Forum Index : Microcontroller and PC projects : tempr not working
| Page 1 of 4 |
With the latest version, ?tempr isn't working for me on an RP2350-Zero. I reflashed V6.00.01 and it worked; flashed again immediately with V6.03.00RC9 and it returns 1000. It does this on all the pins I have tried. PicoMite MMBasic RP2350A Edition V6.00.01 Copyright 2011-2024 Geoff Graham Copyright 2016-2024 Peter Mather > ?tempr(gp29) 25 PicoMite MMBasic RP2350A V6.03.00RC9 Copyright 2011-2026 Geoff Graham Copyright 2016-2026 Peter Mather Formatting the A: drive > ?tempr(gp29) 1000 > ~ Edited 2026-05-21 01:04 by lizby PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11513 |
Haven't got a ds18b20 with me so can't really look at it for the next couple of weeks. Can you find in which version it first stopped working then I might have a chance. |
It fails at RP2350A V6.01.00 PicoMite MMBasic RP2350A V6.01.00 Copyright 2011-2025 Geoff Graham Copyright 2016-2025 Peter Mather Formatting the A: drive > ?tempr(gp29) 1000 I don't have anything between RP2350A V6.00.01 and V6.01.00, and Geoff's archive doesn't contain and V6 versions. (Unfortunately, V6.00.01 doesn't contain trim$--I'll cobble a version.) PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
What about 6.02.01 on Geoff's site? |
| mozzie Guru Joined: 15/06/2020 Location: AustraliaPosts: 385 |
G'day Lizby, Have you tried other pins? Works here on GP0 / GP28 on RP2350A V6.03.00RC9 > option list PicoMite MMBasic RP2350A V6.03.00RC9 OPTION SYSTEM SPI GP18,GP19,GP16 OPTION FLASH SIZE 4194304 OPTION COLOURCODE ON OPTION CPUSPEED (KHz) 200000 OPTION LCDPANEL ST7796S, LANDSCAPE,GP14,GP13,GP12 OPTION GUI CONTROLS 64 OPTION TOUCH GP15,GP17 GUI CALIBRATE 0, 3978, 3840, -1298, -868 > ? tempr(gp0) 26.25 > ? tempr(gp28) 26 > This is on a RPI Pico2 so no access to GP29 Regards, Lyle. Edit: Just re-read your original post and it appears you have tried other pins ![]() Edited 2026-05-21 03:03 by mozzie |
Unless MMBasic does something clever GP29 isn't an ADC input on a RP2350A or B. Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
PicoMite MMBasic RP2350A V6.03.00RC9 Copyright 2011-2026 Geoff Graham Copyright 2016-2026 Peter Mather > ?tempr(GP5) 1000 > ?tempr(GP0) 1000 > option list PicoMite MMBasic RP2350A V6.03.00RC9 OPTION FLASH SIZE 4194304 OPTION COLOURCODE ON OPTION CPUSPEED (KHz) 340000 > ?tempr(GP0) 1000 > ?tempr(GP1) 1000 > update firmware PicoMite MMBasic RP2350A Edition V6.00.01 Copyright 2011-2024 Geoff Graham Copyright 2016-2024 Peter Mather > ?tempr(gp1) 25 > update firmware PicoMite MMBasic RP2350A V6.02.01 Copyright 2011-2026 Geoff Graham Copyright 2016-2026 Peter Mather Formatting the A: drive > ?tempr(gp1) 1000 > No go for me with RP2350A V6.02.01. I don't understand why RP2350A V6.03.00RC9 worked for Lyle but not for me. PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
G'day Lizby, Managed to find the RP2350-Zero purchased by mistake, GP29 does work with the DS18B20: > option list PicoMite MMBasic RP2350A V6.03.00RC4 OPTION FLASH SIZE 4194304 OPTION COLOURCODE ON OPTION CPUSPEED (KHz) 200000 OPTION DISPLAY 40, 80 > ? tempr(gp29) 25.25 > This is using the "Normal Power" option as shown in the manual, I had a heap of trouble with the "Parasitic Power" system as it seems to be quite dependent on device quality. Maybe this is causing what you are seeing. Might also be worth trying TEMPR START with a long timeout, I think this helped with slow sensors. Strange it worked on the older version though Mick, the DS18B20 uses the one wire protocol so will work on any pin, the TMP37 etc is perhaps what you have in mind? Regards, Lyle. Edited 2026-05-21 03:54 by mozzie |
