ville56
Posted: 03:44pm 14 Mar 2025
its triggered by just fast tapping on the toch panel. 10 to 20 times will do it most the time. And I can reproduce it reliably.
Will investigate further with different hardware ...
     Page 2 of 52
