Forum Index : Microcontroller and PC projects : Maximite V6 MMBasic manual?
| Gadgetguy Senior Member Joined: 26/04/2025 Location: FrancePosts: 104 |
Hello all, I see that the most recent (beta) firmware for the Maximite Color 2 is V6.00 The official manual is (as far as I can see) for V5.07.01 Is there somewhere an updated manual for the Maximite V6.00 please? Or should I just look at the PicoMite manual Ver 6.00 - will that be accurate (except the PIO part)? Thank you for your help! Edited 2025-05-08 20:09 by Gadgetguy |
Hi, Typically a user manual update happens when a beta or release candidate becomes a final release. Since 6.00 on the CMM2 is beta, use the 5.7 user manual. It is the only available. Volhout PicomiteVGA PETSCII ROBOTS |
Thank you. So there is no way to find out what has changed between 5.7 and 6.0 on the cmm2? |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11513 |
It's mostly internal stuff MATH commands are now as per PicoMite Includes MEMORY PACK/UNPACK as per PicoMite Includes BLIT MEMORY as per PicoMite (Petscii compatibility) Fixes various bugs |
Thank you |
