Local Time 15:36 15 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite Firmware Release Version 6.01.00
     Page 1 of 6
Posted: 03:19am 17 Dec 2025
Peter has released the final version of the PicoMite firmware V6.01.00 along with the updated user manual.
This can be downloaded from https://geoffg.net/picomite.html (scroll to the bottom of the page).
WARNING: Loading this firmware will erase all data stored in the flash memory.
This release has a huge list of new functionality and enhancements.  For the full list see the file RELEASE NOTES.txt in the firmware download, however this is a summary:
New Commands/Functions
ON ERROR RESTART
TRIM$
PLAY ARRAY
MM.SUPPLY
DEVICE(MOUSE)
LINPUT()
LMID()
FLASH LOAD IMAGE
BLIT FLASH
FILL
YMODEM
TURTLE GRAPHICS
Enhanced Functionality
KEYPAD enhancements
High speed buffered display drivers
Additional HDMI/VGA modes
USB mouse sensitivity control
EDITOR enahncements
REDIM new option: PRESERVE
DEVICE() now works for USB mice
PIO programming enhancements
AUTOSAVE enhancement
Keyboard enhancements
New LOAD JPG options
DRAW3D enhancements
Bug Fixes
Fixes bug in PULSE command on GP pins > 31
Fixes bugs in DEVICE SERIAL TX and DEVICE SERIAL RX including support for all pins on the RP2350B
Correctly validates maximum file lengths in numerous places in the firmware
Fixes bug in MAP command for some HDMI resolutions
Fixes bug in changing HDMI mode causing occasional crashes
Fixes memory leak when a framebuffer is created in HMDI 1280x720 mode 1
Fixes lockup in FRAMEBUFFER SYNC if a previous MERGE has not been executed.
Fixes bug in STATIC variables
Fixes bug in PIO PROGRAM LINE
Fixes bug in MM.INFO(EXISTS FILE fname$)
Fixes bug in XMODEM for RP2040
Fixes bug in reading zero length files - all versions
Fixes a couple of typos in the PIO assembler
Fixes a typo in reading escape sequences
Fixes a bug in ADC START
toml_12953
Posted: 07:53am 17 Dec 2025
  Geoffg said  Peter has released the final version of the PicoMite firmware V6.01.00 along with the updated user manual.
In the manual on page 101 it says the max CPUSPEED is 378000 KHz. MMBasic allows 396000  KHz to be entered and it's running on my system at the higher speed with no issues.
Posted: 08:38am 17 Dec 2025
Thanks.
To avoid cluttering this topic I will start a new one for manual updates/corrections.
twofingers
Posted: 09:08am 17 Dec 2025
deleted
Edited 2025-12-17 19:09 by twofingers
ville56
Posted: 09:14pm 17 Dec 2025
what is the idea behind leaving the touch subsystem in HDMI/VGA versions? Are HDMI/VA panels available that also have touch implemented?
73 de OE1HGA, Gerald
Posted: 10:20am 18 Dec 2025
In 6.01.00 there is one new command which wasn't mentioned before
BEZIER - see the manual for details but here is my test program
Option DEFAULT INTEGER
Option EXPLICIT
MODE 3
CLS
Sub ShowCurve(x(), y(), n, colour, title$)
   CLS
   Text 10, 10, title$, , , 1
   Bezier x(), y(), n, colour
   Pause 3000
End Sub
' One petal, closed
Dim fx%(3) = (320, 380, 450, 320)
Dim fy%(3) = (240, 100, 100, 240)
Math SCALE fx%(),MM.HRES/640,fx%()
Math SCALE fy%(),MM.VRES/480,fy%()
' 2. SPIRAL (multi-point Bzier path)
'    (approximation using many control points)
Dim sx(10) = (320, 380, 420, 450, 430, 360, 260, 200, 180, 230, 320)
Dim sy(10) = (240, 230, 200, 140, 90, 70, 100, 180, 260, 300, 320)
Math SCALE sx(),MM.HRES/640,sx()
Math SCALE sy(),MM.VRES/480,sy()
' 3. WAVY RIBBON (smooth horizontal wave)
Dim wx(6) = (20, 120, 220, 320, 420, 520, 620)
Dim wy(6) = (240, 120, 360, 120, 360, 120, 240)
Math SCALE wx(),MM.HRES/640,wx()
Math SCALE wy(),MM.VRES/480,wy()
' 4. SIGNATURE-STYLE CURVE (fancy stroke)
Dim sigx(7) = (40, 120, 200, 320, 420, 500, 600, 580)
Dim sigy(7) = (300, 260, 320, 200, 260, 180, 260, 300)
Math SCALE sigx(),MM.HRES/640,sigx()
Math SCALE sigy(),MM.VRES/480,sigy()
' 5. Previous demo shapes (S-curve, loops, etc.)
