Local Time 18:21 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : VS1053 & PICO Questions
OA47
Posted: 12:34am 09 Mar 2026
I have finally found time to have a play with the VS1053 module and the PicoW. I have the code written by Peter working ok but I cannot get the code written by Tassie Jim to work. I would like to listen to some local content and have tried to enter Jims strings into Peters code and Peters string into Jims code but I think I have a lack of understanding on how these streams are addressed as I have had no success.
Any help much appreciated
OA47
Posted: 04:38am 09 Mar 2026
I don't have a webmite and VS1053 set up but:
My code
SUB listen url$
LOCAL q$, a$, strm$, k%
IF UCASE$(LEFT$(url$,7)) = "HTTP://" THEN url$ = MID$(url$,8)
r% = 0 : w% = 0
k% = INSTR(url$,"/")
a$ = LEFT$(url$,k%-1)
strm$ = MID$(url$,k%)
PRINT a$
PRINT strm$
q$="GET "
INC q$, strm$
INC q$," HTTP/1.1\r\n"
INC q$,"Host: "
INC q$,a$
INC q$,"\r\nConnection: close\r\n\r\n"
PLAY STREAM buff%(), r%, w%
WEB OPEN TCP STREAM a$,80
WEB TCP CLIENT STREAM q$, buff%(), r%, w%
END SUB
Peters code
' create the request for the radio site (ClassicFM)
Dim a$="ice-the.musicradio.com"
Dim q$="GET "
Inc q$,"/ClassicFMMP3"
Inc q$," HTTP/1.1\r\n"
Inc q$,"Host: "
Inc q$,a$
Inc q$,"\r\nConnection: close\r\n\r\n"
using an example from my code,
url$ = "live-radio02.mediahubaustralia.com/JAZW/mp3/"
in Peters code a$ is the url$ up to the first '/'
the rest of the url$ is the stream (where Peter has "/ClassicFMMP3")
moddified Peters code
Dim a$="live-radio02.mediahubaustralia.com"
Dim q$="GET "
Inc q$,"/JAZW/mp3/"
Inc q$,"Host: "
Inc q$,a$
Getting the spaces correct is important.
https://www.thebackshed.com/forum/ViewTopic.php?TID=16391&P=3#217896
OA47
Posted: 05:21am 09 Mar 2026
Jim, thankyou for your reply.
Here is a snippet of the code I am using:
'Code updated for the latest version RC15 syntax just posted
Option escape
Option explicit
Option default none
Dim q$="GET "
Inc q$,"/JAZW/mp3/"
'Dim a$="ice-the.musicradio.com"
'Dim q$="GET "
'Inc q$,"/ClassicFMMP3"
Inc q$,"Host: "
Inc q$,a$
I am only changing 3 lines of code (Rem'd out the original of Peters) Peters url working but ABC not working.
OA47
OA47
Posted: 05:38am 09 Mar 2026
Jim, I have just found the list of urls for Global Streaming in the UK and other addresses work fine. I am thinking the issue is with the mediahubaustralia urls not functioning. Is there a subscription needed to access these?
OA47
Posted: 06:59am 09 Mar 2026
Try pasting this link into your browser
HTTP://live-radio02.mediahubaustralia.com/JAZW/mp3/
It works for me
OA47
Posted: 08:14am 09 Mar 2026
Jim, I agree the link does work in the browser.
NO Audio
Connected
a$=live-radio02.mediahubaustralia.com
q$=GET /JAZW/mp3/ HTTP/1.1
Host: live-radio02.mediahubaustralia.com
OK Audio
Connected
a$=ice-the.musicradio.com
q$=GET /ClassicFMMP3 HTTP/1.1
Host: ice-the.musicradio.com
Is there a chance that the length of the string (q$) is too long when put behind the WEB TCP Client Stream command? I have tried with and without the SLANT following the /mp3.
OA47
Posted: 08:23am 09 Mar 2026
Maybe the MP3 itself is not compatible with the VS1053 module (bitrate?).
The pico only transfers data to the VS1053.
Or the site is HTTPS in stead of HTTP.
Edited 2026-03-09 18:25 by Volhout
Posted: 08:33am 09 Mar 2026
The streaming support in the VS1053 is quite primitive. There are lots of internet radio stations that it can't receive. For example the BBC uses HLS/DASH which isn't supported. ClassicFM uses the older HTTP streaming with AAC at 48 kbps which is supported. You can use various directories to filter which stations are compatible (AACMix, Internet‑Radio.com etc.)
Posted: 10:26am 09 Mar 2026
The stream DID work with the webmite and VS1053 2 years ago when I posted the code.
I can't test it for the next few days.
Posted: 08:11pm 09 Mar 2026
The link I posted a few posts ago redirects to
https://abc.streamguys1.com/live/abcjazz/icecast.audio
but it does also work OK without the 's'
http://abc.streamguys1.com/live/abcjazz/icecast.audio
so if you put the other address from my original post into your web browser and se where it gets redirected to
Finally, try the new address without the 's in https
Posted: 12:23am 10 Mar 2026
Untested but these updated streams should work.
myList:
 DATA "ABC Jazz","abc.streamguys1.com/live/abcjazz/icecast.audio"
 DATA "ABC Melbourne","abc.streamguys1.com/live/localmelbourne/icecast.audio"
 DATA "NEWS","abc.streamguys1.com/live/newsradio/icecast.audio"
 DATA "Classic FM","abc.streamguys1.com/live/classicfmvic/icecast.audio"
 DATA "END",""
OA47
Posted: 04:57am 10 Mar 2026
  Quote  Untested but these updated streams should work.
myList:
DATA "END",""
Jim, all those url's do work. Thank you very much. Could anyone advise of a list of usable url's especially here in Oz.
OA47
Posted: 06:16am 10 Mar 2026
google for "Australia radio streaming"
That will do as a start.
