Local Time 22:01 14 Nov 2026 Privacy Policy
     Page 20 of 31
Posted: 01:47pm 05 Jun 2026
V6.03.00RC16
PicoMiteRP2040V6.03.00RC16.zip
PicoMiteRP2350V6.03.00RC16.zip
VGA/HDMI USB builds have additional touch panel support.
non-VGA/HDMI builds now support GT911 capacitive touch controllers as well as FT63x6 controllers. VGA and HDMI builds do not and will not support direct GT911 touch controllers. You can buy a very cheap I2C to USB module for any screens that use a GT911 and don't already have the touch over USB
All builds except PICOMITEMIN, PICOMITEVGA RP2040, and  WEBMITE RP2040 now support touch gestures. Obviously only multi-touch controllers support expand/contract/CCW/CW/double tap gestures but even resistive XPT2046 TFT screens now support swipe gestures.
All builds except PICOMITEMIN, PICOMITEVGA RP2040, and  WEBMITE RP2040 now support two new touch functions TOUCH(XN num) and TOUCH(YN num). Setting num to zero in either function will return the number of current simultaneous touches. Setting num to a non-zero value will return the coordinates of that touch.
e.g.
Dim x(10),y(10)
If Touch(yn 0) Then
  For i=1 To Touch(yn 0)
    x(i)=Touch(xn i)
    y(i)=Touch(yn i)
  Next
  Pixel x(),y(),RGB(white)
EndIf
I'm not aware of any previously reported bugs in this release
Coming soon:
HMDIBTH firmware. This combines HDMIUSB and bluetooth LE host functionality allowing for small self contained computers to be built with wireless keyboards and trackpads
homa
Posted: 02:13pm 05 Jun 2026
Wow – this genuine n-Multitouch is just absolutely brilliant!
Posted: 05:12pm 05 Jun 2026
Minor update to WebMite RP2350 to support RSA encryption - see Wolfram Alpha thread for more details/example. No version change
WebMiteRP2350V6.03.00RC16.zip
Posted: 07:14pm 05 Jun 2026
  matherp said  WW
Last try. If this doesn't work then I think we have to assign that monitor as "non-supported". Every other touch monitor that has been tested AFAIK now works. You should see two devices connect. The multi-touch digitizer and a USB touchscreen. Make sure you test without a USB mouse also connected. It may be that only single touch via the USB touchscreen works but that would be a win.
PicoMite.zip
We have a response to touch!!
When Pico powered up and USB-touch attached I get the following:
PicoMiteHDMI MMBasic USB RP2350B Edition V6.03.00RC16
> ---- Touch HID report descriptor (704 bytes) ----
000: 05 0D 09 04 A1 01 85 0D 05 0D 09 22 A1 02 09 42
010: 15 00 25 01 75 01 95 01 81 02 95 03 81 01 09 51
020: 75 04 25 0F 95 01 81 02 05 01 26 FF 3F 75 10 55
030: 0E 65 11 09 30 35 00 46 79 08 81 02 26 7F 25 46
040: 8A 03 09 31 81 02 05 0D C0 09 22 A1 02 09 42 15
050: 00 25 01 75 01 95 01 81 02 95 03 81 01 09 51 75
060: 04 25 0F 95 01 81 02 05 01 26 FF 3F 75 10 55 0E
070: 65 11 09 30 35 00 46 79 08 81 02 26 7F 25 46 8A
080: 03 09 31 81 02 05 0D C0 09 22 A1 02 09 42 15 00
090: 25 01 75 01 95 01 81 02 95 03 81 01 09 51 75 04
0A0: 25 0F 95 01 81 02 05 01 26 FF 3F 75 10 55 0E 65
0B0: 11 09 30 35 00 46 79 08 81 02 26 7F 25 46 8A 03
0C0: 09 31 81 02 05 0D C0 09 22 A1 02 09 42 15 00 25
