Forum Index : Microcontroller and PC projects : Maximite Question II
I have been struggling writing a sub that will enable a predicted TIME$ and DATE$ when a particular number of seconds are added. I tried using TIMER but the conversion back to DATE$ and TIME$ has become enormous. I have also started with a TIME$ and DATE$ and adding to the STRING values but having to modify for incrementing MINUTES, HOURS, DAYS, YEARS and LEAP YEARS is straining the grey matter to a large extent. Has this been done by anyone or are there shortcuts that I am missing. I am stuck using MMBaisic 4.04 on a DTX-2 embedded module and unfortunately AI can't get enough data or information to help the situation. OA47 |
These are from 2014 Lucky they don't use line numbers. Usage: convert date,time to Unix add the number of seconds. convert back to date/time 'date conversion routines currentdate$= DATE$ currenttime$=TIME$ mainloop: DAY= VAL(MID$(currentdate$,1,2)) month= VAL(MID$(currentdate$,4,2)) year= VAL(MID$(currentdate$,7,4)) hh=VAL(MID$(currenttime$,1,2)) mm=VAL(MID$(currenttime$,4,2)) ss=VAL(MID$(currenttime$,7,2)) 'weekday starts at 0 for Sunday to match the RTC chip d=DAY:m=month:y=year GOSUB toJD weekday= ABS((jd%+1) MOD 7) 'weekday starts at 0 for Sunday to match the RTC chip dayz$=MID$("SunMonTueWedThuFriSatSun",weekday*3+1,3) GOSUB toDOY PRINT currentdate$;" ";currenttime$ PRINT "Day of year: ";dayofyear PRINT "Julian Day : ";jd% PRINT "Day of Week: ";weekday;" ";dayz$ d=DAY:m=month:y=year GOSUB tojdtime 'tounix PRINT "JD time : ";jdd GOSUB fromjdtime 'fromunix PRINT udate$;" ";utime$ INPUT "New Date (DD/MM/YYYY) or X to quit: ",newdate$ IF UCASE$(newdate$)="X" THEN END IF newdate$<>"" THEN currentdate$=newdate$ INPUT "New Time (HH:MM:SS) : ",newtime$ IF newtime$<>"" THEN currenttime$=newtime$ IF (newtime$<>"") OR (newdate$<>"") THEN GOTO mainloop testunix: INPUT "Unix time: ",un$ IF un$="" THEN GOTO mainloop IF UCASE$(un$)="X" THEN END unix=VAL(un$) GOSUB fromunix PRINT "Unix time ";STR$(unix,12);" equals ";udate$;" ";utime$ GOTO testunix tounix: d=DAY:m=month:y=year GOSUB toJD unixd=jd%-2440588 hh=VAL(MID$(currenttime$,1,2)) mm=VAL(MID$(currenttime$,4,2)) ss=VAL(MID$(currenttime$,7,2)) unixf=hh*60*60+mm*60+ss unix=unixd*86400+unixf RETURN fromunix: unixd=INT(unix/86400) unixf=unix MOD 86400 IF unixd<0 THEN unixf=86400+unixf ENDIF hh= INT(unixf/3600) mm= INT((unixf MOD 3600)/60) ss=(unixf MOD 3600) MOD 60 jd%=unixd+2440588 GOSUB fromJD udate$=STR$(d,2)+"/"+STR$(m,2)+"/"+STR$(y,4) utime$=STR$(hh,2)+":"+STR$(mm,2)+":"+STR$(ss,2) RETURN toDOY: GOSUB toJD day1=jd% d=31:m=12:y=year-1 GOSUB toJD dayofyear= day1-jd% jd%=day1 RETURN toJD: ' valid for Gregorian dates after Oct 15, 1582 ff=FIX((m-14)/12) jd% = FIX((1461*(y+4800+ff))/4)+FIX((367*(m-2-12*ff))/12)-FIX((3*(FIX(y+4900+ff)/100))/4)+d-32075 RETURN fromJD: l = jd%+68569 ' valid for Gregorian dates after Oct 15, 1582 n = FIX((4*l)/146097) l = l-FIX((146097*n+3)/4) i = FIX((4000*(l+1))/1461001) l = l-FIX((1461*i)/4)+31 j = FIX((80*l)/2447) d = l-FIX((2447*j)/80) l = FIX(j/11) m = j+2-(12*l) y = 100*(n-49)+i+l RETURN jdtounix: unix=jd%-2440588 RETURN tojdtime: d=DAY:m=month:y=year GOSUB toJD hh=VAL(MID$(currenttime$,1,2)) mm=VAL(MID$(currenttime$,4,2)) ss=VAL(MID$(currenttime$,7,2)) jdt=(hh*60*60+mm*60+ss)/86400 jdd=jd%+jdt RETURN fromjdtime: jd%=INT(jdd) jdt=jdd-jd% GOSUB fromJD jdtime=jdt*86400 hh= INT(jdtime/3600) mm= INT((jdtime MOD 3600)/60) ss=(jdtime MOD 3600) MOD 60 udate$=STR$(d,2)+"/"+STR$(m,2)+"/"+STR$(y,4) utime$=STR$(hh,2)+":"+STR$(mm,2)+":"+STR$(ss,2) RETURN Jim VK7JH MMedit |
