Local Time 15:57 19 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : val(x$)......
DigitalDreams
Posted: 05:41pm 07 Mar 2026
Having trouble with this command.
If x$="57+93+117"
Val(x$) returns 57 !?
Am I asking too much of val(x$) ?
Martin H.
Posted: 05:50pm 07 Mar 2026
  DigitalDreams said  Having trouble with this command.
If x$="57+93+117"
yes
  Quote  Returns the numerical value of the ‘string$’. If 'string$' is an invalid number the function will return zero.
This function will recognise the &H prefix for a hexadecimal number, &O
for octal and &B for binary
So it converts the numerical value within a string into a number. But it does not calculate any formulas that are within the string.
'no comment
bfwolf
Posted: 05:58pm 07 Mar 2026
  DigitalDreams said  Am I asking too much of val(x$) ?
Yes, you're asking too much of `VAL(s$)`. This function (as it exists in the BASIC dialect) simply tries to find a number within a string and returns the value after the first match. It doesn't evaluate any expressions!
Try `EVAL(s$)`, which is fortunately available in MMBasic!
Will evaluate 'string$' as if it is a BASIC expression and return the result.
'string$' can be a constant, a variable or a string expression. The expression can
use any operators, functions, variables, subroutines, etc that are known at the
time of execution. The returned value will be an integer, float or string
depending on the result of the evaluation.
For example: S$ = "COS(RAD(30)) * 100" : PRINT EVAL(S$)
Will display: 86.6025
DigitalDreams
Posted: 06:25pm 07 Mar 2026
Thanks !, that's the ticket. I'm about to print a truncated version of the latest user manual so none to hand...
