Local Time 08:27 13 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite V6.01.00 betas
     Page 2 of 15
Bleep
Posted: 06:52pm 26 Jul 2025
Hi Peter,
OK thanks I'll look out for the firmware.
If I draw the circles to a framebuffer it draws at about 3500 cps, so I was thinking I would get results closer to your GUI TEST LCDPANEL, using the BUFF driver, but presumably not?
Any sugestions on how I use the OPTION AUTOREFRESH command which you mentioned?
Regards, Kevin.
Posted: 07:05pm 26 Jul 2025
Here is a full set of the 6.01.00b3 files
PicoMiteV6.00.03b2.zip
Implements OPTION AUTOREFRESH ON/OFF and REFRESH commands
Fixes bug in BLIT x1,y1,x2,y2,w,h for buffered drivers
The RP2040 files should work as before with no changes. The RP2350 VGA files have the new KEYPAD command variant. In addition HDMI files have the new resolutions and standard RP2350 PicoMite files have the buffered drivers.
  Quote  Any sugestions on how I use the OPTION AUTOREFRESH command which you mentioned?
Wasn't implemented before this release. OPTION AUTOREFRESH is a temporary option which is set to ON whenever a program is run or a program ends.
When set to off drawing commands take place to the buffer but the display is not updated. Updates will restart and catch up with OPTION AUTOREFRESH ON, alternatively you can leave it to OFF and force a screen write using the REFRESH command.
GUI TEST LCDPANEL now shows the number of circles/second when you exit the test normally (NOT Ctrl-C)
stanleyella
Posted: 10:47pm 26 Jul 2025
tried on board with audio hdmi usb the manual suggestions and ok
Bleep
Posted: 08:11am 27 Jul 2025
  Quote  Here is a full set of the 6.01.00b3 files
Ok, thanks Peter, I'll give it a go when I'm home from Bisley.
Regards Kevin.
Posted: 08:32am 27 Jul 2025
Bisley? Are you a rifle target shooter? Used to go there with my father when he was firing a .22 at tiny targets
Bleep
Posted: 09:15am 27 Jul 2025
I prefer the longer stuff 600 to 1200yds, though today only 100yds with yes .22 & .357 under lever (John Wayne) :-)
javavi
Posted: 09:20am 27 Jul 2025
Welcome to Ukraine, gentlemen!
Here, as part of the Armed Forces of Ukraine, you can shoot from any type of caliber at any distance!
PhenixRising
Posted: 10:24am 27 Jul 2025
  javavi said  Welcome to Ukraine, gentlemen!
Just walk in to any hunting store in USA. I went in for new boots and came out with a 7mm Ultra Mag
Posted: 11:29am 27 Jul 2025
The Betting and Gaming Act of 1960 officially ended the requirement for mandatory archery practice in England. Aren't we lucky?  :)
JanVolk
Posted: 06:34pm 27 Jul 2025
New in V6.01.00b2 is the function: MM.SUPPLY
This allows you to monitor the battery voltage.
SetPin GP29, AIN ' A3=GP29 VSYS/3=GP29 VSYS--R5=200K--+--R6=100K--GND
Print "VSYS/3=GP29 = "; Pin(GP29)        '            +--C3= 1nF--GND
Print "VSYS        = "; Pin(GP29) * 3.01 '            +-AIN=GP29--GND
Print "MM.SUPPLY   = "; MM.SUPPLY
VSYS/3=GP29 = 1.62031746
VSYS        = 4.874729915
MM.SUPPLY   = 4.871428571
Jan.
Posted: 07:04pm 27 Jul 2025
But has this stopped working on the Pico?  ;)
OPTION VCC n (where n is the measured 3V3 voltage) - you really need this step anyway
SETPIN GP29 AIN
PRINT PIN(GP29) * 1.51515  (or tweak to suit your particular Pico's divider)
JanVolk
Posted: 07:48pm 27 Jul 2025
Mick,
You'll have to ask Peter.
I tried the example above on a standard RP2040 Raspberry Pi Pico, so > ? MM.SUPPLY
Jan.
JanVolk
Posted: 08:56pm 27 Jul 2025
Mick,
I think Peter took that into account?
Only OPTION LCD BACKLIGHT 0 is a bit unclear?
> option list
PicoMite MMBasic RP2040 Edition V6.01.00b2
OPTION COLOURCODE ON
OPTION HEARTBEAT OFF
OPTION PICO OFF
OPTION CPUSPEED (KHz) 200000
OPTION DISPLAY 44, 80
list pins
GP0      1      OFF
GP1      2      OFF
GP2      4      OFF
GP3      5      OFF
GP4      6      OFF
GP5      7      OFF
GP6      9      OFF
GP7      10     OFF
GP8      11     OFF
GP9      12     OFF
GP10     14     OFF
GP11     15     OFF
GP12     16     OFF
GP13     17     OFF
GP14     19     OFF
GP15     20     OFF
GP16     21     OFF
GP17     22     OFF
GP18     24     OFF
GP19     25     OFF
GP20     26     OFF
GP21     27     OFF
GP22     29     OFF
GP23     41     OFF
GP24     42     OFF
GP25     43     OFF
GP26     31     OFF
GP27     32     OFF
GP28     34     OFF
GP29     44     AIN
Jan.
