Forum Index : Microcontroller and PC projects : help file
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6252 |
All, Does anyone have a "help.txt" file for a recent PicoMite build (6.01 0r 6.02) he could share ??? Volhout PicomiteVGA PETSCII ROBOTS |
| lizby Guru Joined: 17/05/2016 Location: United StatesPosts: 3888 |
Here's an older help.txt, but it would need to have 6.01 / 6.02 additions added to it. help.zip I don't know which version it applied to. PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
Thank you !! Volhout P.S. Do you think this is something Claude could generate ? Edited 2026-03-12 00:24 by Volhout PicomiteVGA PETSCII ROBOTS |
@Peter, RP2040 VGA. When using above help file, searching for an item requires and asterix. help MM.VRES does not work help MM.VRES* does work (not that the help is very useful in this file) Has this always been that way ? I never used the help function before. Volhout PicomiteVGA PETSCII ROBOTS |
| JanVolk Guru Joined: 28/01/2023 Location: NetherlandsPosts: 420 |
Harm, This depends on how you saved mm.vres. ~mm.vres or ~mm Keep the command and function names as short as possible after ~, and it's best to use the command and function list. Here's my help.txt list for the Dutch speakers among us, which I still have to update regularly in mmedit, after which I can send it from a single point to my various microcontrollers. It's also helpful to put the help under a function key. OPTION F1 "help " > option list PicoMite MMBasic RP2350B V6.02.01RC3 OPTION FLASH SIZE 16777216 OPTION COLOR CODE ON OPTION PICO OFF OPTION CPU SPEED (KHz) 200000 OPTION DISPLAY 50, 100 OPTION F1 help OPTION F5 list commands OPTION F6 list functions OPTION F7 list pins OPTION F8 option list OPTION F9 flash run 1 OPTION PLATFORM WeAct-RP2350B-FLASH:16-PSRAM:8 OPTION PSRAM PIN GP0 help.txt-V6.02.00.txt.zip Jan. |
