Local Time 16:00 19 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : howto calc whit the %
tenij000
Posted: 09:30am 07 Aug 2025
how do i calc whit the %
most is working whit this program
cls
font 3
' === Elementen ===
GUI TEXTBOX    #1,  20,  20, 200, 30, RGB(0,0,0), RGB(255,255,255) ' Invoerveld
GUI BUTTON     #2, "Bereken", 20, 120, 80, 30, RGB(0,0,0), RGB(0,255,0) ' Knop
GUI DISPLAYBOX #3,  20,  70, 200, 30, RGB(0,0,0), RGB(220,220,220) ' Resultaat
' === Hoofdlus ===
DO
 IF CtrlVal(#2) = 1 THEN
   expr$ = CtrlVal(#1)
   ON ERROR SKIP
   result = EVAL(expr$)
   CtrlVal(#3) = STR$(result)
   CtrlVal(#2) = 0
 ENDIF
 PAUSE 50
LOOP
Martin H.
Posted: 09:57am 07 Aug 2025
I would like to help, but unfortunately I don't understand your problem. Please, can you explain in more detail what the program is supposed to do and what you need as a percentage.
How to calculate percentages:
A percentage is a way to express a number as a part of 100.
To calculate a percentage, use this formula:
👉 (Part ÷ Whole) × 100 = Percentage
Example:
If you got 18 points out of 20 on a test:
(18 ÷ 20) × 100 = 90%
So, you scored 90%.
Edited 2025-08-07 20:01 by Martin H.
'no comment
tenij000
Posted: 10:47am 07 Aug 2025
it is calc but cant calc % the + - * / all work
Posted: 11:12am 07 Aug 2025
% isn't a valid operator - see the manual. You have to do it by normal operators as per Martin's post
Posted: 11:19am 07 Aug 2025
There is no % maths function in MMBasic. The % symbol is used to denote an integer variable.
If you want a percentage function you will need to write it. e.g.
FUNCTION PC(percentage, number)
 PC = (percentage/number) * 100
END FUNCTION
a = PC(18,20)
This might be better than calculating percentages repeatedly in-line in some cases.
twofingers
Posted: 11:35am 07 Aug 2025
Possibly the "Mod" operator is meant.
Ragards
Michael
Martin H.
Posted: 02:12pm 07 Aug 2025
And the other way round, if you want to know how much x% of a number is
part=(Whole/100)*Percentage
@twofingers MODulo determines the remainder of a division e.g. 7 MOD 4 =3
Edited 2025-08-08 00:23 by Martin H.
'no comment
twofingers
Posted: 02:29pm 07 Aug 2025
Hi Martin,
  Martin H. said  ...
That's exactly how it is! And in other programming languages, '%' is the modulo operator. Could it be that the OP knows languages other than MMBasic?
I don't see that the OP asked about percentages.
MMBasic Manual  p24:
* / \ MOD
Multiplication, division, integer division and modulus (remainder)
Michael
Martin H.
Posted: 02:41pm 07 Aug 2025
  twofingers said  in other programming languages, '%' is the modulo operator.
MMBasic Manual  p24:
* / \ MOD
Michael
Hi Michael,
of course you're right, I hadn't considered that
Edited 2025-08-08 00:42 by Martin H.
'no comment
