Local Time 18:13 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : New Z-MIM release - play Infocom adventures on PicoMite
Posted: 10:27pm 30 Apr 2025
Link to original Z-MIM thread
Hey folks,
I have updated Z-MIM so it should run on all PicoMite's (even RP2040 VGA), CMM2, MMB4L and MMB4W.
https://github.com/thwill1000/mmbasic-zmim
Version 3.5.0 - 1-May-2025:
- Added support for new platforms:
  - MMBasic for Linux.
  - MMBasic for Windows.
  - PicoMiteVGA and PicoMiteHDMI including USB versions.
  - PicoCalc (third party PicoMite variant).
  - Note that due to RAM limitations a "virtual memory" implementation is
    used when running on PicoMite RP2040 platforms making them slower.
- Added command history to the prompt.
  - This is accessed via the Up & Down cursor keys.
  - Under the hood the console support has been replaced with the more
    advanced version that I developed for the "Scott Adams Adventure
    Interpreter" (SAAINT).
- Added *MORE [ON | OFF] meta-command to enable/disable paged output.
- Added *RECORD [ON | OFF] and *REPLAY [ON | OFF] meta-commands for recording
  and replaying scripts.
  - Script files recorded by previous versions are now invalid.
- Added *SCREENSHOT meta-command for generating .bmp screen-shots.
  - Not currently supported when running from the MMBasic for Linux console.
- Added *SPIN [ON | OFF] meta-command to enable/disable display of spinning
  cursor when Z-MIM is "thinking". The spinning cursor is enabled by default
  on PicoMite platforms.
- Removed Colour Maximite 1 support; it was much too slow on the CMM1 to be
  playable and in any case that platform is now long superseded by the CMM2
  and PicoMite.
Happy adventuring,
Gadgetguy
Posted: 10:24am 01 May 2025
Thank you Tom, this is amazing! My Picocalc will be more happy now (after it arrives)
Posted: 07:41pm 05 Jun 2025
ZMIM v3.6.0 released.
   https://github.com/thwill1000/mmbasic-zmim/releases/tag/v3.6.0
ChangeLog:
Version 3.6.0 - 1-Jun-2025:
- Added status line.
  - Having the status line "scroll" off the top of the display and then
    redrawing it (instead of having the text scroll beneath it) is a
    deliberate choice for performance reasons rather than a bug.
- Added *FONT [SMALL | MEDIUM] meta-command.
  - KNOWN BUG: using *FONT SMALL on the Colour Maximite 2 causes the prompt
    to "glitch" in a way I have been unable to reproduce in a small example.
- Added '--shell' command-line option which if used will cause Z-MIM to
  RUN the program specified in the "/.mmbasic-shell" file when it exits.
- Changed code to use SELECT CASE rather than IF .. THEN .. ELSEIF ..
  constructs.
  - This should slightly improve performance.
- Changed transpiled versions of Z-MIM to remove comments and unnecessary
  whitespace.
- Changed code to no longer use _ as a variable name as this was incompatible
  with the new PicoMite line-continuation feature.
- Removed '--platform' command-line flag.
  - This was specifically for MMB4L and as of MMB4L v0.8 is no longer
    required due to enhancements to the RUN command.
- Fixed *status meta-command to display time instead of score for
  "time games" such as "Deadline".
- Fixed bug where cursor colour was always white rather than using the
  display foreground colour.
- Fixed debug help text for displays <= 40 characters wide.
- Fixed formatting of stored values when using interactive debugger.
Edited 2025-06-06 05:45 by thwill