Dim x1(3) = (50, 200, 440, 590)
Dim y1(3) = (400, 50, 430, 80)
Math SCALE x1(),MM.HRES/640,x1()
Math SCALE y1(),MM.VRES/480,y1()
Dim x2(5) = (100, 300, 300, 200, 440, 540)
Dim y2(5) = (240, 480, 0,   400, 80,  240)
Math SCALE x2(),MM.HRES/640,x2()
Math SCALE y2(),MM.VRES/480,y2()
Dim x3(12) = (320,390,441,460,441,390,320,250,199,180,199,250,320)
Dim y3(12) = (240,309,309,240,171,171,240,309,309,240,171,171,240)
Math SCALE x3(),MM.HRES/640,x3()
Math SCALE y3(),MM.VRES/480,y3()
Dim x4(5) = (320, 600, 40, 560, 100, 320)
Dim y4(5) = (450, 380, 140, 200, 60, 30)
Math SCALE x4(),MM.HRES/640,x4()
Math SCALE y4(),MM.VRES/480,y4()
Dim hx1(3) = (320, 190, 190, 320)
Dim hy1(3) = (350, 200, 100, 160)
Math SCALE hx1(),MM.HRES/640,hx1()
Math SCALE hy1(),MM.VRES/480,hy1()
Dim hx2(3) = (320, 450, 450, 320)
Dim hy2(3) = (160, 100, 200, 350)
Math SCALE hx2(),MM.HRES/640,hx2()
Math SCALE hy2(),MM.VRES/480,hy2()
Dim x6(4) = (50, 300, 200, 580, 400)
Dim y6(4) = (420,350, 50, 120, 300)
Math SCALE x6(),MM.HRES/640,x6()
Math SCALE y6(),MM.VRES/480,y6()
'                     MAIN LOOP
   DrawFlower()
   ShowCurve sx(), sy(), 11, RGB(YELLOW),  "Spiral Sweep (11 points)"
   ShowCurve wx(), wy(), 7,  RGB(CYAN),    "Wavy Ribbon Pattern"
   ShowCurve sigx(), sigy(), 8, RGB(WHITE),"Signature-Style Stroke"
   ShowCurve x1(), y1(), 4, RGB(YELLOW),  "Smooth S-Curve Ribbon"
   ShowCurve x2(), y2(), 6, RGB(CYAN),    "Loop-de-Loop"
   ShowCurve x3(), y3(), 13, RGB(RED),     "Figure-Eight"
   ShowCurve x4(), y4(), 6, RGB(GREEN),   "Spiral-Sweep Path"
   CLS
   Text 10,10,"Heart Shape",,,1
   Bezier hx1(), hy1(), 4, RGB(RED)
   Bezier hx2(), hy2(), 4, RGB(RED)
   Fill MM.HRES\2,MM.VRES\2,RGB(red)
   Pause 3000
   ShowCurve x6(), y6(), 5, RGB(WHITE), "Abstract Dragon Stroke"
Sub DrawFlower()
   Local i, p
   Local float angle, r
   Local dx, dy, x, y
   Local rx!(3), ry!(3)   ' FLOATING ARRAYS
   Local xi%(3), yi%(3)
   CLS
   Text 10,10,"Flower (12 petals)",,,1
   For i = 0 To 11
       angle = i * 30
       r = angle * Pi / 180
       For p = 0 To 3
           dx = fx%(p) - MM.HRES\2
           dy = fy%(p) - MM.VRES\2
           rx!(p) = MM.HRES\2 + dx * Cos(r) - dy * Sin(r)
           ry!(p) = MM.VRES\2 + dx * Sin(r) + dy * Cos(r)
       Next p
       ' Convert float
       For p = 0 To 3
           xi%(p) = Cint(rx!(p))
           yi%(p) = Cint(ry!(p))
       Next p
       Bezier xi%(), yi%(), 4, RGB(MAGENTA)
       x=0
       y=0
       For p= 0 To 3
         Inc x,xi%(p)
         Inc y,yi%(p)
       Next
       Fill x\4,y\4,RGB(yellow)
   Next i
   Pause 3000
End Sub
Posted: 12:14pm 18 Dec 2025
Geoff, Peter,
Congratulations with this "final" release for PicoMite.