Hi Jim, Good that you found something. I can't go back before 4.5C on CMM1. Is 4.04 a mono maximite ? P.S. Off-Topic: did you already find a "final" solution for the MMCC 5.40 linux problem. You found a "quick fix" but needed more testing ? Volhout PicomiteVGA PETSCII ROBOTS |
I am never 100% confident. Time will tell how well I have done. Jim VK7JH MMedit |
| Pluto Guru Joined: 09/06/2017 Location: FinlandPosts: 411 |
Could the EPOCH functions be useful? |
Hi Pluto, According MMBasic 4.5C language manual (CMM1), the EPOCH function is not implemented in this version of basic. I am not sure about 4.04, but my estimate is it is not available. Volhout PicomiteVGA PETSCII ROBOTS |
@OA47, There is a version 4.5 MMBasic for the DTX2. Please find attached. They fixed some bugs with DATE$ and TIME$ according the release notes. mmbasic.zip Volhout P.S. They added some nice commands to MMBasic. Especially the simple multithread capability. But also "HELP"... Edited 2026-02-10 01:02 by Volhout PicomiteVGA PETSCII ROBOTS |
Thankyou Jim for your code unfortunately the version of Basic I am stuck with does not like the Fix line. Is there a way around this? [CODE[83] jd% = Fix((1461*(y+4800+ff))/4)+Fix((367*(m-2-12*ff))/12)-Fix((3*(Fix(y+4900+ff)/100))/4)+d-32075 Error: Unknown command] OA47 Found if I deleted the % from the variable the code runs Edited 2026-02-10 13:42 by OA47 |
@ Volhout As the embedded Maximite is a DTX-2 (a variation at the time) I dont believe that there are any updates available. As far as I can see it is Version 4.4 Rev 5 OA47 Edited 2026-02-10 14:31 by OA47 |
| phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3290 |
V4.5C complete package also available here -https://geoffg.net/MonoMaximite.html |
Sorry about that. Integers ( % suffix ) only came in with V4.6 firmware. I hope you don't run into an overflow. What date range are you expecting to cover? Jim VK7JH MMedit |
@ Jim The current code generates a period in seconds from 1 to years and this new DATE and Time is set and scanned for. I wonder if the period is only a couple of second that they would be lost in the conversion to JD time eg 2.46108e+06. @ Volhout, I was certainly wrong it looks like I must have missed the 4.5 update. I will look through the docs and see what it has to offer. OA47 Edited 2026-02-10 14:48 by OA47 |
Searched for DTX2-4105C MMBasic firmware to see what is the latest but the links to it are dead. |
Try this at the beginning of the code I sent previously (after removing all the %) currentdate$= DATE$ currenttime$=TIME$ INPUT "Number of seconds away (+ or -)",difsec PRINT "Starting time ";currentdate$;" ";currenttime$ DAY= VAL(MID$(currentdate$,1,2)) month= VAL(MID$(currentdate$,4,2)) year= VAL(MID$(currentdate$,7,4)) hh=VAL(MID$(currenttime$,1,2)) mm=VAL(MID$(currenttime$,4,2)) ss=VAL(MID$(currenttime$,7,2)) GOSUB tounix 'print "startsec = ";unix unix = unix + difsec GOSUB fromunix PRINT udate$;" ";utime$ Back in the single precision days, I separated the whole days from the part days. We might have to resort to that here. I might have to look it the old-parts draw for a Maximite to test it properly. Jim VK7JH MMedit |
@ Jim Added that code but the new date needs proceeding zeros added. Number of seconds away (+ or -)4500 Starting time 10-02-2026 17:30:11 10/2/2026 18:44:16 10-02-2026 17:30:11 Day of year: 41 Julian Day : 2.46108e+06 Day of Week: 2 Tue JD time : 2.46108e+06 10/2/2026 18:0:0 OA47 |