0D0: 01 75 01 95 01 81 02 95 03 81 01 09 51 75 04 25
0E0: 0F 95 01 81 02 05 01 26 FF 3F 75 10 55 0E 65 11
0F0: 09 30 35 00 46 79 08 81 02 26 7F 25 46 8A 03 09
100: 31 81 02 05 0D C0 09 22 A1 02 09 42 15 00 25 01
110: 75 01 95 01 81 02 95 03 81 01 09 51 75 04 25 0F
120: 95 01 81 02 05 01 26 FF 3F 75 10 55 0E 65 11 09
130: 30 35 00 46 79 08 81 02 26 7F 25 46 8A 03 09 31
140: 81 02 05 0D C0 09 22 A1 02 09 42 15 00 25 01 75
150: 01 95 01 81 02 95 03 81 01 09 51 75 04 25 0F 95
160: 01 81 02 05 01 26 FF 3F 75 10 55 0E 65 11 09 30
170: 35 00 46 79 08 81 02 26 7F 25 46 8A 03 09 31 81
180: 02 05 0D C0 09 22 A1 02 09 42 15 00 25 01 75 01
190: 95 01 81 02 95 03 81 01 09 51 75 04 25 0F 95 01
1A0: 81 02 05 01 26 FF 3F 75 10 55 0E 65 11 09 30 35
1B0: 00 46 79 08 81 02 26 7F 25 46 8A 03 09 31 81 02
1C0: 05 0D C0 09 22 A1 02 09 42 15 00 25 01 75 01 95
1D0: 01 81 02 95 03 81 01 09 51 75 04 25 0F 95 01 81
1E0: 02 05 01 26 FF 3F 75 10 55 0E 65 11 09 30 35 00
1F0: 46 79 08 81 02 26 7F 25 46 8A 03 09 31 81 02 05
200: 0D C0 09 22 A1 02 09 42 15 00 25 01 75 01 95 01
210: 81 02 95 03 81 01 09 51 75 04 25 0F 95 01 81 02
220: 05 01 26 FF 3F 75 10 55 0E 65 11 09 30 35 00 46
230: 79 08 81 02 26 7F 25 46 8A 03 09 31 81 02 05 0D
240: C0 09 22 A1 02 09 42 15 00 25 01 75 01 95 01 81
250: 02 95 03 81 01 09 51 75 04 25 0F 95 01 81 02 05
260: 01 26 FF 3F 75 10 55 0E 65 11 09 30 35 00 46 79
270: 08 81 02 26 7F 25 46 8A 03 09 31 81 02 05 0D C0
280: 27 FF FF 00 00 75 10 95 01 09 56 81 02 09 54 15
290: 00 25 7F 95 01 75 08 81 02 85 0A 09 55 95 01 25
2A0: 0F B1 02 C0 05 0D 09 0E A1 01 85 21 09 22 A1 00
2B0: 09 52 09 53 15 00 25 0A 75 08 95 02 B1 02 C0 C0
---- Parsed touch_info ----
 uses_report_id=1 report_id=13 report_length_bytes=54
 max_contacts=10 first_contact_bit_offset=0 contact_stride_bits=40
 contact_count bit_offset=416 bits=8
 tip_switch_bit_offset=0 in_range_bit_offset=0
 contact_id bit_offset=4 bits=4
 X bit_offset=8 bits=16 logical_max=16383
 Y bit_offset=24 bits=16 logical_max=9599
 input_mode=1 report_id=33 bringup: cc_max_id=10 cert_id=0
 pointer_fallback=0
Multi-Touch GET_FEATURE id=33 len=2 data=A1,1
touchTouch SET_FEATURE InputMode id=33 len=2
Connected on channel 4 (10 contacts, 16383x9599)
> ---- Touch HID report descriptor (80 bytes) ----
000: 05 01 09 02 A1 01 85 07 09 01 A1 00 05 09 19 01
010: 29 03 15 00 25 01 75 01 95 03 81 02 75 01 95 05
020: 81 03 05 01 09 30 75 10 95 01 55 0E 65 11 35 00
030: 46 79 08 26 FF 3F 81 02 09 31 46 8A 03 26 7F 25
040: 81 02 09 38 15 81 25 7F 75 08 95 01 81 06 C0 C0
 uses_report_id=1 report_id=0 report_length_bytes=0
 max_contacts=0 first_contact_bit_offset=0 contact_stride_bits=0
 contact_count bit_offset=0 bits=0
 contact_id bit_offset=0 bits=0
 X bit_offset=0 bits=0 logical_max=0
 Y bit_offset=0 bits=0 logical_max=0
 input_mode=0 bringup: cc_max_id=0 cert_id=0
 pointer_fallback=1 report_id=7 button@0 X@8/16b max=16383 Y@24/16b max=9599
USB Touchscreen Connected on channel 3 (16383x9599)
> T+0ms #1 [7] 07 00 00 00 00 00 00 -> count=0 active=0
NOTE that the last line appears after a delay of about a second - then sits there.
