Local Time 10:35 16 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Opto-coupler for DIs
PhenixRising
Posted: 07:18am 24 Jun 2025
I am using the PC817 for digital inputs. Would an If ~5mA suffice? The datasheet warns about <1mA and I want to be safe.
PC817.pdf
Posted: 08:21am 24 Jun 2025
  Quote   Current transfer ratio (CTR : MIN. 50% at IF=5 mA, VCE=5V)
So it appears the output load can be up to 2.5mA for a drive of 5mA.
If the supply on the output side is 3.3v and the load resistor is 3.3kΩ just 1mA can flow so it should be ok.
Edit.
Fig.6 Current Transfer Ratio vs. Forward Current shows best CTR @ If = 2.5mA.
Edited 2025-06-24 18:29 by phil99
PhenixRising
Posted: 08:50am 24 Jun 2025
Cheers Phil. 2.5mA feels good
Posted: 10:23am 24 Jun 2025
Phenix,
Speed on these PC817 is not overwhelming.
For more speed use digital isolators, or digital optocouplers.
PhenixRising
Posted: 10:54am 24 Jun 2025
Cheers, Harm.
These are only 24V signals from proximity sensors. I software debounce anyway so speed isn't an issue.
