Forum Index : Microcontroller and PC projects : PicoMite - version specific commands
Attached is a html file that identifies all commands that aren't universally available. Just open this file on your computer using a browser Commands.zip |
@Peter, Thanks for the overview. It may need a bit of tuning. Example: I can use Backlight in mt RP2040 GEEK, which the overview says I can not. Volhout PicomiteVGA PETSCII ROBOTS |
Is it fair to expect a non-pico board such as a RP2040 GEEK, RP2040-Zero, YD-RP2040 etc. to always behave as expected? :) Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
Thanks for that Peter, it will be useful. Can you ask Claude to rethink the STAR command "Star shape drawing" Jim VK7JH MMedit |
@Mick, The GEEK uses the normal microcontroller picomite image (non VGA). That picomite image supports a variety of LCD panels (also the GEEK). And these LCD panels have BACKLIGHT. So it is a mistake that the microcontroller image, according that list, does not support the BACKLIGHT command. It does. Volhout Edited 2026-01-27 17:05 by Volhout PicomiteVGA PETSCII ROBOTS |
Ah, I see. :) Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