This is more compact (but only for positive diffs so far) currentdate$= DATE$ currenttime$=TIME$ INPUT "Number of seconds away (+ or -) ",difsec PRINT "Starting time ";currentdate$;" ";currenttime$ wholedays = toJD(currentdate$) secondsDay = partday(currenttime$) newseconds = secondsDay + difsec newwholedays = wholedays + INT(newseconds/86400) newseconds = newseconds MOD 86400 newtime$ = frompartday$(newseconds) newdate$ = fromJD$(newwholedays) PRINT newdate$;" ";newtime$ FUNCTION toJD(thisdate$) d = VAL(MID$(thisdate$,1,2)) m = VAL(MID$(thisdate$,4,2)) y = VAL(MID$(thisdate$,7,4)) ' valid for Gregorian dates after Oct 15, 1582 ff=FIX((m-14)/12) tojd = FIX((1461*(y+4800+ff))/4)+FIX((367*(m-2-12*ff))/12)-FIX((3*(FIX(y+4900+ff)/100))/4)+d-32075 END FUNCTION FUNCTION partDay(thistime$) hh=VAL(MID$(thistime$,1,2)) mm=VAL(MID$(thistime$,4,2)) ss=VAL(MID$(thistime$,7,2)) partday=(hh*60*60+mm*60+ss) END FUNCTION FUNCTION frompartDay$(secs) hh= INT(secs/3600) mm= INT((secs MOD 3600)/60) ss=(secs MOD 3600) MOD 60 frompartDay$=RIGHT$("0"+STR$(hh),2)+":"+RIGHT$("0"+STR$(mm),2)+":"+RIGHT$("0"+STR$(ss),2) END FUNCTION FUNCTION fromJD$(jd) l = jd+68569 ' valid for Gregorian dates after Oct 15, 1582 n = FIX((4*l)/146097) l = l-FIX((146097*n+3)/4) i = FIX((4000*(l+1))/1461001) l = l-FIX((1461*i)/4)+31 j = FIX((80*l)/2447) d = l-FIX((2447*j)/80) l = FIX(j/11) m = j+2-(12*l) y = 100*(n-49)+i+l fromJD$=RIGHT$("0"+STR$(d),2)+"/"+RIGHT$("0"+STR$(m),2)+"/"+STR$(y,4) END FUNCTION I will play further. Edited 2026-02-10 17:01 by TassyJim VK7JH MMedit |
Hi OA47, The link is not dead. Maybe your browser refuses to download because it is not a HTTPS site, but HTTP. Dimetech Maximite Download But this is the exact package that I zipped up for you 6 posts ago. It contains the user manual, the list of changes, the added commands, the release notes, the hex file, everything you need, even a description of 2 different ways to put the firmware into your DXT2-4105. If you have firmware 4.04 the only one method works (pickit3), if your current code is 4.4 you can also use the built in bootloader. Regards, Volhout Edited 2026-02-10 16:58 by Volhout PicomiteVGA PETSCII ROBOTS |
@ Volhout, I loaded the firmware you supplied the link to and MM.Ver still shows version 4.05. @ Jim, the code you supplied seems to work great and is very compact. I have inserted it into the current code but for many hours of trying, I cannot get my code to recognise the new date and time. I cannot see any issues but the code recognises the 1st set date and time but will not recognise any further. Heres the line where it fails: If DateOn$(J)=Date$ Then 'Check for DATE of operation When I check the new date (which does not change in my test code where DateOn$(1)="11/02/2026" (String length is 10) Date$="11/02/2026" (String length is 10) It has got me stumped OA47 Edit I think I found the fault. I do worry about my grey cells sometimes. Of course the DATE$ can be "11/02/2026" and it can be "11-02-2026" and they both work fine. Edited 2026-02-11 14:40 by OA47 |
Date$ is a system command and I expect that you are really comparing the result of Date$ which contains - instead of / Date$ accepts either - or / but only outputs - I don't think there is an option to change it. > date$ = "11/02/2026" > print date$ 11-02-2026 > You might have to change all the '/' to '-' Jim Edited 2026-02-11 14:45 by TassyJim VK7JH MMedit |
Thanks again Jim your code has got me on the road again. I did change the new dates to use the minus instead of the slash and testing has been running along well. OA47 |
