Forum Index : Microcontroller and PC projects : PEEK and POKE FLOAT var! 32 bit
Both PEEK and POKE FLOAT var! are described in the Picomite manual as 32bit but they both appear to be 64 bit. The manual needs updating. I have a use for 32bit PEEK/POKE FLOAT. I have written a function for PEEK and will try POKE next but I was wondering if there is a 32bit version lurking in the firmware somewhere. Jim VK7JH MMedit |
Not sure if this is what you are doing. Is this any help Gerry F4 H7FotSF4xGT |
Something like: convert to 32-bit then use POKE WORD. Worst case, extract 4 bytes & use POKE BYTE. John |
Thank Gerry, that should be useful. I have a routine to read *.OPT files and there are 2 floats in the structure. This is what I came up with: CASE "float" b1%= ASC(INPUT$(1,#3)) : b2%= ASC(INPUT$(1,#3)) :b3%= ASC(INPUT$(1,#3)) :b4%= ASC(INPUT$(1,#3)) tempint% = ((b4%*256+b3%)*256+b2%)*256+b1% mantissa = tempint% AND &h7FFFFF mantissa = mantissa +&h800000 exponent = (tempint% >>23)AND &hFF exponent = exponent - 127 sign = (tempint% >>31)AND 1 tempfloat! = mantissa*2^-23*2^exponent * 10000 ' multiply by 10k to match OPTION LIST IF sign THEN tempfloat!=0-tempfloat! readdata$ = STR$(INT(tempfloat!))+" ("+STR$(b1%)+" "+STR$(b2%)+" "+STR$(b3%)+" "+STR$(b4%)+")" I didn't think of converting to 64bit at the bit level. Jim VK7JH MMedit |
One interesting issue I found was 2^exponent In the third last line it was overflowing with large numbers even though the result was going into a float. I changed it to 2.0^exponent to force a float and all was well I ended up using a combination of this code and the FoTS code Jim VK7JH MMedit |
