Local Time 02:18 15 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMEdit V5.3.4
     Page 4 of 4
Turbo46
Posted: 05:54am 22 Jan 2026
Thanks Jim
panky
Posted: 03:10am 25 Jan 2026
Hi Jim,
Would it be possible to add the version number to the download box on geoff's site?
Secondly, running Linux Mint 22.2 Cinnimon, MMCC likes to take over complete control both during upload and if anything is happening in the monitor window ( won't even just stay in it's own workspace)? Could this be a focus issue in my config?
Doug.
Posted: 04:31am 25 Jan 2026
  Quote  Would it be possible to add the version number to the download box on Geoff's site?
Sorry.
Geoff has kindly supplied the space on his website and one requirement is that I am restricted to the one file which retains the same name.
  Quote  MMCC likes to take over complete control
It sounds like MMCC is using too much CPU. This probably means that you are sending data at a high rate.
Try this test program
n = 1
DO
PRINT "fred",STR$(n)
PAUSE 100
INC n
LOOP
While running 'top' or similar, change the PAUSE to a smaller value and watch the CPU utilisation.
On my old Linux box, I can run other programs without any obvious issues with MMCC using 50%+ CPU
MMCC is not good at handling high data rates.
If you regularly send high volumes of data, perhaps a better terminal program is needed.
Try Rob's GFXterm
     Page 4 of 4
