Local Time 17:11 19 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PIO and RP2040 V6.01.00 and PIO READ/WRITE Questions
homa
Posted: 04:11pm 02 Jan 2026
I'm trying my hand at PIOs and mmBasic again. Unfortunately, the responses are not as expected.
I'm using an rp2040, i.e., Pi Pico.
Thanks @Volhout for the tips so far. Especially regarding the difference between 2350 and 2040 and the new commands.
Shouldn't the interrupt trigger here?
My test program:
> option list
PicoMite MMBasic RP2040 V6.01.00
OPTION COLOURCODE ON
OPTION CONTINUATION LINES ON
OPTION CPUSPEED (KHz) 200000
OPTION DISPLAY 40, 80
'PIO TEST FIFO
Option explicit
Dim pio_0_FSTAT% = &h50200000 + &h4 'PIO0 Register Offset + Register FSTAT
Dim integer fifoR(3), fifoW(3)
Dim integer ffR, ffW, tmp
Array Set 0,fifoR()
Array Set 0,fifoW()
ffW=0
PIO clear 0
PIO ASSEMBLE 0,".program bsp1"
PIO ASSEMBLE 0,".wrap target"
PIO ASSEMBLE 0, "pull block"
PIO ASSEMBLE 0, "mov isr, osr"
PIO ASSEMBLE 0, "push block"
PIO ASSEMBLE 0,".wrap"
PIO ASSEMBLE 0,".end program list"
PIO CONFIGURE 0,0,10000,,,,,,,,,,,,,Pio(.wrap target),Pio(.wrap)
PIO interrupt 0,0,pRX,pTX
PIO START 0,0
'PIO interrupt 0,0,pRX,pTX
Print "pause 1sec"
Pause 1000
'TEST FIFO
' 1. read
Print "FSTAT: ";Bin$(Peek(word pio_0_FSTAT%),32)
PIO READ 0,0,4,fifoR()
Math V_PRINT fifoR(), hex
' 2. write
Print "Schreiben"
PIO write 0,0,4,&h1,&h2,&h3,&h4
Pause 10
Pause 10
' 3. read again - interrupt?
pRX
Pause 10
Sub pRX
 Print "Pio FiFo RX"
 Array Set 0,fifoR()
 Print "Pio Fifo RX - END"
End Sub
Sub pTX
 Print "Pio FiFo TX / TX - End"
End Sub
And the outputs (1. directly after startup | 2. after Ctrl-C and RUN):
Copyright 2011-2025 Geoff Graham
Copyright 2016-2025 Peter Mather
> run                                              <---- 1x
0: 80A0
1: A0C7
2: 8020
pause 1sec
FSTAT: 00001111000000000000111100000000
EA0A9814, EA0A9814, EA0A9814, EA0A9814
Schreiben
FSTAT: 00001111000000000000111000000001
Pio FiFo RX
1, 2, 3, 4
Pio Fifo RX - ENDE
> run                                              <---- 2x
0: 80A0
1: A0C7
2: 8020
pause 1sec
1, 1, 1, 1
Schreiben
Pio FiFo RX
1, 2, 3, 4
Pio Fifo RX - ENDE
FSTAT explanation from the rp2040-manual:
00001110000000010000111000000001
       |       |       |       3:0 RXFULL: State machine RX FIFO is full
       |       |       11:8 RXEMPTY: State machine RX FIFO is empty
       |       19:16 TXFULL: State machine TX FIFO is full
       27:24 TXEMPTY: State machine TX FIFO is empty
I'm just trying to write data to the TX-Fifo/OSR, PIO reads it WORD and writes it directly back to the ISR/RX-FIFO.
My expectation is that the interrupt should trigger.
If there is nothing in the RX-FIFO, any values/garbage are okay.
But a PIO CLEAR does not reset it either?!
After the first start, Ctrl-C, and restart, the 1 always appears (i.e., the last value from the shift-in?!)
Only a reset instead of the PIO CLEAR brings back the initial values.
Should a PIO READ return nothing/no values if the FIFO is empty (e.g., -1 to distinguish it from 0)?
