Local Time 18:16 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 via VGA-Hdmi Converter to KVM-Switch
Wolfgang
Posted: 07:37am 08 Mar 2026
Hallo experts,
I apologise if I am possibly revisiting an old topic here.
I would like to use my monitor for both tasks: HDMI (from my PCs) and also the CMM2-VGA via my KVM switch.
My KVM switch has HDMI-video inputs, so a VGA-HDMI converter could be connected between KVM-switch and the CMM2.
Has anyone tried connecting a CMM2 to such a KVM switch (HDMI inputs) via a VGA-HDMI adapter for using only one monitor? Does this makes sense, or are there any reasons not to do so?
Wolfgang
Posted: 08:23am 08 Mar 2026
Awww... And I was so looking forward to ordering a MicroMite Plus.  ;)
I must confess that I've not used a VGA to HDMI converter, only the other way so that I could use an old monitor with a Raspberry Pi.
I think your idea will *probably* work, after all VGA is a very basic linear system. The converter from VGA to HDMI should be taking care of everything to make the signal HDMI compatible. After that the KVM is merely switching the signals.
I suspect that, if you have any problems, it will be with your monitor re-synchronising to a different resolution. That can sometimes be a bit slow.
There is also the case that the VGA-HDMI converter will almost certainly have to be a "proper" active one and not a very cheap Chinese knock-off which might or might not work. They aren't that expensive now anyway.
Posted: 09:17am 08 Mar 2026
The mouse on CMM2 is PS2, not USB, despite the USB connector. You need a converter to run it through a KVM switch.
Wolfgang
Posted: 09:18am 08 Mar 2026
at the moment, my monitor is cycling through all four video inputs before finally displaying the VGA connection. This thake some time.
Could this be resolved with an EDID function on the VGA-HDMI converter?
Would it be possible to set the CMM2-VGA pin 9 to +5V or to use an EDID emulator for this purpose?
Posted: 09:35am 08 Mar 2026
I've no idea. VGA has no equivalent of EDID so it would be a function of the converter, which may or may not handle VGA pin 9. You probably need a full specification of the converter. Good luck with that unless you are getting a big name commercial one.
PeteCotton
Posted: 06:04am 11 Mar 2026
I use my CMM2 with an HDMI output going into a Monitor Switcher (not KVM - just the display) and it works fine. I also have an HDMI video capture card that has a CMM2 going into it (via VGA to HDMI) so that I can open the Windows Camera app, switch it to the video capture card and display the CMM2 display as a window on my desktop. This is how I primarily use the CMM2.
As Volhout mentioned, the mouse doesn't play well with a KVM, so I do keep a separate keyboard and mouse for the CMM2.
I'm using this for the VGA to USB output (note - it does require external power from a USB port).
https://www.amazon.ca/dp/B083K83NNX?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_14
And using this for video capture
https://www.amazon.ca/dp/B0CLNZ8267?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_33&th=1
And I use this for switching between HDMI inputs
https://www.amazon.ca/dp/B071G4NXNH?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_5
Posted: 07:42am 11 Mar 2026
@ Wolfgang - Thanks for posting the new thread.
  Mixtel90 said  Awww... And I was so looking forward to ordering a MicroMite Plus.  ;)
I'm sure you were.
Nice one, my son.
Wolfgang
Posted: 11:07am 11 Mar 2026
@PeteCotton
Very interesting information.
I had no success with my combination:
VGA Emulator: Lindy 32121
https://www.reichelt.de/de/de/shop/produkt/vga_edid_emulator_1080p-367085?search=Lindy%252032121&
https://www.reichelt.de/de/de/shop/produkt/vga_adapter_vga_stecker_auf_hdmi_buchse-152747
HDMI KVM-Switch
https://www.kvm-switch.de/de/4-port-8k60hz-4k120hz-hdmi-2-1-usb3-0-kvm-switch-mit-kabelfernbedienung-kc-kvm8401ba.html
Monitor: FlexScan EV2455 , HDMI-input
Result: Text-Output on monitor: Signal Error
As a workaround, I use now the monitor's additional separate VGA-input to connect the CMM2.
After selecting ‘Load it and Run’ in MMedit, it must be switched from HDMI to VGA using the monitor's input selection menu. This requires five steps, compared to just one button press, if it had worked with the KVM switch.
But it helps.
Wolfgang
