Local Time 02:24 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Blit RESIZE abused ;-)
Martin H.
Posted: 01:11pm 09 Mar 2026
For PicoMite V6.02.01 RC 1 or later
Here is an example of using BLIT RESIZE somewhat outside its intended use.
BLIT RESIZE draws a floor similar to the game Ballblazer. At this speed, the simultaneous view for the second player/NPC would also not be a problem.
Movement is again controlled using the WS AD keys.
Dim integer mmb4w
Dim integer Bcl(16,160),speed=3
phase
' --- Initialisierung ---
CLS
' --- Init_Graphics: Setup 320x240 Resolution, Layer-Buffer).
If MM.DEVICE$ = "MMBasic for Windows" Then mmb4w = 1
If mmb4w Then
MODE 7
PAGE WRITE 1
CLS
Else
'Pico
MODE 2
FRAMEBUFFER create : FRAMEBUFFER write f
End If
' 2. Z-Table
Dim integer x,y, z_dist(38)
For y = 0 To 37
  Read scal:z_dist(y)=16+(scal/4)
Next y
CLS 'clear FRAMEBUFFER
Dim integer hh=120,hw=160,f,n,w
Dim integer c1=RGB(0,180,0),c2=RGB(White)
Dim Integer sky=RGB(0,85,255),sky1=RGB(0,170,255),sky2=RGB(cyan)
' --- Create_Checkerboard Source
For f =0 To 288 Step 32
Line f,hh-1,f+15,hh-1,,c1:Line f+16,hh-1,f+31,hh-1,,c2
Line f,hh,f+15,hh,,c2:Line f+16,hh,f+31,hh,,c1
Next
Box 8,16,304,72,,sky,sky
Line 8,51,311,51,,sky1:Line 8,52,311,52,,sky2
main:
p=0
For y = 0 To 37
mult=y<<1
 f=z_dist(y):sy=y+53:w=200-f*2-y2'w=144-mult
 If mmb4w Then
    IMAGE RESIZE_FAST f+camX,hh-Bcl(p,y+50), w,1, 8, y+53,304,1
  Else
      BLIT RESIZE f,f,f+camX,hh-Bcl(p,y+50), w,1, 8, y+53,304,1
  End If
Next y
   ' --- Keyboard ---
   k$ = Inkey$
   Select Case k$
       Case "w", "W"
          Inc P,speed:p=p Mod 15   ' vorwrts
       Case "s", "S"
           p=p-speed:If p<0 Then p=15
       Case "a", "A"
           camX = camX - speed:If camX<0 Then camX=31
       Case "d", "D"
            camX = camX + speed:camX = camX Mod 32
   End Select
If mmb4w Then
Page copy 1,0
'Page write 0
Else
 FRAMEBUFFER copy f,n,b
End If
'pause 20
Sub phase
  'Precalculation pharse lookup table
   Local integer X,Y, SW = 120,CYCLES = 7
   Local C_VALUE = (2 * Pi * CYCLES) / (SW * SW),START_PHASE = 0,Agl
   For dst=0 To 15
     For X = 0 To 119
       Agl = C_VALUE * X * X + START_PHASE
       Y = Int(Sin(Agl)*5)
       bcl(dst,120-x)=Not(y>0)
     Next X
     Inc START_PHASE, 0.393
   Next
End Sub
Data 36, 39, 43, 46, 50, 54, 57, 61, 64, 68, 72,75, 79, 82, 86
Data 89, 93, 97, 100, 104, 107, 111, 115, 118, 122, 125, 129
Data 133, 136, 140, 143, 147, 151, 154, 158, 161, 165, 169
Runs faster smoother on Pico than on Windows
Edited 2026-03-10 00:57 by Martin H.
'no comment
vegipete
Posted: 08:08pm 09 Mar 2026
That's fun! Runs pretty fast on MMB4W if your keyboard repeat rate is high.
Here's a modification with acceleration and friction: (still AWSD keys to move)
Only tested on MMB4W.
Dim integer mmb4w
CONST SMAX=0.025
CONST FRICTION=0.9999
CONST ACCEL=0.005
phase
CLS
If mmb4w Then
 MODE 7
 PAGE WRITE 1
 CLS
Else
 'Pico
 MODE 2
End If
' 2. Z-Table
For y = 0 To 37
Next y
Dim float xpos=0,ypos=0,dx=0,dy=0
Next
main:
p=0
 if abs(dx) < .0001 then
   dx = 0
 else
   dx = dx * FRICTION
   inc xpos,dx
 end if
 camX = xpos mod 32 : if camX < 0 then inc camX,32
 if abs(dy) < .0001 then
   dy = 0
 else
   dy = dy * FRICTION
   inc ypos,dy
 end if
 p = ypos mod 15 : if p < 0 then inc p,15
 For y = 0 To 37
   'y2 = y<<1
   'mult=y<<1
   f=z_dist(y):sy=y+53:w=200-f*2 '-y2 'w=144-mult
   If mmb4w Then
   Else
   End If
 Next y
 ' --- Keyboard ---
 k$ = Inkey$
 Select Case k$
   Case "w", "W"
     'Inc P,speed:p=p Mod 15   ' vorwrts
     inc dy,ACCEL
     dy = min(dy, SMAX)
   Case "s", "S"
     'p=p-speed:If p<0 Then p=15
     inc dy,-ACCEL
     dy = max(dy,-SMAX)
   Case "a", "A"
     'camX = camX - speed:If camX<0 Then camX=31
     inc dx,-ACCEL
     dx = max(dx,-SMAX)
   Case "d", "D"
     'camX = camX + speed:camX = camX Mod 32
     inc dx,ACCEL
     dx = min(dx, SMAX)
 End Select
 If mmb4w Then
   Page copy 1,0
   'Page write 0
 Else
 End If
 'pause 20
Sub phase
  For dst=0 To 15
    For X = 0 To 119
      Y = Int(Sin(Agl)*5)
    Next X
  Next
End Sub
Martin H.
Posted: 04:23am 10 Mar 2026
Hey Pete, it gives you a completely different riding experience, reminiscent of skating. Great addition.
Martin
Edit:Sadly, it runs extremely slowly(is not due to the image generation) on the first attempt on the Pico.... I'll have a look what the problem might be.
Edited 2026-03-10 18:26 by Martin H.
'no comment
vegipete
Posted: 04:51pm 10 Mar 2026
I tuned the SMAX (max speed,) FRICTION and ACCEL values for MMB4W, which obviously calculates much faster. They will need tuning for the PicoMite.
Martin H.
Posted: 05:12pm 10 Mar 2026
  vegipete said  I tuned the SMAX (max speed,) FRICTION and ACCEL values for MMB4W, which obviously calculates much faster. They will need tuning for the PicoMite.
Const SMAX=1.8
Const FRICTION=1
Const ACCEL=0.5
They run quite well, not quite as nicely as under Windows, but still quite pleasantly.
Thanks for the support.
Martin
'no comment
Martin H.
Posted: 10:46am 22 Mar 2026
Since it's Sunday,
I dug up some old code and sped things up using the new BLIT RESIZE command
On the PICO2 HDMI @252MHz, this gives me 47 FPS, so there's now room to include enemie cars, trees, and signs
Road.zip
Have Fun
Martin
Link to the original post
Edited 2026-03-22 20:51 by Martin H.
'no comment
Peter63
Posted: 02:37pm 03 Apr 2026
  Quote  Road.zip
Have Fun
Martin
have tried it on,  PicoMiteVGA MMBasic USB RP2040 Edition V6.02.01
  have a nice weekend
Peter63