When I touch the screen (1 finger) and move it around, I see:
T+56545ms #2 [7] 07 01 D2 38 44 1B 00 -> count=1 tip=1 x=1136 y=523 active=1
T+56732ms #7 [7] 07 01 FF 38 13 1B 00 -> count=1 tip=1 x=1139 y=519 active=1
T+56884ms #20 [7] 07 01 BF 3A 14 16 00 -> count=1 tip=1 x=1174 y=423 active=1
T+57037ms #33 [7] 07 01 6C 3A 5D 11 00 -> count=1 tip=1 x=1168 y=333 active=1
T+57191ms #46 [7] 07 01 5F 36 C0 0F 00 -> count=1 tip=1 x=1087 y=302 active=1
T+57346ms #58 [7] 07 01 D7 2F 57 11 00 -> count=1 tip=1 x=956 y=332 active=1
T+57501ms #71 [7] 07 01 3D 2B 6F 16 00 -> count=1 tip=1 x=864 y=430 active=1
T+57656ms #84 [7] 07 01 56 25 93 1B 00 -> count=1 tip=1 x=746 y=529 active=1
T+57810ms #96 [7] 07 01 EF 1C 52 19 00 -> count=1 tip=1 x=578 y=486 active=1
T+57965ms #108 [7] 07 01 56 1C B8 11 00 -> count=1 tip=1 x=566 y=340 active=1
T+58120ms #121 [7] 07 01 10 25 52 10 00 -> count=1 tip=1 x=741 y=313 active=1
T+58275ms #133 [7] 07 01 5E 2F 00 12 00 -> count=1 tip=1 x=947 y=345 active=1
T+58429ms #145 [7] 07 01 B8 37 4A 0D 00 -> count=1 tip=1 x=1114 y=255 active=1
T+58584ms #158 [7] 07 01 DE 34 3E 08 00 -> count=1 tip=1 x=1057 y=158 active=1
T+58740ms #171 [7] 07 01 E4 2A A0 0C 00 -> count=1 tip=1 x=857 y=242 active=1
T+58894ms #183 [7] 07 01 7C 21 CB 10 00 -> count=1 tip=1 x=669 y=322 active=1
T+59048ms #196 [7] 07 01 AF 1B D4 0E 00 -> count=1 tip=1 x=553 y=284 active=1
T+59203ms #209 [7] 07 01 70 20 8B 09 00 -> count=1 tip=1 x=648 y=183 active=1
T+59358ms #221 [7] 07 01 6A 2B F6 0B 00 -> count=1 tip=1 x=868 y=229 active=1
T+59513ms #233 [7] 07 01 91 2F 7A 12 00 -> count=1 tip=1 x=951 y=354 active=1
T+59667ms #246 [7] 07 01 B2 35 D6 16 00 -> count=1 tip=1 x=1073 y=438 active=1
And when I add a second touch/finger it bounces between a count of 1 and 0:
T+250974ms #1154 [7] 07 01 35 12 38 16 00 -> count=1 tip=1 x=364 y=426 active=1
T+251256ms #1157 [7] 07 00 35 12 38 16 00 -> count=0 active=0
T+251421ms #1160 [7] 07 01 35 12 38 16 00 -> count=1 tip=1 x=364 y=426 active=1
T+251573ms #1166 [7] 07 01 35 12 3E 16 00 -> count=1 tip=1 x=364 y=427 active=1
T+252164ms #1172 [7] 07 01 2E 12 50 16 00 -> count=1 tip=1 x=363 y=428 active=1
T+252698ms #1173 [7] 07 01 2E 12 56 16 00 -> count=1 tip=1 x=363 y=428 active=1
T+252854ms #1178 [7] 07 00 00 00 00 00 00 -> count=0 active=0
T+253014ms #1190 [7] 07 01 7F 36 4D 0F 00 -> count=1 tip=1 x=1089 y=293 active=1
T+253186ms #1197 [7] 07 01 78 36 59 0F 00 -> count=1 tip=1 x=1089 y=294 active=1
T+253370ms #1203 [7] 07 01 21 12 87 16 00 -> count=1 tip=1 x=362 y=432 active=1
T+253567ms #1210 [7] 07 00 21 12 93 16 00 -> count=0 active=0
T+253726ms #1215 [7] 07 01 72 36 84 0F 00 -> count=1 tip=1 x=1088 y=297 active=1
T+253898ms #1221 [7] 07 01 72 36 8A 0F 00 -> count=1 tip=1 x=1088 y=298 active=1
