Forum Index : Microcontroller and PC projects : MMCC question
| ville56 Guru Joined: 08/06/2022 Location: AustriaPosts: 560 |
Hi all, I'm trying to automate the setup of my PicoMites a bit more with less mouse clicks. In the MMCC manual there is a directive 'nap nn to pause processing for nn seconds. I'd like to use that instead of line-by-line confirmation but I always get into line-by-line confirmation. Is there a special directive to switch that off? Gerald 73 de OE1HGA, Gerald |
TassyJim![]() Guru Joined: 07/08/2011 Location: AustraliaPosts: 6571 |
I will have to look into it. Most of the OPTIONs I have in my mmc files result in reboots so the nap is off no use for me. It will bee a few days before I have time to do any testing. Jim VK7JH MMedit |
Thank you Jim, there is no hurry ... true, many options cause a reboot, but as I don't see the MMBasic prompt in MMCC after rebooting I don't know when I safely can enter "Yes" for the next line to be executed. Just a bit too fast and it would miss out the next line. A nap in between basically does the trick, but still every line has to be confirmed. So I thought specifying a nap and (possiby with the nap) avoiding confirmation it would wait and in parallel autoconnect, if necessary, for the next line. If the nap is long enough it could run automatically, avoiding to click yes for every line. forgot to mention the version: it is V5.4.0 Gerald 73 de OE1HGA, Gerald |
