Local Time 16:00 19 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite Nixie Clock (almost)
Bleep
Posted: 08:18pm 10 Mar 2026
Here is my take on a Nixie Clock for a PicoMite, Both for a 480x320 LCD and a HDMI VGA, It might be ok on a standard VGA, I have not tried it, I have also not tested it on a 2040 Pico.
VGA Version
Short video of it working.
LCD Version
Short Video of it working.
Both versions ziped up.
nixie.zip
Regards Kevin.
Edited 2026-03-11 06:21 by Bleep
toml_12953
Posted: 01:27am 11 Mar 2026
In the jpg file, all the digits look fine but when the program runs, the 4 and the 9 don't display properly in the minutes column.
Edited 2026-03-11 11:32 by toml_12953
ville56
Posted: 07:47am 11 Mar 2026
toml_12953,
I've done some optimisation (brightness, contrast, color depth, size) on the fonts. I use the .bmp to load. All 3 fonts do work with BLIT commands (.bmp files) without a hitch. Difference is, that I'm loading the fonts onto 6 individual LCD displays and you use a single one. If I find time I will also try to setup a similar environment like yours and see if I can reproduce the issue.
Nixie-Fonts.zip
Just give them a try
Gerald
N.B.; I'm still fiddling around with my software. Now try to get DCF77 working, but I'm here on the edge of the indoor receiving range (Vienna/Austria) and so I'm currently working on an "extension" via 433MHz ISM band.
Edited 2026-03-11 17:48 by ville56
73 de OE1HGA, Gerald
Bleep
Posted: 10:06am 11 Mar 2026
Hi Toml
When you say the 4 & 9 don't display properly, what exactly do you mean?
What picomite are you using? You do realise this will only work on a HDMI VGA or a 480x320 LCD & not tested on a RP2040 which may not have enough memory.
Martin H.
Posted: 11:40am 11 Mar 2026
Hi Kevin
Looks realy good on HDMI,  but will not run on 2040 (no Mode 3)
So you can lower the resolution to 320x240 (Mode 2) reduse your source to BW (mode 1)
Good Job
Martin
'no comment
ville56
Posted: 11:50am 11 Mar 2026
RP2040 doesn't have HDMI at all ... do you mean VGA?
Bleep
Posted: 11:56am 11 Mar 2026
Hi Martin,
I can try re-sizing to fit 320x240, but I think the images will become too small, one option might be to only show Hours & Minutes.
While you are here, on a LCD The JPGs are full colour, and I am placing the Jpg of the Nixie tubes on to a Framebuffer layer, but they are limited in colour range, do you know, if I put the JPG onto the normal screen temporarily, then copy each digit to BLIT buffers, assuming there is enough memory, which I think there is not, do the BLIT buffers have a higher colour count, ie same as the screen in use, or they similarly colour depth limited. Thanks.
Kevin.
Edited 2026-03-11 22:08 by Bleep
Posted: 12:08pm 11 Mar 2026
  Quote  do the BLIT buffers have a higher colour count, ie same as the screen in use
Yes, maintains all the colours.
Martin H.
Posted: 12:57pm 11 Mar 2026
Kevin
I reduced the template by half, so it should fit in Mode 2. See which version you like better.
Martin
Edited 2026-03-11 22:59 by Martin H.
'no comment
Bleep
Posted: 05:43pm 11 Mar 2026
Hi Martin,
I have already done this myself, but there seems to be a problem with Blit Framebuffer, in hight colour modes, or I'm not using it right, so I've escelated it. :-)
Regards, Kevin.
Martin H.
Posted: 06:35pm 11 Mar 2026
  Bleep said  Hi Martin,
Regards, Kevin.
This is mode 2 colours, i.e. RGB 121, no high colour Modes required.
Meant for the 2040 Pico VGA. Blit Framebuffer works as intended.
Edited 2026-03-12 04:36 by Martin H.
'no comment
Bleep
Posted: 10:17pm 11 Mar 2026
Ok thanks Martin,
I'll do a version using your bitmaps.
Thanks, Kevin.
Bleep
Posted: 07:01pm 12 Mar 2026
Hi Martin,
Attached is a new version of the VGA Mode 2 320x240 Nixie Clock, using your images, both sets are in the code, just change the commented out line. I couldn't use the PNG directly, not enough memory, so I changed them to BMP.
I have included my 3 Nixie sets, as JPG, could you let me know how and what programs you use to reduce the colours to less than 16, and using the 121 colour set? also is it possible to reduce the brightness/contrast, so there are fewer random orange dots around/in the converted image?
I only really use IrfanView and PhotoShop CS2, but if you recommend one I'm happy to install it.
Regards, Kevin.
nixie.zip
Martin H.
Posted: 07:37pm 12 Mar 2026
Hi Kevin,
to draw, you can use whichever tool you feel most comfortable with. As I've mentioned a few times before, I use Paint.net
To get the images exactly to RGB 121 for the Pico, I use a few tools 1/2  I wrote myself in MMBasic for Windows.
Which one I use always depends on the source and what you want to use the image for.
BTW: the PicomiteVGA Nixie-Version(Mode 2) runs and looks fine
Have Fun
 Martin
Edited 2026-03-13 16:50 by Martin H.
'no comment
Bleep
Posted: 09:55am 13 Mar 2026
Presumably that now means it will work on a standard 2040 VGA as the 16 colours are the same and it now use less ram.
Edited 2026-03-13 19:56 by Bleep
Martin H.
Posted: 10:51am 13 Mar 2026
  Bleep said  Presumably that now means it will work on a standard 2040 VGA as the 16 colours are the same and it now use less ram.
I just tried it, but unfortunately it doesn't work on the  standard 2040 VGA...
[19] Blit Read 6,0,110,51,110
Error : Not enough Heap memory
You could work around this by,instead of storing the numbers in sprites, initializing the framebuffer first, load the Image there and then blitting the segments from the framebuffer F to  N.
BLIT FRAMEBUFFER from, to, xin, yin, xout, yout, width, height
Edited 2026-03-14 01:14 by Martin H.
'no comment
