Forum Index : Microcontroller and PC projects : CMM2: Latest firmware ?
Hi folks, Is there a later CMM2 firmware than "MMBasic Version 5.07.02b2" ? Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
https://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=17795&LastEntry=Y#237053 |
Thank you Peter, now I just have to try and remember how to flash the thing. Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
CMM2 manual appendix G for Linux gives http://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=12171 but gone from TBS :( Is on archive.org John |
Thanks John, but fortunately I was able to muddle through on Windows. Peter, I'm afraid I've found an issue: > ? Mm.Ver 6.000002 > List "errno.bas" Option Explicit On Print Mm.ErrNo > Run "errno.bas" Error in line 2: MM.ERRNO is not declared Also I don't think it has a recent implementation of RUN as I'm having to use the EXECUTE hack to call RUN from within a program - I can live with this. Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
Here you go CMM2V6.00.00b2.zip CMM2 is too different to change RUN easily |
Thank you Peter, that seems to have done the job. Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