Sorry, brain's gone... I'm concentrating on aquarium stands at the moment, not electronics. It shows, doesn't it? :) Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
| JanVolk Guru Joined: 28/01/2023 Location: NetherlandsPosts: 379 |
G'day Lizby, Rejected DS18B20 temperature sensors are left out in later versions and can be used with an extra timeout. Or try the code below. ' Function TEMPR() and TEMPW() Dallas DS18B20. V6.03.00RC10 Const Pin$="GP14" Do Print "DS18B20 TEMPW(";Pin$;"):"; Str$(TEMPW(Pin$),3,2);" "; Chr$(176);"C" Print "DS18B20 TEMPR(GP14):"; Str$(TEMPR(GP14),3,2);" "; Chr$(176);"C" Print "DS18B20 TEMPR(GP14):"; Str$(TEMPR(GP14,200),3,2);" "; Chr$(176);"C" ' TEMPR(pin [,timeout]) Manual: Ver 6.02.01 Page 200 PicoMite User Manual. Pause 5000 Loop Function TEMPW(Pin$) Local T1,T2,b,t OneWire Reset Pin$ OneWire Write Pin$,1,2,&HCC,&H44 Pause 80 t=Timer OneWire Write Pin$,1,2,&HCC,&HBE OneWire Read Pin$,2,2,T1,T2 TEMPW = ((T2 And &B111)*256+T1)/16 If T2 And &B1000 Then TEMPW=-TEMPW End Function Jan. |
| phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3291 |
Yes, I have one that is fussy about that. TEMPR START is essential for that one, and it reads a bit high so I think it's a fake. Sub DS18B20 TEMPR START 9,3 TEMPR START 10,3 DS1 = Cint(TEMPR(9)*10)/10 DS2 = Cint(TEMPR(10)*10)/10 End Sub Edited 2026-05-21 07:53 by phil99 |
The timeout fixes it: PicoMite MMBasic RP2350A V6.02.01 Copyright 2011-2026 Geoff Graham Copyright 2016-2026 Peter Mather > ?tempr(gp1,500) 24.25 > ?tempr(gp1) 1000 > > update firmware PicoMite MMBasic RP2350A V6.03.00RC9 Copyright 2011-2026 Geoff Graham Copyright 2016-2026 Peter Mather Formatting the A: drive > ?tempr(gp1) 1000 > ?tempr(gp1,300) 1000 > ?tempr(gp1,400) 1000 > ?tempr(gp1,500) 24.75 > PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
PicoMite MMBasic RP2350A V6.03.00RC10 Copyright 2011-2026 Geoff Graham Copyright 2016-2026 Peter Mather > new > tempr(gp14,170) 19.75 Jan. |
| Peter63 Senior Member Joined: 28/07/2017 Location: SwedenPosts: 196 |
Have tried connecting DS18S20 (yes S20) Getting strange values, have tested 4 out of 10 that I have... > new > tempr(gp7) 10.625 > tempr(gp7) 10.625 > tempr(gp7) 10.625 > tempr(gp7,170) 10.625 > tempr(gp7,170) 10.625 > tempr(gp7,800) 3.1875 > tempr(gp7,800) 3.1875 > tempr(gp7,800) 3.1875 I have a temperature of 25 degrees in the room. using PicoMite MMBasic USB RP2350B Edition V6.03.00RC10 tested and the device DS18S20, works on an Arduino UNO (5V) /Peter63 Edited 2026-05-21 17:50 by Peter63 |
The ds18s20 isn't supported by MMBasic. It functions differently and is not compatible |
Does this make any difference? > TEMPR START gp7,3 : TEMPR(gp7) |
| dddns Guru Joined: 20/09/2024 Location: GermanyPosts: 843 |
some more info ..at the time when timeout parameter was introduced |
i tested the program , and this display OK temp value... Family name: DS1820/DS18S20 Rom Code: 10 B4 65 B5 02 08 00 CA ScratchPad: 32 00 00 00 FF FF 0A 10 Power mode Parasitic ScratchPad: 32 00 FF FF FF FF 0A 10 Temperature: 25.0625 775.005mS, 9 bit ScratchPad: 32 00 FF FF FF FF 0B 10 Temperature: 25.125 774.997mS, 10 bit ScratchPad: 32 00 FF FF FF FF 0A 10 Temperature: 25.1875 774.974mS, 11 bit ScratchPad: 32 00 FF FF FF FF 09 10 Temperature: 25.1875 774.985mS, 12 bit Tempr() without start 10.625 Tempr Start Pin,0 10.625 Tempr Start Pin,1 10.625 Tempr Start Pin,2 10.625 Tempr Start Pin,3 3.125 huummm... /Peter63 |
result... /Peter63 |
| Page 1 of 4 |
