Local Time 18:17 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PICAXE program fault
Chrisk
Posted: 09:35am 22 Sep 2025
Hi Guys
Can someone advise me why  the program below does not work.
I doesn't seem to get past the loop until C.3 = 1
If I change the trigger from low to high nothing happens.
After all this time I still don't how to put the code into that "Blue code Box"
Maybe someone could advise on that too.
Chrisk
'my attempt PICAXEFinal.bas  22/9/2025
'Overview: If Trig is 0 then loop and wait
'If trigger goes high start 2 min timer
'at end if still high set output C2 High for 2 min
'repeat until trigger goes low then output goes low
'at end of 2 min timing cycle.
#picaxe 08m2 'Identify the PICAXE being used as an 08M2.
#no_data     'No data tranfer required
Symbol X=b0 'Variable for the timer loop needs to be here ???
OUTPUT C.0 'C.0 not used
OUTPUT C.1 'C.1 not used
OUTPUT C.2 'MOSFET driver
INPUT  C.3 'Trigger
INPUT  C.4 'C.4 not used
Low C.2 'FAN/MOSFET OFF ensure on power up
Main:
Do:Loop until PinC.3=1  ' pinC.3 = 0 then Low C.2 FAN/MOSFET OFF
pause 1000
loop
gosub Timx  ' wait 2 min before FAN/MOSFET ON
do
If pinC.3 = 1 then High C.2 ' Trigger High FAN/MOSFET ON
pause 1000
loop
else  ' Trigger has gone Low
gosub Timx  ' Fan continues for 2 min
gosub Main
endif
Timx:
for x=1 to 5 ' 1 to 120 for 2 min - 5 for test purposes
pause 1000
next x
return
Posted: 10:10am 22 Sep 2025
Hi Chrisk,
Indenting code helps in understanding how the flow is.
OUTPUT C.0 'C.0 not used <--------------- C.0 IS PROGRAMMER PIN, DO NOT RE-CONFIGURE
INPUT  C.3 'Trigger
Main:
 Do : Loop until PinC.3=1  ' pinC.3 = 0 then Low C.2 FAN/MOSFET OFF
 pause 1000
loop
do
   pause 1000
   loop <-------------------------- WHAT IS THIS DOING HERE ?
   gosub Main
 endif
<-----------------------------LOOP MUST BE HERE ???
Timx:
 pause 1000
next x
return
Posted: 12:04pm 22 Sep 2025
Also, the gosub Main within Main is asking for trouble.
Posted: 02:06pm 22 Sep 2025
As above, LOOP in the wrong place, and you probably don't need 2 loops--just one and no "goto Main" (which you perhaps meant instead of the very wrong "gosub Main").
The PICAXE debugger is your friend. You can single step through your code to see what is actually happening (which all to often is different from what one thinks is happening).
To get your posted code in the "blue box", you can click on the "code" button and paste your code within the forum tags that have then been inserted in the edit window.
Edited 2025-09-23 00:10 by lizby