T+254051ms #1234 [7] 07 01 B4 11 B7 16 00 -> count=1 tip=1 x=354 y=436 active=1
GUI TEST TOUCH works for single finger, and with 2 fingers will respond to the 'last' finger (although difficult to see for certain as the screen fills up with data making it hard to see the touch-pixels.).
UNPLUGGING the usb-touch results in:
Multi-touch Disconnected
> USB Touchscreen Disconnected
And reconnecting USB touch seems to now re-initialise correctly (i.e. I do NOT see the previous 'device limit reached' error).
I will now try the FW you posted at the top of this page in the hope that will work too (but without all the debug messages!!)....
homa
Posted: 07:12am 06 Jun 2026
  WhiteWizzard said  ...
WhiteWizzard,
is it working? Don't keep us in suspense
Matthias
Posted: 07:41am 06 Jun 2026
Hi Matthias,
Yes, it works (without all the debug messaging) but for now only for a single touch point.
So now I’m a bit curious to know if this screen has a non-standard data structure for multi-touch bearing in mind it supports 10-points and works as such when connected to a Windows laptop. Or whether there is simply more decoding required of the data sent.
Very happy with a single touch; but I do have a need for 3-point touch ideally with the amazing image this screen puts out.
Posted: 09:14am 06 Jun 2026
WW
We can't now take this any further unless you can do a USBPcap/Wireshark capture while the monitor enumerates and you touch with two fingers.
Posted: 09:21am 06 Jun 2026
Hi Peter,
I’m waiting for another smaller OLED touchscreen to arrive and hopefully that will work with multi-touch as I really like the ‘true-black’ at any angle. Trouble is, that screen is on a ‘slow-boat’.
Also have some other IPS screens here to re-try with the latest firmware for other projects where backlight-wash won’t be an issue.
I may get back to you regarding sniffing this screen if I can’t work it out with Google.
Thanks for getting a single touch working with this OLED, that is definitely a big help with other ideas.
homa
Posted: 10:02am 06 Jun 2026
WhiteWizzard,
what sort of touch controller is it? You might even find a detailed explanation of it, just like the one provided here. If only all companies would provide information like this   There's USB as well as I2C explained:
https://www.interelectronix.com/sis95xx-series-touch-data-format.html
Matthias
Edited 2026-06-06 20:04 by homa
fred777
Posted: 10:11am 06 Jun 2026
Relating to Memory sharing
  matherp said  It should work but I haven't tested recently. Are both RP2350s running at the same cpu speed?.
Yes, but since then
I was able to get Memory sharing running with the experimental
MMBasic RP2040 vga version from back when
Memory sharing was first announced.
