Forum Index : Microcontroller and PC projects : How to stop an E64
| PeterB Guru Joined: 05/02/2015 Location: AustraliaPosts: 669 |
G'Day All I have an E64 running some code which is started by OPTION AUTORUN ON. It works very well. My problem is, how do I stop it? I know, I'm an old bloke and should give up trying. Peter |
control-C unless you have turned it off Jim VK7JH MMedit |
G'Day Jim Thanks. I'm sure I have used that in the past but one does forget these things. Peter |
If you also want to prevent the program from running at startup, enter OPTION AUTORUN OFF at the command-prompt, but you probably already knew that. ![]() Smoke makes things work. When the smoke gets out, it stops! |
G'Day Grogster. The problem with that is, how do I get to the command prompt when the thing is running. Yes, I know, hit Ctrl + C. A lot of this stuff is coming back to me after not using it for a while but it is slow but still fun. Peter |
Eh? Am I confused? You can't have the command prompt while a program is running... It can be either stopped at the command prompt or running, but not both. Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
G'Day Mick. You and I agree, correct? Peter |
Probably. I get easily confused nowadays. :) Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