Bleep
Posted: 11:28am 29 Jul 2025
Hi Peter,
I've been playing with the new BUFFER driver and puerly for my own interest, could you give a bit more info on what is happening in the background.
I tuned the circle drawing (below) to give me about 100 circles per second on the standard driver.
Then using the BUFF driver, set to auto refresh, I get 200 cps, which is fine, but if I turn off auto refresh, and do a refresh every circle, I now get 600 cps?
If I then use the timer to give me a 10Hz refresh I get about 3000 cps?, however there is screen tearing? What is the difference in the background, to what's going on? Is there a function like the Framebuffer sync, to reduce screen tearing?
Thanks for any info.
Regards, Kevin.
PS. I've now found, if I put a Pause 33 after the Refresh command, while doing 10Hz Refresh, I can get about 2000cps without the tearing. :-)
Option AUTOREFRESH Off 'On
Dim Integer a,t
Dim Integer b(15)=(RGB(white),RGB(yellow),RGB(lilac),RGB(brown),RGB(fuchsia),RGB
(rust),RGB(magenta),RGB(red),RGB(cyan),RGB(green),RGB(cerulean),RGB(midgreen),RG
B(cobalt),RGB(myrtle),RGB(blue),RGB(black))
Timer =0
For a=0 To 6000
Circle Rnd*480,Rnd*320,Rnd*68+12,1,,,b(a Mod 16)
If Timer > 99 Then Timer =0:Inc t:Refresh
'Refresh
Next
Print 6000/(0.1*t),t
Edited 2025-07-30 20:52 by Bleep
Posted: 03:30pm 31 Jul 2025
Version 6.01.00b5 files
PicoMiteV6.00.03b5.zip
This should fix the map command for all HDMI resolutions - please report
In addition, the map command and function are now implemented for the new buffered LCD drivers
MAP(n)=RGB888value 'n=0 to 255
MAP SET
MAP RESET
? MAP(n) 'n=0 to 255
NB: It can't be implemented for non-buffered drivers
Amnesie
Posted: 05:44pm 31 Jul 2025
Hi Peter,
that was quick! Can't find any problems with the mapping so far!
Greetings
Daniel
Posted: 07:40am 01 Aug 2025
Fixes bug introduced in b5 in use of PSRAM if CS pin other than GP47 is used
mozzie
Posted: 08:43am 01 Aug 2025
G'day Peter,
Some observations and questions from testing with PicoMiteV6.00.03b5(1)
Tested on HDMIUSB and RP2350HDMI
MAP command appears to be working in all resolutions (mode 3)
MAP Grayscale / Greyscale only works in 640x480 and 720x400 (mode 3), should it work in all resolutions?
Is the MAP function intended to return the current value assigned to a MAP(index) or the default value for the mode? currently only returns default value as far as I can tell.
Unfortunately 1024x600 resolution has dropped back to 30HZ so I can only test on main monitor
Had planned to post some photos of the monitor at 1024x600 but not much point, they do not do the actual screen justice, it is now a pleasure to use
Lyle.
Posted: 08:50am 01 Aug 2025
  Quote  Unfortunately 1024x600 resolution has dropped back to 30HZ so I can only test on main monitor
It hasn't. Your monitor is lying. One of mine does too. The pixel clock is 252MHz which gives exactly 60Hz
  Quote  or the default value for the mode? currently only returns default value as far as I can tell.
This is correct. It returns a value that will allow you to access that map value.
map(0)=RGB(255,0,0)
cls map(0) ' map(0) returns 0 which is the RGB level for BLACK which is normally in location 0 of the map.
  Quote  MAP Grayscale / Greyscale only works in 640x480 and 720x400 (mode 3), should it work in all resolutions?
I'll look at this
mozzie
Posted: 11:27am 01 Aug 2025
G'day Peter,
Thanks for the clarification, some more experimenting required before it finally sinks in 100%
Can I ask you to please verify any changes made when "2025-07-25_025614" and V6.00.03b2 where released are still applied? These worked perfectly with both 1024x600 monitors and showed 60Hz on the main monitor, although this isn't diagnostic as you mention.
With V6.00.03b5 neither 1024x600 units will sync (one does momentarily) and this indicates something has changed.
Lyle.
     Page 2 of 15
