Local Time 23:39 15 May 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : I've now jumped on the PICO2 train...
Posted: 06:41am 13 Jun 2025
I have some on order.
This module looks very nice indeed.
Good job, Peter.
As with everyone else's orders, the PSRAM chip was unavailable, so I just left it off.
I HOPE....I can get some time to play with this new module.
I am very busy at work these daze.....
Bryan1
Posted: 07:35am 13 Jun 2025
Grog's if you one spare I'll buy one off you mate
Cheers Bryan
Bleep
Posted: 12:43pm 13 Jun 2025
Make sure you set up the R1V pot before you power anything on.
Posted: 12:52pm 13 Jun 2025
The pots seem to come mid-range which gives a voltage of just over 1.4 - perfectly safe. I just power the boards up and then with a multimeter across DVDD and GND adjust to 1.3. The board is designed so that even with the pot full scale it should be safe (1.8V) - others have run the chip at that without issue
PhenixRising
Posted: 01:30pm 13 Jun 2025
Started laying out a carrier board. DIL is soo nice.
Posted: 12:13am 14 Jun 2025
I will ensure pot is mid-range first, then do the power check thing.
I have to do a bit more research on Peter's original thread.
I can't remember what the purpose of the little trimmer is, but I am sure it is there for good reason.  None of the other boards have it, so perhaps it is specific to the 2350 chip or something - I will go do a bit more reading to find out.
JLC website DID moan that the oscillator and caps were NOT those specifically stated by Raspberry PI Org that you are supposed to use, but I basically ignored it, assuming Peter knows what he's doing with PI boards now, and I have also seen posts from others who have had these boards made, and they obviously start up fine, so....
Posted: 12:14am 14 Jun 2025
  Bryan1 said  Grog's if you one spare I'll buy one off you mate
Cheers Bryan
Yes, I ordered ten units, so I will have a few spares - I'll only be playing with one module to start with.  I may well put them up on my website, so long as Peter is happy with the state of the design etc, and if other members think that would be something they would like me to do.
Bryan1
Posted: 12:38am 14 Jun 2025
Thanks Grog's when your ready to send one over just PM me with the cost   and I'll make the payment straight away.
Posted: 02:57am 14 Jun 2025
is the unused end of R1V tied to the wiper?
i'd be interested in seeing both sides of the PCB with parts unpopulated so all tracks are visible.
rob   :-)
Posted: 07:14am 14 Jun 2025
Grogster et al
I have done a trivial update to include GPIO numbers on the top silkscreen of the board. No other changes. The board as you have ordered seems rock solid.
Pico2350DILV1.2.zip
Edited 2025-06-14 17:17 by matherp
Posted: 08:29am 14 Jun 2025
Excellent.
I have yet to test my units as ordered, but if Peter is happy(and it seems he is) with the stability of this layout, I will PROBABLY offer these for sale on my website.
Shipping world-wide.
Posted: 08:37am 14 Jun 2025
One of the things I want to do, is design a carrier board that has HDMI.
PhenixRising has already indicated this is in progress, so rather then double-up, perhaps the member can elaborate on what they are going to have on their carrier board?
No sense in re-inventing the wheel.....
PhenixRising
Posted: 11:11am 14 Jun 2025
Hi Grogs,
Mine is purely for machine interfacing.
-16 buffered ins
-16 buffered outs
-2 MC3486 line receivers
-2 4050 level shifters
-1 op-amp for analog out
-1 MAX3491 for multidrop, FD RS422.
etc....
Posted: 12:15am 19 Jun 2025
My boards have arrived.
I hope to have a play around with one of them over the weekend.
PhenixRising
Posted: 03:55am 19 Jun 2025
Posted: 06:00am 20 Jun 2025
OK, I have my first PICO2 up and running, and white "Heartbeat" LED blinking away there happily.
Can someone just briefly explain WHY there was a need for the wee trimmer, and setting it to 1.30v - which I have done, BEFORE I loaded the MMBASIC firmware.
I am sure this has been covered before, but I have been very busy lately, and have not had the time to read each and every thread or post, so a quick pointer as to the purpose and need for this trimmer would be fantastic.
Posted: 06:51am 20 Jun 2025
Hi grogster,
In short: RP designed a switch mode power supply for the core voltage INSIDE the RP2350B. That switcher has possibility to adjust the core voltage to support over clocking.
But.. RP found out that the switcher is sensitive to noise, and specific noise generated from the coil that the switcher uses. Polarity of the coil (how it is wound) is key. And since there is no polarity indicator on small coils, problems are to be expected.
Hence Peter decided to avoid the issue, and use an external linear regulator for the core voltage. And if you want to "overclock" you have to set it for 1.3V (normal core voltage is 1.1V for 150MHz).
That is the short story,
Edited 2025-06-20 16:52 by Volhout
Posted: 06:52am 20 Jun 2025
IIRC, the faster you want to go the higher the voltage needed.
Posted: 07:04am 20 Jun 2025
  Quote  IIRC, the faster you want to go the higher the voltage needed.
"These go to 11" :)
(Tune for maximum smoke)
Posted: 07:24am 20 Jun 2025
@ Volhout: Thanks a bunch.  Explains it exactly.
EDIT: Should I be setting the default core voltage to 1.10v then?
1.30v might be needed for HDMI support etc.
Edited 2025-06-20 17:28 by Grogster
