Local Time 18:08 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : I did it again :-(
OA47
Posted: 05:42am 11 Sep 2025
Just spent the last 3-4 days coding a new project on a PicoVGA connected to TeraTerm and powered by the USB cable. I left it running overnight to see if there were any issues and this morning I was greeted by MSOFT telling me the PC needs a restart. Guess what I did ?
Unfortunately, I have been to used to programming mites and forgot to save the code to flash or the PC so when the PC came back the Pico was blank.
OA47
Posted: 06:34am 11 Sep 2025
Oh dear. :(
You will stray from the golden path to true enlightenment though! Such futile actions cannot go unpunished in some way.  ;)
It's like nudging the ram pack on a ZX81 when you are just entering the last line of the program that you are copying from a magazine. Only this time you have Microsoft to help. :(
OA47
Posted: 07:00am 11 Sep 2025
You remind me of the days I had my first 8 bit computer where I would delay the saving of the program until the last minute as it took ages to save on cassette. I vividly remember the sound of thunder in the background and the knowledge that a lightning strike even kilometers away was enough to rest the computer.
OA47
Posted: 07:10am 11 Sep 2025
OA47,
If you have ever RUN the program on the PicoVGA, then it is still in flash. Simply open teraterm, and type "LIST", or "F2"(edit)
To erase a program from flash you actively have to execute a "NEW", or update the firmware (i.e. from 5.08.00 to 6.00.03). Otherwise the program is still there.
Edited 2025-09-11 17:10 by Volhout
atmega8
No backup, no mercy
OA47
Posted: 07:31am 11 Sep 2025
Unfortunately if I list from Teraterm I get nothing. The PicoVGA is running ver 5.0704 and memory reports:
Program:
  0K ( 0%) Program (0 lines)
108K (100%) Free
RAM:
  0K ( 0%) 0 Variables
  0K ( 0%) General
140K (100%) Free
OA47
Posted: 08:06am 11 Sep 2025
Hi OA47,
Maybe this is the time to upgrade to 6.01.00b11. It is simply 1 button press, and a drag and drop.
I think the earliest ports of MMbasic on RP2040 ran the code in RAM. Maybe 5.07.04 was that early version (although I think 5.07.04 was already flash based). Later versions are running from flash, while maintaining similar speed.
OA47
Posted: 09:58pm 11 Sep 2025
As an afterthought, I was wondering as Teraterm was still running after the PC re-boot could I have been able to look at the history and got most of the code back ?
OA47
Posted: 11:35pm 11 Sep 2025
Tested with a Windows restart.
Answer:- No not with TeraTerm 5.2. TeraTerm restarted with an empty buffer.
As for the PicoMite (RP2040 V6.01.00b11) it continued to run its program without a hiccup throughout the restart.
Perhaps a Windows Update is different. If it starts the virtual com port at 1200 baud the Pico would go into Firmware Update mode. If Windows sees that as a corrupt USB drive it may try to "repair" it.
Posted: 02:00am 13 Sep 2025
Tested with Windows Update.
Pico connected to TeraTerm and program running then let Windows do the update.
Once again  the PicoMite continued to run its program without a hiccup throughout the update.
So what happened to yours remains a mystery.
OA47
Posted: 02:15am 13 Sep 2025
Phil, I did notice an error message from mmbasic during both of the re-boots of the PC but they were only visable for a split second and I could not interpret them.
OA47
Edited 2025-09-13 12:16 by OA47
