Forum Index : Microcontroller and PC projects : Problem with rp2350 firmware,no usb or video out version.
| gadgetjack Senior Member Joined: 15/07/2016 Location: United StatesPosts: 233 |
Last night I was playing with an old handheld with a 2350 and an ili9341. Thought I would update the firmware to the newest. It would not boot up? Tried several times with wiping out the device and re-loading. Ok, wondered if there was a problem with just that file. Downloaded it again. Still no go. Started going backward in versions till I could find one that worked. Had to go to version 6.00 to get it to boot. Strange. Went back to the newest and again , no boot? Could there be a problem with just that one file with no usb and no video? I have the newest file working on an HDMI version just fine. Puzzled...... |
Exactly which firmware version? |
I tried 6.02.00 , 6.01.00rc19 , 6.01.00rc24 , 6.01.00rc25 , 6.01.00rc0 . The one that worked was 6.00.02 . |
What Peter wants to know is the exact name of the file such as: PicoMiteRP2350V6.02.00RC1.uf2 Jim VK7JH MMedit |
All were PicoMiteRP2350Vxxxx , the only one meant for no video and no USB keyboard. |
All the VGA and HDMI versions I have tried work just fine. I don't use the WEB version ones , at least not yet. |
I've just been bug fixing using what is now PicoMiteRP2350V6.02.00RC2.uf2 and it works absolutely perfectly on a standard Pico2. What H/W are you using? Clear the flash completely using the clear_flash.uf2 in the download and then install RC2 |
Ok , I found that version , tried it and success! Went back and re-tried 5 other versions and no go. I have the new one loaded and running so thank you very much. It was a SeeedStudio board , the short one. |
Never mind. My board is crap. I tried another pico2 board and no faults at all. Sorry for the fault. |
