Local Time 02:23 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 1x16 LCD
mace
Posted: 01:17pm 07 Oct 2025
Hi.
I Have 1x16 LCD. When using pico intepreter, first eight characters is displaying,rest not. I know reason for this. I can manipulate program to display all 16 characters. But,is there easy way on mmbasic to display all 16 characters?
Thanks.
Posted: 01:53pm 07 Oct 2025
Are you working from the MMBasic manual?
As far as I know there's nothing that would prevent you from displaying all 16 characters at once provided the display is the correct sort and has been connected and initialised properly.
  Quote  To setup the display you use the DEVICE LCD INIT command:
LCD INIT d4, d5, d6, d7, rs, en
  Quote  To display characters on the module you use the LCD command:
LCD line, pos, data$
In your case "line" will always be 1. If "pos" is 1 it starts at the first character on the line. "data$" can then be a string of up to 16 characters for a 16 character display.
Unfortunately I haven't got a display to test with at the moment.
mace
Posted: 02:48pm 07 Oct 2025
Ok.
I mean like this
https://gcbasic.sourceforge.io/help/_lcd_variant.html
vegipete
Posted: 03:45pm 07 Oct 2025
As your link shows, position 9 is not immediately after position 8. Instead, it is in memory location 40. (Might be hex, not decimal.)
Posted: 06:10pm 07 Oct 2025
There's no equivalent of LCD_VARIANT in MMBasic. All you can do is add a constant to pos when necessary. You need all the details of that particular LCD to see how the memory is laid out.