Why is there no interrupt?
Can anyone point me in the right direction? I feel like I'm on the wrong track.
Matthias
Edited 2026-01-03 02:13 by homa
Posted: 05:56pm 02 Jan 2026
I have to check how the interrupt works, or not. Maybe you have to set fifo thresholds before the interrupt happens. I am not used to PIO CONFIGURE, always used PIO INIT MACHINE.
But I can Tell you that PIO read (mmbasic side) always returns, even when there is no data in Fifo.
It returns with the last value from fifo. You dont want mmbasic to stall if fifo is empty.
That is why you can read 5 valies from a 4 deep fifo. It Will always return the most recent value as 5th. The 4th in fifo, or the one being pushed while MMBasic empties the 4.
PIO CLEAR N should clear FIFO’s
Edited 2026-01-03 04:02 by Volhout
Posted: 06:27pm 02 Jan 2026
Just reading the user manual on pio interrupt
TX interrupt only happens when TX FIFO is full. When you push 4 values, and have a PIO state machine "waiting" (PULL BLOCK) the first value will be pulled before you write the 4'th into FIFO. So the TX interrupt will never happen. FIFO is never full.
You can try this by stopping the PIO, and pushing 4 values in fifo. Then you should get an interrupt.
RX interrupt will be set with every single value written in FIFO by the state machine. So not at 4 values, but at every single value. And when you read it, the interrupt will clear, and be set again at the next value.
I have not tried it, but may be able to help further sunday next. Not at home at this moment.
Edited 2026-01-03 04:29 by Volhout
homa
Posted: 10:06pm 02 Jan 2026
-- I tried 1/7/31 as a parameter and think that is only for parameters /v or /w.
t/ pushthreshold (1..31 bits shifted IN in ISR before autoPUSH)
u/ pullthreshold (1..31 bits are shifted OUT from OSR before autoPULL)
v/ autopush (1 = allow autmatic push)
w/ autopull (1 = allow automatic pull)
Unfortunately, the information in the manual is sometimes very sparse and scattered in various places :-(
I think I'll write a summary when I'm done here!
-- Yes, that makes sense, and I can also check it with Pio(FLEVEL 0) or Pio(FLEVEL 0, 0, RX)
-- Based on my observations, unfortunately no.
-- understood
-- Unfortunately, that won't happen either.
I tried that too:
PIO ASSEMBLE 0, "set x, 0"
PIO ASSEMBLE 0, "mov x, osr"
-- No problem, I appreciate the help and food for thought.
Matthias
homa
Posted: 10:16pm 02 Jan 2026
That's all on the topic of PIO INTERRUPT page 155 and page 218 in the examples:
PIO INTERRUPT pio, sm [,RXinterrupt] [,TXinterrupt]
Sets Basic interrupts for PIO activity.
Use the value 0 for RXinterrupt or TXinterrupt to disable an interrupt.
Omit values not needed.
The RX interrupt triggers whenever a word has been "pushed" by the PIO code into the specified FIFO. The data MUST be read in the interrupt to clear it.
The TX interrupt triggers whenever the specified FIFO has been FULL and the PIO code has now "pulled" it
PIO CLEAR clears all the PIO FIFO's, as does PIO START and PIO INIT MACHINE.
The MMBAsic program doesn't need to wait for data in the FIFO to appear since the RX FIFO can be assigned an interrupt. The MMBasic interrupt routine can fetch the data from the FIFO.
Similar for TX interrupt in which case MMBasic gets an interrupt when data is needed for the TX FIFO.
PIO INTERRUPT a,b,c,d
a/ PIO (0,1 or 2(2350 only))
b/ state machine (0...3)
c/ Name of RX interrupt handler (i.e. "myRX_Interrupt" or 0 to disable)
d/ Name of TX interrupt handler (i.e. "myTX_Interrupt" or 0 to disable)
And this is completely independent of the PIO DMA, right?
Edited 2026-01-03 08:17 by homa
Posted: 09:27pm 03 Jan 2026
Homa,
I think there is a bug in the RX interrupt. See my post in the 6.01.00 release thread.
