Local Time 02:19 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 3D Engine examples
joker
Posted: 09:05am 03 Aug 2026
Hello,
I found some videos on YouTube. One is a tank driving in circles and the other is a rotating football with lighting effects.
Does anybody know where I can finde the source code for these examples?
By the way, any example would help me to dive into this topic. Any suggestions?
 Matthias
Posted: 11:44am 03 Aug 2026
  joker said  Any suggestions?
Provide links to what you found. ;-)
LeoNicolas
Posted: 12:27pm 03 Aug 2026
I implemented those examples years ago, before the 3D API was released. They were written 100% in MMBasic.
Ancient 3D engine implement in MMBasic
https://github.com/leonicolas/cmm2-3d-api/blob/master/api-3d.bas
Octahedron code
' Octahedron-20 – Leo Nicolas
option explicit
option keyboard repeat 400,40
option base 0
option default float
option angle degrees
timer=0
mode 1,8
' Aux variables
dim f,i,v, x(2),y(2),z,vi(2),vo(2),tt
' Object data - distance X,Y,Z - Viewplane distance - Vertices and Faces arrays size
const dx=400,dy=300,dz=1000,vp=800,vs=5,fs=7
' Projection matrix
dim px(vs),py(vs)
' Vertices
dim vt(2,vs)=(0,250,0, 250,0,0, -250,0,0, 0,-250,0, 0,0,250, 0,0,-250)
' Faces
dim f1(fs)=(5,5,5,5,4,4,4,4)
Graphics Programming on the Colour Maximite 2 67/68
dim f2(fs)=(2,3,1,0,3,1,0,2)
dim f3(fs)=(3,1,0,2,2,3,1,0)
' Faces colors
dim
c(fs)=(rgb(yellow),rgb(cyan),rgb(green),rgb(magenta),rgb(red),rgb(blue),rgb(white),rgb(&H40,&H40,&H4
0))
' Rotation - Angles X,Y,Z - Rotation matrix
const ix=2,iy=1,iz=0.5
dim ax,ay,az, cx,sx, cy,sy, cz,sz, r(2,2)
' Main loop
cls
for i=1 to 720
   box 192,92,416,416,,0,0
   inc ax,ix
   inc ay,iy
   inc az,iz
   cx=cos(ax):sx=sin(ax)
   cy=cos(ay):sy=sin(ay)
   cz=cos(az):sz=sin(az)
   r(0,0)=cy*cz:r(0,1)=sx*sy*cz-sz*cx:r(0,2)=-sy*cx*cz-sx*sz
   r(1,0)=cy*sz:r(1,1)=cx*cz+sx*sy*sz:r(1,2)=sx*cz-sz*cx*sy
   r(2,0)=sy:r(2,1)=-sx*cy:r(2,2)=cx*cy
   for v=0 to vs
       math slice vt(),,v,vi()
       math v_mult r(),vi(),vo()
       z=vp/(dz+vo(2)):px(v)=vo(0)*z+dx:py(v)=vo(1)*z+dy
       if i=650 then
           pv(vo())
       end if
   next
   for f=0 to fs
       v=f1(f):x(0)=px(v):y(0)=py(v)
       v=f2(f):x(1)=px(v):y(1)=py(v)
       v=f3(f):x(2)=px(v):y(2)=py(v)
       math v_cross x(),y(),vo()
       if math(sum vo())>0 then
           polygon 3,x(),y(),c(f),c(f)
       end if
   next
next
tt=timer
' Execution statistics
page write 0
print
print "TOTAL AFTER "+str$(i-1)+" ITERATIONS: "+str$(tt,0,2)+" ms"
print "TIME PER ITERATION: "+str$(tt/720,0,2)+" ms"
print "FPS: "+str$(1000/(tt/720),0,2)
sub pv(vrt())
   tt=timer
   math v_print vrt()
   timer=tt
end sub
Check this manual as well
Graphics Programming on the CMM2
LeoNicolas
Posted: 12:31pm 03 Aug 2026
More here:
https://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=12896
Here:
https://www.thebackshed.com/forum/ViewTopic.php?TID=13139
Battlezone implemented by VegiPete
https://github.com/thwill1000/mmbasic-challenge/blob/main/2022/vegipete/StellarBattleinthe7GreenHillsZone.pdf
joker
Posted: 07:54pm 07 Aug 2026
Hello,
Thank's a lot for all this input.
It will take some time to dig through them. Especially VegiPete's StellarBattle is extremely impressive.
If I understood it correctly, the code was the base for the 3D engine but none of the programs were build with it, correct?
Correct me if I'm wrong, but none of the examples mentioned above use any kind of lighting, correct? Because the 3D Engine does not support any light source, I assume that lighting effects can't be done (efficiently)?.
Are there any examples out there that uses the 3D engine?
 Matthias
joker
Posted: 11:24am 17 Aug 2026
Hello,
Sorry for my silliy questions.
I had a deeper look into VegiPete's StelarBattle and it is using the 3D engine.
 Matthias
LeoNicolas
Posted: 02:28pm 17 Aug 2026
Yes, it is. My code was created before Peter added the 3D engine to MMBasic, and the inbuilt engine is way faster than my version in basic
vegipete
Posted: 07:28pm 17 Aug 2026
A detail that may not be initially obvious about the 3D engine is where the camera is, and which direction it is looking.
The camera is positioned at x,y,0 (x=0 and y=0 is easiest) and looks in the direction of positive z.
Objects in the field of view will have (approximately) x and y values less than the z value (this is a simplification, depends on where the viewplane is.) I used this to quickly remove non-visible objects from the drawing list in Stellar Battle. (I also skipped very close objects because they often don't render cleanly.)
As such, the camera doesn't move so view rotation (yaw) and translation is accomplished by moving all the objects in the X-Z plane. (Y unchanged.) When I get to it and add flying enemies to Stellar Battle, the Y value will change to show flight elevation.
Camera pitch and roll will require object translation and rotation.
