Local Time 16:00 19 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Clock Clock 24
Bleep
Posted: 09:39am 26 Aug 2025
A forum member has asked me for a 240*320 LCD version of my Clock Clock 24, clock!
I can't attach a zip to a PM, so I have put it here.
In this version, the LCD backlight is controlled, you can increase it by touching the Left top of the screen, decrease it by touching the Left Bottom of the screen, otherwise it will set a brightness it thinks is appropriate for the time of day. If you haven't set up backlight, then comment out the 3 places where Backlight is set.
If you havent set up touch, then comment out the touch handeling in subroutine Brightness, from:-
'change brightness using screen touch
'Set screen brightness for dusk
There is a UK/USA date format option built in, set as appropriate.
Think that covers it.
Regards, Kevin.
3clockclock240.zip
Edited 2025-08-26 20:03 by Bleep