But I’m not having any luck with the current
RC version at all. Tried it on RP2040 and RP2350A.
Posted: 02:02pm 06 Jun 2026
Definitely a bug. Working on it.
Posted: 03:58pm 06 Jun 2026
V6.03.00RC17
PicoMiteRP2040V6.03.00RC17.zip
PicoMiteRP2350V6.03.00RC17.zip
Fixes bug in MEMORY SHARE and improves detection of incorrect wiring
Fixes bug in PORT command when using pins > GP32 on RP2350B processors
Adds support for additional TLS crypto methods
Edited 2026-06-07 05:01 by matherp
terekgabor
Posted: 08:49pm 07 Jun 2026
Hello Peter!
I just playing with longstrings and found an interesting behavior.
If I have a longstring for example lg() its length is 500 character.
If I write LGETSTR$(lg(),500,1) I get the last character of the long string.
If I write LGETSTR$(lg(),501,1) I get an empty string. Seems normal, because no more character in the longstring.
Then I write LGETSTR$(lg(),502,1) or more then 502 the system feezes. Number of character can be not only 1, doesn’t matter how. Maybe in these cases the string has to be an empty string again, instead of freeze.
G@bor
JanVolk
Posted: 09:05pm 07 Jun 2026
Hello Peter,
After version V6.03.00RC11, the color code no longer works in EDIT for various functions. Tested with PicoMite MMBasic RP2040 V6.03.00RC11 and PicoMite MMBasic RP2350A V6.03.00RC11.
HEX$()
LCASE$()
LEFT$()
MAX()
MIN()
OCT$()
RIGHT$()
UCASE$()
Jan.
fred777
Posted: 08:25am 08 Jun 2026
  matherp said  Fixes bug in MEMORY SHARE and improves detection of incorrect wiring
Excellent, it works great now!  (Tested on 2x RP2350A HDMI)
Experimenting with the clockdiv parm is important. If set too low, the client can lock up completely and need a reset. But once the clockdiv is high enough its rock solid.
Yet one more cool function to add to the long list of picomite's capabilities :-)
Cheers!
Posted: 10:52am 10 Jun 2026
PicoMite RP2040 MIN version 6.03.00 rc14
New observation (not really surprising).
A genuine Pico 2040 that worked with previously listed code running 2040-MIN-60300rc14, refused to work this morning after having been powered down for 2 weeks.
This leads me to believe that the issue with not working PIO FIFO is caused by non initialized RAM.
- new Pico's typically have the problem when running any MIN version (60202rc5/60300rc9/60300rc14 are tested)..
- new Pico's work correct with the associated normal 2040 versions.
- Nuking flash and installing the MIN version has NO impact (when they did not work before, they don't work after..and when they worked before, they work after nuking).
- same with installing a normal version, running the program, and reverting back to the MIN version. (when they did not work before, they don't work after..and when they worked before, they work after).
- Setting any OPTIONs does not impact the MIN problem with PIO FIFO.
- Manipulating PIO associated registers (the few ones that can be written to from MMBasic) has no impact.
This leads me to believe it is not flash related. There is something in RAM (or cache, or peripheral register) that causes this.
Posted: 01:39pm 10 Jun 2026
Just to be absolutely clear:
1. PIO on the normal PicoMite build works perfectly in all circumstances?
2. PIO on the PicoMiteMIN does not work on a virgin Pico?
3. Loading and running PIO on a normal PicoMite build "fixes" that Pico for subsequent PicoMiteMIN usage?
4. If 3 is true what happens if a "fixed" PicoMiteMIN is powered off and then re-powered?
Posted: 03:37pm 10 Jun 2026
Hi Peter,
Pio works reliable on normal picomite.
When failing on MIN, converting to normal, running, converting back does NOT fix it.
What does fix it on MIN? I think I may have found it - compiler bug associated with the fact min uses extra ram for increased optimisation
Edited 2026-06-11 01:38 by matherp
Posted: 03:41pm 10 Jun 2026
Try this
PicoMite (2).zip
     Page 20 of 31