I see benefit in this last addition (Bezier function) for representing waveform graphs (i.e. oscilloscope picture) when there are only few datapoints. Linear interpolation gives a mediocre representation.
Tested in mode 1 on RP2040 VGA
Thank you both for this release. I already updated 50% of my platforms, and these all appear to start up fine and run their intended programs.
Posted: 01:29pm 18 Dec 2025
You should have said you wanted some curve fitting before I finished the release. I've just implemented a sin(x)/x (sinc function) including sinc interpolation
red = original points
yellow = 1:1 smoothing
green = interpolated output
' Demo: unified SINC smoothing vs interpolation
OPTION EXPLICIT
mode 2
CLS
CONST N = 40          ' input points
CONST M = 120         ' resampled output points (m != n triggers interpolation)
CONST WIN = 17        ' window size (odd)
CONST FREQ = 0.12     ' normalized cutoff (0<freq<=0.5)
DIM x_in(N), y_in(N)
DIM x_s(N), y_s(N)       ' smoothed outputs (m omitted => smoothing)
DIM x_out(M), y_out(M)   ' resampled outputs (m provided => interpolation)
DIM i%, xi%, yi%
' Build a test waveform that fits the screen
FOR i% = 0 TO N - 1
 x_in(i%+1) = (MM.HRES - 1) * i% / (N - 1)
 y_in(i%+1) = (MM.VRES\2) + (MM.VRES\3) * SIN(2 * PI * i% / 12) + 0.15 * MM.VRES * SIN(2 * PI * i% / 5)
 IF y_in(i%+1) < 0 THEN y_in(i%+1) = 0
 IF y_in(i%+1) > MM.VRES - 1 THEN y_in(i%+1) = MM.VRES - 1
NEXT
' Smoothing (m omitted => m=n internally)
MATH SINC x_in(), y_in(), N, WIN, FREQ, x_s(), y_s()
' Interpolation/resampling (m provided)
MATH SINC x_in(), y_in(), N, M, WIN, FREQ, x_out(), y_out()
' Clear and draw axes
CLS
LINE 0, MM.VRES\2, MM.HRES-1, MM.VRES\2, 1, RGB(GREY)
LINE 0, 0, 0, MM.VRES-1, 1, RGB(GREY)
' Plot original points in red
FOR i% = 1 TO N
 xi% = INT(x_in(i%))
 yi% = INT(y_in(i%))
 IF xi% >= 0 AND xi% < MM.HRES AND yi% >= 0 AND yi% < MM.VRES THEN PIXEL xi%, yi%, RGB(RED)
NEXT
' Plot smoothed points in yellow
FOR i% = 1 TO N
 xi% = INT(x_s(i%))
 yi% = INT(y_s(i%))
 IF xi% >= 0 AND xi% < MM.HRES AND yi% >= 0 AND yi% < MM.VRES THEN PIXEL xi%, yi%, RGB(YELLOW)
NEXT
' Plot resampled points in green, slightly offset upward for visibility
FOR i% = 1 TO M
 xi% = INT(x_out(i%))
 yi% = INT(y_out(i%)) - 2  ' small offset for visibility
 IF yi% < 0 THEN yi% = 0
 IF yi% >= MM.VRES THEN yi% = MM.VRES - 1
 IF xi% >= 0 AND xi% < MM.HRES THEN PIXEL xi%, yi%, RGB(GREEN)
NEXT
Edited 2025-12-18 23:31 by matherp
Posted: 01:44pm 18 Dec 2025
Hi Peter,
Nice, but I am not working on such now, but it is always on the back of my mind.
Posted: 02:34pm 18 Dec 2025
RP2350 versions of V6.01.00 implements a celestial navigation system that calculates the altitude and azimuth of celestial objects (stars, Moon, and planets) from an observer's location on Earth. Attached is a document explaining the functionality for those interested.
