Local Time 02:24 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 DRAW3D Function - Is it obsolete?
disco4now
Posted: 09:47pm 07 Dec 2025
I am working on the CMM2 code. I have found the DRAW3D Function in the code. It is not mentioned in the CMM2 3D Engine PDF and a search on TBS found only this thread that reference to it. I extracted the example program and it is below.
The DRAW3D function errors on the current released Version 5.07.01 and also on all the latest betas I tried.
Is the DRAW3D function obsolete, can I removed it.
Example using DRAW3D Function
option explicit
option default float
dim integer viewplane = 500
const camera = 1
dim q(4)
dim yaw=rad(1),pitch=rad(2),roll=rad(0.5)
dim integer nv=9, nf=9 ' cube has 9 vertices and 9 faces
'array to hold vertices
dim v(2,nv-1)=(-1,1,-1, 1,1,-1, 1,-1,-1, -1,-1,-1, -1,1,1, 1,1,1, 1,-1,1, -1,-1,1, 0,0,0)
math scale v(),200,v()
' array to hold number of vertices for each face
dim integer fc(nf-1) =(4,4,4,4,4,3,3,3,3)
dim integer cindex(9)=(rgb(red),rgb(blue),rgb(green),rgb(magenta),rgb(yellow),rgb(cyan),rgb(white),rgb(brown),rgb(gray),0)
dim integer fcol(nf-1)=(9,9,9,9,9,9,9,9,9)
dim integer bcol(nf-1)=(0,1,2,3,4,5,6,7,8)
'array to hold vertices for each face
dim integer fv(math(sum fc())-1)=(1,5,6,2, 1,0,4,5, 0,3,7,4, 5,4,7,6, 2,6,7,3, 0,1,8, 1,2,8, 3,8,2 , 3,0,8)
draw3d create 1, nv, nf, camera, v(), fc(), fv(),cindex(),fcol(),bcol()
dim integer c
page write 1
draw3d camera 1,viewplane, mm.hres\2, mm.vres\2
do
for c=0 to 720
timer=0
math q_create roll,1,1,1,q()
draw3d show 1,mm.hres\2,mm.vres\2,1000
' math q_euler yaw,pitch,roll,q()
draw3d rotate q(),1
print @(0,0)draw3d(XMIN 1),@(64)draw3d(xmax 1),@(128)draw3d(ymin 1),@(192)draw3d(ymax 1)
' inc yaw,rad(1)
' inc pitch,rad(2)
inc roll,rad(0.5)
page copy 1 to 0,b
next
loop
draw3d close all
F4 H7FotSF4xGT
Posted: 12:26pm 08 Dec 2025
It should be there and should work. The bug is in allcommands,h where the definitions is for it to return an int and it actually returns a float
{ "DRAW3D(",    T_FUN | T_INT, 0, fun_3D,    },
should be
{ "DRAW3D(",    T_FUN | T_NBR, 0, fun_3D,    },
In the example it is used to demonstrate how it could be used to define an area to be erased before re-drawing
disco4now
Posted: 09:56pm 08 Dec 2025
Peter,
Thanks that fixed it.
DRAW3D Function corrected and now works as expected.
I will add this to the manual.
The DRAW3D function can be used to determine the boundaries of a 3D object and could be used to define an area to be erased before re-drawing.
DRAW3D(XMIN n)'returns the leftmost x coordinate of a box bounding the render of 3d object n on the screen
DRAW3D(XMAX n)'returns the rightmost x coordinate of a box bounding the render of 3d object n on the screen
DRAW3D(YMIN n)'returns the upper y coordinate of a box bounding the render of 3d object n on the screen
DRAW3D(YMAX n)'returns the lower y coordinate of a box bounding the render of 3d object n on the screen
DRAW3D(DISTANCE n)'Returns distance to the box bounding the object n
DRAW3D(X n)'returns the x coordinate in the world current used to display 3D object n
DRAW3D(Y n)'returns the y coordinate in the world current used to display 3D object n
DRAW3D(Z n)'returns the y coordinate in the world current used to display 3D object n
Edited 2025-12-09 08:22 by disco4now
F4 H7FotSF4xGT
vegipete
Posted: 06:40pm 09 Dec 2025
Is there any chance that this could be expanded to report the screen coordinates of the vertices (or more likely, a given vertex) of the render of a given 3d object?
For example,
DRAW3D(X n,v)
would return the x-coord of vertex number v of object number n. Coordinates beyond screen limits would still be valid.
Towards the end of the function void display3d(  ...params...  ) in Draw.c, each face is drawn using DrawPolygon(n, xcoord, ycoord, sortindex), so these coordinates are known, at least for a period of time. A way to access them would allow, for example, interacting with rendered objects. (I'm pondering a program to interactively draw/generate 3D objects.)
PeteCotton
Posted: 11:52pm 10 Dec 2025
  disco4now said  I am working on the CMM2 code. I have found the DRAW3D Function in the code. It is not mentioned in the CMM2 3D Engine PDF
I have been looking for a function like this. I thought about asking for it to be written - but didn't want to bother anyone. Thank you!
*I have 3D ships on the screen and want to print a distance value underneath each 3D object - but didn't have an easy way to translate a 3D point/object on to the 2D screen. This should work perfectly.