GPS_Astro_Reference.pdf
toml_12953
Posted: 04:08pm 18 Dec 2025
  matherp said  RP2350 versions of V6.01.00 implements a celestial navigation system that calculates the altitude and azimuth of celestial objects (stars, Moon, and planets) from an observer's location on Earth. Attached is a document explaining the functionality for those interested.
When I put in location data, the astro command gives me this:
>location "18/12/2025 11:03:00",44.8488,-74.2937
>astro "Vega",a,az,ra,dec
Error : Argument count
Edited 2025-12-19 02:11 by toml_12953
Posted: 04:54pm 18 Dec 2025
Two faults, one in the pdf and one in the code. PDF attached and I'll ask Geoff to update the download.
Posted: 10:45pm 18 Dec 2025
Geoff has kindly updated the download. 6.01.00 as downloaded now fixes the TAB bug and fixes the ASTRO/STAR bug. The manual has also been updated with various minor changes identified. make sure you clear you cache to get a clean download of the updated zip
Edited 2025-12-19 08:46 by matherp
toml_12953
Posted: 12:40am 19 Dec 2025
  matherp said  Geoff has kindly updated the download. 6.01.00 as downloaded now fixes the TAB bug and fixes the ASTRO/STAR bug. The manual has also been updated with various minor changes identified. make sure you clear you cache to get a clean download of the updated zip
The TAB function works great. Thanks! I still can't enter
though. What am I doing wrong?
Edited 2025-12-19 15:30 by toml_12953
Posted: 08:09am 19 Dec 2025
The manual for astro is still wrong use the syntax for star
Updated manual attached
Edited 2025-12-19 18:16 by matherp
Amnesie
Posted: 12:13pm 19 Dec 2025
Hi Peter,
just a quick question:
I've recently ordered some Pico2 and saw that there is a new "a4 stepping" of the chip available. Does the MMBASIC firmware work with the new chips (they have corrected the ADC issues etc.)?
Greetings
Daniel
Edited 2025-12-19 22:14 by Amnesie
Posted: 12:31pm 19 Dec 2025
  matherp said  You should have said you wanted some curve fitting before I finished the release. I've just implemented a sin(x)/x (sinc function) including sinc interpolation
Thanks for "sneaking" MATH SINC in in all versions (also RP2040). Really appreciated.
Merry Christmas...
Posted: 12:39pm 19 Dec 2025
  Quote  I've recently ordered some Pico2 and saw that there is a new "a4 stepping" of the chip available. Does the MMBASIC firmware work with the new chips (they have corrected the ADC issues etc.)?
The firmware is compiled with sdk v2.2.0 which supports the A4 stepping chips so I assume it works. I just bought a couple of Pico2's but they still came with A2 chips fitted so I can't test to confirm.
ville56
Posted: 01:17pm 19 Dec 2025
It definitely works, I've already tried it.
Posted: 02:16pm 19 Dec 2025
I've asked Geoff to include this in the next update of the manual but in the meantime be aware there is a very nice new MATH sub command in 6.01.00. The sinc command implements the same sin(x)/x smoothing typically used by digital oscilloscopes. Example code is in my post just above. The result is pretty impressive IMHO.
 MATH SINC x_in(), y_in(), n , m, window, freq, x_out(), y_out()
 MATH SINC x_in(), y_in(), n, window, freq, x_out(), y_out()
 Apply a windowed sinc filter to smooth or interpolate coordinate data.
   A sinc filter is an ideal low-pass filter that removes high-frequency noise while preserving
   the signal shape. It is particularly good for resampling (interpolation).
   Parameters:
     x_in(), y_in() : Input coordinate arrays (float)
     n              : Number of input points
     m              : Number of output points (optional)
                      - If omitted or m=n: Smoothing mode (output size n)
                      - If m!=n: Interpolation/Resampling mode (output size m)
     window         : Filter kernel size (must be odd; even values are incremented).
                    Typical values: 15 to 101. Larger values give a sharper cutoff but are slower.
     freq           : Normalized cutoff frequency (0.0 < freq <= 0.5).
                      0.5 is the Nyquist frequency (no filtering).
                      Typical values: 0.1 (heavy smoothing) to 0.4 (light smoothing).
     x_out(), y_out(): Output coordinate arrays (must be large enough to hold output)
     Page 1 of 6
